Question about Watches
I have a timmex Essentials wrist watch I have opened the back and have removed the plastic support ring. I do not know how to remove the crown to get the mechanism out. Ultimately I want to fix the "second" arm of the watch Can any one guide me?
  • 831 Answers
Thank you for contacting FixYa.<br /> Can I be honest here? If you are not a wathmaker, then you are doing more harm then good trying to fix your own watch. You need to take to a qualifed watchmaker to have the second hand fixed because without the proper tools and know how, you WILL damage your watch and ultimately if its still under warranty, you will null and void that too.<br /> My best advice is to go to this link:<br /> <a rel='nofollow' href="http://www.timex.com/info/Online_Repair_Guide">http://www.timex.com/info/Online_Repair_Guide</a><br /> Best regards. <br /> Jewel
Posted on Aug 28, 2010
Skagen solar watch
try pushing then screwing it in
Apr 08, 2013 | Skagen 233LSS Wrist Watch
How do i remove crown?
hummmmmmm
u need to go experts of watch reper i think its its problem in watch curcuit thats y this happen
& thnx useing fixya
Mar 28, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Hello I have two nixon men's wrist watches that
just bring your watch to Nixon watch experts. they have spare and tools to repair your watch.
Jul 14, 2011 | Watches
How do I safely remove the crown of SEIKO ladies wristwatch
it might just lightly push on but not expert at this. clocks do. and some watches do. thats a fact.
Mar 26, 2009 | Seiko SNA413 Wrist Watch
Remove the winding stem/crown.
There is a tiny point (end of small metal piece called setting lever) on the left side of the stem (on watch movement, very close where the stem is entering the movement).
You have to push that point down with a metal pin or tweezers. Crown (winder) must be pushed in to normal position otherwise you will not be able to put the stem back properly.
So, do as follows:
1) Push the crown in,
2) Lay the watch down on flat surface and push on setting lever point,
3) While holding setting lever pushed in- extract the setting lever by gently pulling crown out of watch.
Do not forget to rate, please.
Jan 09, 2009 | Fossil AM3425 Wrist Watch
Removing the crown
The video i want to see you,is using older kind of watch,screwing before he can pull the crown ,the new model watches now like your Tag Heuer is pushing, use a needle to push, while pushing the stem lock you pull the crown .That's why ill tell you in advance so you aware.I know because i'm a watch technician working in rolex before...
remove the crown
if i helped,please,click FOR RATING .It is the only way i get paid for my works also,please consider leaving feedback..
Regards,
VOTIT
Sep 07, 2008 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Jan 13, 2008 | Casio MQ24-7B2 Wrist Watch
How do i remove the crown on my DKNY 1094 2003 model
nice noon to you ! you need to open the crown ,to open the crown , wind it counter clockwise until the crown lose then pull it and adjust the time after set the time ,push the crown and wind it clockwise until the crown fix tight,
Dec 21, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Hi, on the back of the movement there should either be a screw or a dimple in line or next to the line of the stem. If a dimple, press in with a pin or similar sturdy tool and gently withdraw the stem. If a screw, only one turn should be enough to release the stem
Nov 13, 2007 | Tag Heuer Formula 1 CAC1111.BA0850 Wrist...
Watches Logo
22 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
