Question about Frigidaire ATF6000ES Front Load Washer
FRIGIDAIRE washer CONTROL BOARD could this be the problem the modle numer is GLTF2940ES2 i checked the soup dispencer sensor and it semm to be working and i replaced door switch to no availe it still has a code [do] no matter what i try to do.
  • 1 more comment
  • Thomas Perno Aug 28, 2010
    how shure are we that this should fix the problem the board is about 136.00 dollar's. thanks tom
    I have already replaced the door lock switch with another new one that has the same part number as mine and I am still getting the error message [DO] E41. Also I have checked the soap dispencer sensor with the ohms meter and I put the sensor by the magnet and used the wirers coming from the sensor and the ohms meter beeps showing it has connection. i was told by some else here that it has to be the control board with this checking good.
  • Thomas Perno Aug 31, 2010
    yes great help i replaced the controller board today and bingo problem fixed works great. thank you very much Tom
  • Frigidaire Master
  • 12,061 Answers
Hi, yes you are 100% correct, that fault you describe is indeed the controller board.
Whenever we have a situation like this, after replacing the relevant sensors, and it still stays the same, we then must suspect the controller. they are usually the problem anyway, they are not very robust anyway.
So you need to obtain a new controller board, and replace it. I am sure this will fix your problem.
If you have a meter you might like to meter the Door switch, connection, the Input, should go Low, down to Zero Volts, when the door is opened, IF the Input is "Stuck" then this input will NOT change.. even if it does, it is still possible for it to be a main board, as even though the signal may be there the Micro, may simply not be "Reading" that "Port", due to the Micro being faulty itself.
Posted on Aug 29, 2010
    Brigadier General:
  • 3,513 Answers
Yes please get the control board replaced as [do] error does not involve any other parts . Its due to a fualty control board.
Let us know if you have something more to ask else please accept the solution.
Thanks for contacting fixya.com
Posted on Aug 28, 2010
    President:
  • 1,554 Answers
The problem is definitely the door lock and switch assembly as the code signifies. Replace the door lock and switch assembly (part #131763202) to address the problem.
Disconnect power to the machine. Open the washer door then look for the retaining hoop securing the door seal around the lip of the door opening. Stretch the retainer spring of the door seal retaining hoop then remove it.
Carefully peel off part of the door seal from the lip of the door opening near the door lock and switch assembly. Remove enough of the door seal to gain access to the door lock and switch assembly.
Remove the screws securing the door lock and switch assembly to the front panel. Once the screws are removed, lift the door lock and switch assembly then FRIGIDAIRE washer CONTROL BOARD could this be the - 1a4b866.jpgway from the front panel.
Take the door lock and switch assembly out of the machine. DisconnecFRIGIDAIRE washer CONTROL BOARD could this be the - febd08e.jpgrical connections then connect it to the new door lock and switch assembly.
Put the new door lock and switch assembly back into position in the front panel and secure it with the securing screws.
Properly put the eased part of the door seal back over the lip of the door opening then secure it with the retaining hoop.
Feel free to update us about the development of the repair. Please make sure to accept the solution that helped you the most. Failure to do so will automatically give credit the first solution no matter how inappropriate or not helpful it is.
Accepting a solution does not stop you from communicating with an expert. You may continue communicating with the expert as long as you need assistance regarding the issue stated herein.
  • Jahn27
    Jahn27 Aug 29, 2010
    Check the connection (J2 and J3) between the door lock and
    switch
    assembly and the control board. Make sure the connections are good and
    snug fit. Reseat the connections several times to clean off
    dirt and corrosion build up on the connectors
    and terminals.
    Check the wiring harness connections on the door lock and switch
    assembly and do the same to the connectors. Also make sure
    the wire harnesses connecting the control board and the door lock and switch assembly are intact and have continuity. It is pretty sure that the control board always "thinks" that the door is open and it is the culprit if the error code persists with the door lock and switch assembly replaced and the wire harnesses and connectors are all but good.
