Question about Linksys SPA921 IP Phone
How do i factory reset linksys spa921 when i have forgottoen the password?
3 Suggested Answers
  • 36 Answers
SOURCE: LINKSYS SPA-2102 CAN NOT FACTORY RESET, PASSWORD REQUIRED!!
You need to:
1) figure out where it's going for config file updates (e.g. http://ip address/path/filename (wireshark highly recommended for this)
2) once you have the filename, you need to find a "broken" copy of that CFG file. You may be able to use the broken sunrocket one (google linksys2102-sunrocket.cfg)
3) setup a webserver to it appears to be at the ip address above (there are a number of ways to do this - google sunrocket 2102 for some step-by-step instructions.
4) reboot the SAP with the DTMF codes
That all seem like too much? Then go to broadband reports.com and PM DogFace05 - he can remotely unlock your 2102, but there's a fee.
Posted on Dec 13, 2009
  • 59 Answers
SOURCE: lost password reset router to factory defualt cant
Please leave the user name box blank and type in admin for the password. I hope this helps and thank you.
Posted on Jan 23, 2011
How do i find my password to my link system
There is no way to find the password if it has been changed from the factory settings. You will have to do a factory reset of the router to allow you to log in and change the default password. Usually on Linksys pressing the reset button for 10-20 seconds resets the router completely to factory defaults. Usual user/password is admin/admin or admin/password. check your installation manual if you still have it or go the http://support.linksys.com to get a manual for your router.
Feb 01, 2013 | Linksys E1200 Wireless Router - Ieee...
Tip
How To Reset Your Linksys Router Password
If you have forgotten your Linksys router password, the easiest thing to do is to reset your router to the factory default settings and then go through the router setup process.
  1. To restore the router configuration to factory defaults, hold the reset button on the unit for 30 seconds.
  2. Once your router is hard reset, you will need to login and go through the router setup process.
  3. To reconfigure your Linksys, connect a PC to one of it's Ethernet ports, load a web browser, and go to http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
  4. On older Linksys routers, the default username is blank and the default password is "admin."
  5. On newer Linksys routers, both the default username and the default password are set to "admin."
  6. Once you are past the login screen, you are able to reconfigure the Linksys router.
  7. Go to the management tab and change the administrator password to keep others from accessing your router.
on Jul 12, 2010 | Computers & Internet
I've forgotten my security password for the wireless and want to allow another computer access. as i'm not very technical is it difficult to reset andstart again?i don't want to be without the...
If you have forgotten your LinkSys router password, the easiest thing to do is to reset your router to the factory default settings.
Once your router is hard reset, you will need to login and configure it again.
To reconfigure your LinkSys, connect a PC to one of it'sEthernet ports, load a web browser, and go to the URLhttp://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router.
LinkSys Default Password
On older LinkSys routers, the default username is blank and the default password is "admin." While newer models, both the default username and the default password are set to "admin."
Once you go past the login screen, you should be able to reconfigure the LinkSys router.
Here are some of LinkSys Router models along with its Default usernames:
Linksys EtherFast Cable/DSL Ethernet routers: Administrator
Linksys WRT54G, BEFW11S4: admin
Linksys Comcast routers: comcast
All other Linksys routers: {none}
Here are some of LinkSys Router models along with its Default passwords:
Linksys Comcast routers: 1234
Linksys BEFW11S4: {none}
All other Linksys routers: admin
For those [none] username/password entries listed above, no name or password is required. Just skip or press the Enter/Return key when prompted for those settings.
Jul 18, 2011 | Zyxel (91-004-361002) Wireless Router
How can i find out my pssword.
The default username and password for Linksys routers are:
Username: admin Password: password
or
Username: admin Password: admin
or
Username: <no username> Password: password
If all of this fail you'll need to reset your linksys router so that it will also reset the password to the default. To reset you linksys router you can check it out on this website: http://technicallyeasy.net/2008/01/how-to-reset-linksys-wrt54g-wireless/
Note: Reseting your router means it's going to reload the factory default settings and all of the settings that you made on your router will be deleted permanently.
Apr 23, 2011 | Linksys Wireless-G WRT54G Router
How i can change my wirless net password
If you have forgotten your Linksys router password, the easiestthing to do is to reset your router to the factory default settings. To restore therouter configuration to factory defaults, hold the reset button on the unit for30 seconds.
Once your router is hard reset, you will need tologin and reconfigure it again.
To reconfigure your Linksys,connect a PC to one of it's Ethernet ports, load a web browser, and go to theURL http://192.168.1.1/. This will take youto a popup box which asks you to enter a username and password to login to yourrouter.
Linksys Default Password
On older Linksys routers, the default username is blank and thedefault password is "admin." On newer Linksys routers, both thedefault username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigurethe Linksys router.
You want to go to the management tab and change the administrator password tosomething else to keep others from accessing your router.
Apr 05, 2011 | Linksys WAG200G Router
What is the default username & password for the SPA921?
According to the manual (http://tig.csail.mit.edu/manuals/spa941.pdf) there is no username/password when you first use it. Perform a factory reset to gain access to this.
Mar 28, 2011 | Linksys SPA921 IP Phone
Spa 921 reset default factory
Open menu and click factory reset
Mar 10, 2011 | Linksys SPA921 IP Phone
I need to figure out how to re-set my Linksys WRT54GX2 Wireless0G Broadband Router With SRX200
This article will guide you how to change the router's password and reset it to factory default.
NOTE: Accessing the router's web-based setup page requires a password. The default password of a Linksys router is "admin". For security purposes, it is recommended to change default password.
Changing the Router's Password
Resetting the Linksys Router to Factory Default
Resetting the Router Using the Web-Based Setup Page.
If any more problem encounter,post or thumbs back.
Nov 02, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
How can I reset an unknown admin pw on Linksys RV042 VPN Router? I'm the new IT guy here, and I don't have the admin pw for our VPN router (and I need to provide remote access to a colleage working...
Once your router is hard reset, you will need to login and reconfigure it again.
To reconfigure your LinkSys, connect a PC to one of it's Ethernet ports, load a web browser, and go to the URL http://192.168.1.1/. This will take you to a popup box which asks you to enter a username and password to login to your router Password: Admin
On older LinkSys routers, the default username is blank and the default password is "admin." On newer Linksys routers, both the default username and the default password are set to "admin."
Once you are past the login screen, you are able to reconfigure the LinkSys router
Apr 16, 2009 | Linksys RV042 VPN Router
Linksys SPA921 IP Phone Logo
857 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
