Question about Texas Instruments TI-30X-IISTK Scientific Calculator
TI-30XB syntax Error - Texas Instruments TI-30X-IISTK Scientific Calculator
4 Suggested Answers
SOURCE: syntax error on TI-30XIIS calculator when i press
I had the same problem and finally figured out how to fix it. You need to clear the memory. To do so, first press and release the 2nd button at the top left of the calculator. You will see "2nd" appear on the screen at the lower left. next press the 0 button (which 2nd function is "Reset"). The key to making this work is: do not hold the 2nd button while pressing the 0 button. You have to press it, release it, and then press the 0 button.
Posted on Nov 08, 2010
  • 102366 Answers
SOURCE: where's the EXP button on
To raise e to the xth power, use e^x, which is the second function of the LN key to the left of the 4 key.
To enter a decimal exponent, use EE, which is the second function of the , key above the 7 key.
To raise a value to another value, use the ^ key, above the divide key.
Also, don't forget to use (-) instead of - when entering a negative exponent (or any other negative value).
Posted on Sep 29, 2010
  • 38 Answers
SOURCE: syntax error shows on screen of TI-83 Plus
It means there was a problem with your syntax which means you typed something incorrect. (like 8+*/8, which makes no sense and cannot be computed.)
Posted on Sep 15, 2011
I have a TI-30Xb. It keeps saying syntax error when I type 1500000 0,03/1-(1+0,03)^20. I have tried with both - but it keeps telling me the same
15000000,03/(1-(1+0,03)^20) =-18607853,8356453 or
15000000,03/(1-(1+0,03))^20
=43019579947925000000000000000000000000,0000000
Mar 25, 2015 | Texas Instruments Office Equipment &...
How do I graph a simple equation on my TI-86, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
Means you made a typing error while entering the equation. Using the minus sign instead of the negation sign (change sign) (-), can produce a syntax error. Maybe you need to explicitly type the multiplication sign
y= (-) 1.5*x +3
Try entering it as 3 - 1.5*x
Jun 11, 2014 | Texas Instruments TI-86 Calculator
How do I graph a simple equation, without getting an error 07 message? y=-1.5x+3
Error 07 Syntax
y= (-) 1.5*x +3
What is syntax error-ti-34 ii
A syntax error occurs if the command is not correctly entered.
Jun 01, 2014 | Texas Instruments TI-30XA Calculator
What does error syntax mean
You enter a command. It is like an English sentence with a syntax (correct structure). If the structure of the command is wrong, you have a syntax error. You could use a minus - sign, instead of a change sign (-) that constitutes a syntax error.
May 27, 2014 | Texas Instruments TI-84 Plus Silver...
TI-30 texas instruments calculator saying syntax error
You may be in a wrong MODE. But even in any computational mode you should be able to do simple operations.
Apr 07, 2014 | Texas Instruments TI-84 Plus Calculator
My TI-30XB WONT CALCULATE INVERSE COS OR INVERSE SIN
Does it refuse to do so or does it give an error message?
Three common errors:
  1. Not having the correct angle unit. Wrong result, No error message
  2. Confusing reciprocal of sine (1/sin(x) with arc sine (x) ,sin^-1(x). Confusing the reciprocal of cosine, 1/cos(x) with arc cosine (cos^-1(x)). Wrong result, No error message
  3. Taking the argument of the inverse sine and/or inverse cosine functions outside the interval [-1,1]. This gives a domain error.
Oct 28, 2013 | Texas Instruments TI-81 Calculator
I can't put a negative number in the matrix without a syntax error
Use the (-) key just to the right of the decimal point, not the - key. The second key is for subtraction.
Jan 27, 2013 | Texas Instruments TI-84 Plus Calculator
Syntax error shows on screen of TI-83 Plus
Sep 15, 2011 | Texas Instruments TI-83 Plus Silver...
Texas Instruments TI-30X-IISTK Scientific Calculator Logo
434 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