  • Jahn27
    Jahn27 Aug 31, 2010
Why does my dishwasher most of the time not desovle the dish soap
make sure when you load it that nothing is stopping the soap door from opening all the way,, most common mistake is loading a cutting board or tray in the front of the lower rack
Nov 20, 2015 | Frigidaire Dishwashers
Error code 32
Hello Lance - Error code 32 for Frigidaire models means there is pressure sensor calibration problem. This will need to be checked and a repair performed by a technician since they must do the following: inspect the wiring between the pressure sensor and the main control board. Correct the defective wiring and/or replace the pressure sensor or main control board.
Sep 16, 2012 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire dish washer FDB4315LFo Error code uo
You are experiencing a vent issue - While in wash cycle, Main Control Board does not receive signal from vent assembly that vent plunger is closed. Plunger status is sensed with optical sensor in vent assembly. Check wiring between vent assembly and Main Control Board. If wiring correct, replace vent assembly. If error still exist, replace Main Control Board.
Sep 04, 2012 | Frigidaire Dishwashers
My Frigidaire front load washer doesn't spin, it turns during the wash cycle, doesn't show an error code, but doesn't spin the load at all, it is model CLTF2940ES0. Is it something simplet to fix?
Welcome to FixYa.
Based on what you've described,...you likely need a door lock/switch assembly. The closest I found to your model is actually CLTF2940ES0.
The door latch is likely the single most common fault (which prevent's any spin, and consequently drenching wet clothing at the end of the cycle) with the frigidaire/electrolux built washer's, aside from pump's being obstructed.
I think it fool's many people because the lock indicates it is energized on the panel, however the built in "monitor" switch inside the assembly fail's. I do see a lot of these particular machine's...unfortunately.
You should be able to purchase one at most local brick
Sep 05, 2010 | Frigidaire GLTF2940ES Front Load Washer
Getting an E6E error on my Frigidaire GLTF2940ES2 washing machine. What does it mean? The code is not in my owners manual. Machine starts but stops after a few minutes. It is now full of wet clothes and...
Hi
Thanks for using FixYa. Error E6E is a communication error between the motor control board and machine control. To resolve this you’ll need to check the wiring between the control board and the machine control board. If that is fine then replacing the control board should resolve the issue, you can buy its parts from this link. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 02, 2010 | Frigidaire GLTF2940ES Front Load Washer
THE ICE MAKER WILL NOW ONLY MAKE A FEW CUBS
Our Kenmore ice maker GSI23 has stopped making ice cubes, the water still flows out the front, the sensor arm is down and we have pushed on the O button numerous times but still no ice. Help please
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
My frigidaire refrigerator is broken
Under the cap of the top end of your freezer door is a plug. Unplug it. If this is helpful, please post as such. There is more to look at. Please use premium chat so I can help you while you help me. TY
Jan 17, 2009 | Frigidaire Affinity ATF7000ES Front Load...
My Frigidaire Front Loader Washer will not turn on at all???
it came from your dispencer ..it activates a sensor on the unit right side,,,,take your dispencer out turn it over and that magnet goes on the left side when dispencer is right side up....yes that magnet is neeeded to start unit...onthejob
Jan 11, 2009 | Frigidaire ATF6000ES Front Load Washer
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire Washer - pressure sensor
I WOULD SAY REPLACE THE PRESSURE SENSOR IF BOTH CONTROL BOARDS HAVE BEEN REPLACED
THE MOST ECONOMICAL PART ASSOCIATED WITH THE CONTROL BOARDS ESPECIALLY AFTER HAVING ELECTRICAL PROBLEMS IS MORE THAN LIKELY THE PRESSURE SENSOR it may have BLOWN ALSO
Jan 31, 2008 | Frigidaire Affinity ATF7000E Front Load...
Frigidaire ATF6000ES Front Load Washer Logo
521 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
