My sf 2540 is producing blank copies - Office Equipment & Supplies
  • 52 Answers
Check the corona wire srevice the inside
Posted on Aug 28, 2010
My sharp SF-2540 it has a code H5-02
its an error code for the fusing unit
Sep 06, 2016 | Sharp SF 2540 Copier
How do i remove error code C2 on Sharpf SF2540
Check the Transfer corona wire assy. located under the drum where the paper flows by, mite be broken or the power supply that provide power to it mite be bad, several hundred to thousand of volts during a copy operation when machine is woking
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 22, 2014 | Sharp SF 2540 Copier
Sharp 2540 code f2
F2 mean toner not supply .Change toner chip
Jul 12, 2014 | Sharp SF 2540 Copier
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
How can I reset the password/ Copying code on SF 2540 copier
codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Aug 08, 2012 | Sharp SF 2540 Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Sharp AR 5316e copier
check if the developer that comes in a silver bag has been installed and the screw that fastens the scanner has been removed.
Jun 19, 2008 | Sharp SF 2020 Copier
Sharp sf.2540
Press C - interrupt - 0 - interrupt - flash
and then
14 and press start
Feb 26, 2008 | Toshiba e-Studio65 Copier
52 people viewed this question
k24674
jasbo
jasbo
