pls try disable the DMZ in router it will forword all the TCP ports to your designated host in your internal network pls Note that, it will course disable sequrity in your designated host as well
is this an electric motor? if so, you can just switch the polarity around. meaning connect positive to negative and negative to positive. hope this helps!
first ooff you will have to get the port NUMBERS from Kuma then have them forwarded to the router by following the instructions in the link below (do not use the ports in the link, they are just examples, use the ports that KUMA will give you.
ok port forward if any has router this is easy ill get too others in momment
routers port forwarding features type in ip address in internet explorer search bar at top
router ip's start like this 192. type the whole ip in
this will ask you for password and that usually is the word "password" or "admin" threw that you can set the router port forward by going down the list
now for comps with out routers
goto control panel
then network connections
right click on your connection
goto properties
goto advanced
goto settings
you will be directed to windows fire wall
goto exceptions add program or port you want to forward
basically port forwarding is a program that keeps 2 comps from having conflict with each other running the same program and helps in monitoring ports for intrussions
