Question about GE Spacemaker JVM1640SJ Microwave Oven
Keypad number buttons not working on ge spacesaver microwave - auto program buttoms work?
Very angry. Fairly new, little-used Spacesaver Microwave [3][Clock][Surface Light] buttons now do not work. We never even press [3], just [1] and [2] to warm sandwiches.
Unplugged for an hour. Still not working. Everything else works. We never use anything else. Bad solder joint in circuit board or keypad?
Thank you.
Posted on May 14, 2012
MicrowaveSvc
  • 9047 Answers
SOURCE: G.E. Spacesaver Microwave - Keypad Won't Work
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
You may have a problem with the keypad or the control unit (circuit board / smart board).
We repair these on a regular basis. Details and *critical* safety, disassembly, and troubleshooting info is at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
Posted on Nov 22, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Microwave Keypad or Control Panel
If some pads on the keypad are not working, then you have a failed keypad.
If you (or someone you know) might want to replace it yourself, I have uploaded a handy guide with pictures showing you what's typically involved.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you would like to have us do this for you, we do that for $39.95 plus part costs.
On this model, the cover will have to come off to replace the light bulb. If it's mounted in the wall, it will have to come down.
The installation instructions are nice to have in this case. You can download GE owner's manuals and installation instructions here.
I have attached a drawing to show where the bulb is on this model. It is located on the right side of the oven next to the wall of the cooking cavity.
The bulbs are available in local grocery stores, hardware stores, and stores like Wal-Mart and Lowe's.
Please feel free to contact me directly if you need more help.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Sep 27, 2008
SOURCE: Microwave interior light
Very easy to replace...at least on my JVM1790. Remove the top vent....the long plastic thing that runs along the top of the MW. Two screws on top of the micro. Behind the charcola filter (if you installed one) is an access area to the bulb. remove one screw and the entire assy comes out. Simply R & R the bulb.
Posted on Apr 02, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: GE Spacesaver Microwave touchpad
You almost certainly have a bad membrane keypad.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
If you would like to have us do this repair for you, we do that for $39.95 plus part costs nationwide.
But please note that for some GE models, the membrane keypad is not available as a separate part, so you would have to order the control panel frame assembly which comes with a new keypad.
In this case, you simply move your circuit board into the new frame.
That is a simple do-it-yourself job.
Either way, we can let you know what your options and costs would be and send you other helpful info.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
Feel free to contact me
directly (and please remind me of your full model number from the tag on the unit) for more information & help.
We're happy to help you. Once we have all your information and offer a final solution, we'd appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
Microwave Oven Control Panel Repair Nationwide
Posted on May 04, 2010
SOURCE: It doesn't heat anything. Could putting metal in
This is usually caused by a "Blown" magnetron, and or the High power Diode And YES, putting metal inside the MW, will cause it to fail.
You need to get a "Quote" for any repair, as the repair may cost nearly as much, as new unit. Also the new unit will have a warranty.
Posted on Jul 21, 2010
Microwave keeps beeping on GE spacesaver JVM1640WB
Does the display say anything?
If it says "F3" then you have a shorted keypad.
Please post a new question with full model number and more detailed symptoms.
Nov 29, 2012 | Microwave Ovens
Model # JVM150001 GE Spacesaver Microwave stopped working. Clock & keypad are still working
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Jan 04, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave ge spacesaver touchpad does not work except for the
You have a failed membrane keypad.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites. There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
prototech@usa.net
May 04, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
The microwave GE spacesaver is not working. It
TAKE MICRO APART PHILLIPS HEAD SREWDRIVER LOOK FOR A FUSE DOWN WERE THE PLUG COMES IN OR ON THE RIGHT HAND SIDE.iF THAT DOUSNT SOLVE IT TRY TO TIGHTEN ALL THE SCREWS BE CAREFULL YOU DONT HAVE TO TIGHTEN VERY TIGHT. THANKS FOR ASKING Troy Lawton
Jan 13, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Numbers 4,7,8,9,0 and Beverage on pad do not work. Others do work, do I have to replace the oven? (Spacesaver JVM1440WH04) Over stove oven installed in Feb 2007, in use 4 months each year. This problem...
No you can have the keypad replaced. It may be something as simple as a dis-lodged keypad ribbon connection where it mates to the control panel recepticle. If you look here: http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 there are several model numbers it seems you did not provide all of the numbers but the keypad is the same. The key panel here is $75.00 http://www.appliancepartspros.com/partsearch/modelsearch.aspx?model=JVM1440 Then you add a service call or shop charge your looking at well over a $100.00 repair. Your call on how to proceed. Good luck.
Jan 12, 2010 | GE JVM1440 Microwave Oven
GE microwave not heating lights and keypad functional
You may have a fuse blown on the micro/ the vent and lights are a diffrent cercut , Try replaceing the fuse. its on the in side of the unit. if you need further assitance and you think you can do this I will be happy to instruct U DFD
Apr 11, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
851 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Shekar Avadhani
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
