Question about Maytag Neptune MDE5500AY Electric Dryer
One of our tumbling shelves in the dryer has come loose in two of the three places it is screwed in. I am not sure how to open the dryer, or enter the dryer to fix the screws?
  • 3 Answers
Remove the front cover and access the outside of the drum there are screws
Posted on Aug 28, 2010
Replace indesit IC70s element
Not sure which model you have but most heating elements are accessible through the back panel of your dryer. Take it off. locate the element, remove it and replace it. There should be about 3 screws holding it on with three wires going to it.
Oct 04, 2012 | Miele T7744C Dryer
My tumbling bar in my dryer in coming loose - how do I fix it
Remove the 2 screws holding the dryer door hinges and remove the 2 screws on the opposite side of the hinged ( in the door opening ) . Then the front panel will pull out ( from the top ) and off . This will give enough room to use a driver to tighten the baffle screws .
May 23, 2010 | Maytag MDG7600AW Gas Dryer
As dryer rotates, with clothes drying, it sounds like loose pocket change is loose in between the two tubs.........help!
the change gets caught in the three baffles that are attached to the drum.unplug the dryer,open the door and remove the two screws that hold the in place,remove the door,then remove the other two screws opposite the door screws and pull the front panel off.rotate the drum so one of the baffles are down in the right hand corner so you can get at the screws that hold the baffles onto the drum.try loosening the screws but you might have to remove the baffles to get to the change.let me know how you make out
Apr 19, 2010 | Maytag Neptune MDG5500AW Gas Dryer
Hi tumble dryer noisey when in use, can i still use it whist waiting to get it fixed.
Most likely. There are no guarantees in life, and without diagnosing it I can't be sure, but most of the things that cause a dryer to make noise while running. The only exception I can think of off the top of my head is if you have an Electrolux family (Frigidaire and a few others) machine and the three screws in the center of the drum in the back are coming loose. Otherwise, you should be fine. Good luck.
Mar 14, 2010 | Dryers
Paddle inside dryer came loose how do we tighten
You have to open up the dryer to expose the clothes drum. Most paddles are fastened by two or three 1/4" sheet metal screws. Look for your lost screw in the dryer or replace it with the same. Use a drop or two of lock-tite to keep screws in place. Good time also to clean out all lint which can become a fire hazard, replace the drum belt and redo all of the screws.
Oct 15, 2009 | Maytag Neptune MDE5500AY Electric Dryer
One of the three things that tumble the laundry in the dryer is loose--it is making alot of noise--how do I tighten it
I think you are talking about the large ribs that prevent clothes from just sliding in the drum.
They are available as a spare, so are usually screwed in from outside the drum.
To fix your problem, turn off and unplug dryer.
Remove back pannel screws holding the lid on, and slide back the lid.
Rotate the drum by hand internally untill the faulty blade is at the top. You should be able to see the screws that need tightening.
Replace parts when finished.
Sep 29, 2009 | Maytag Neptune MDE5500AY Electric Dryer
The fin on the Neptune Dryer has come loose and I need to remove the side panel on the dryer to replace the two screws that hold one of the three fins in place. It would be simple if I knew exactly how to...
Remove the 2 screws holding the door and the 2 screws on the other side of the door opening . Pull the front panel foreward and lift off . If still not enough room to reach under to tighten , remove the 2 screws (1 on each side , holding the top down , then lift top . DISCONNECT POWER BEFORE DOING ANY WORK .
Aug 18, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Loose shelf in Maytag Neptune dryer
Hi, UNPLUG the dryer. There are two screws on each side of the door opening. Remove them screws and the front should pull toward you and release.The door can either lift off or remain on. You can reach under the drum and tighten the screws.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 31, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore Elite Dryer with loose paddle- can I glue?
Unplug the dryer.
Remove the lint filter.
Remove the screws at the lint filter opening.
Pop the lid clips on the left and right front corners of the cabinet.
Rotate the drum counterclockwise until a tumble vane(paddle) is at the 12 o'clock position.
Tighten the screws going through the drum.
Repeat this for the other 2 vanes.
Re-assemble the dryer.
May 10, 2009 | Whirlpool LEB6300 Electric Dryer
Frigidaire combo washer/dryer screws inside come off
The drum shaft came loose from drum. You can YouTube it for procedure of disassembly of dryer. Remount shaft, if screws are bad may need new shaft with screws, make sure it is tight to drum. While you have it apart you can clean out lint.
Sep 27, 2017 | Frigidaire GLER331A Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
42 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
