Question about Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive
I'm on Indonesia, exactly on Central Java... My HDD is Seagate FreeAgent 250 GB... I've plugged the USB cable and i connected the HDD to my PC... then, the led is just blinking for once, then black out, and my PC do not detect the HDD... please help me...
    Sergeant:
  • 203 Answers
If you get no joy using the Troubleshooting Guide then try this...
You will need to check You Tube to find a Dismantle on your product and follow the step guide on here, the procedure should be similar.
Check 1st that your External HDD has an P.C. internal HDD inside, from You Tube, before dismantle of your External HDD. Connections for an Internal Laptop HDD may have same connections as P.C. not sure though.
Once your happy that it has continue reading and follow the step guide on the link below.
My neighbour has the Seagate FreeAgent Desk 500GB, and in under 2 weeks it started to beep and was not recognized by any Laptop or P.C. if this is the same for you with any FreeAgent Desk series ( not GO series, different procedure for GO products). You maybe in luck click this link, you may have to register in the forums to view thread.... http://www.yo-lid.co.uk/forum/viewtopic.php?f=32&t=84 Thread can be found in 'Technical' under 'General Technical Issues',
Only attempt this option if you have important information saved in it, you will find that you will be charged by your product makers for retrieval of any information saved on your product.
Thumbs up please if it's any use to you Thank you.
Posted on Aug 28, 2010
  • Ytee
    Ytee Oct 09, 2010
    link being amended to another site soon sorry please be patient.
My external usb hdd showing unknown device
If the unit has mains power, check that it is getting it. Also if it comes with two usb plugs then make sure both are plugged into usb ports on your pc. Try the unit on someone elses pc/laptop. if it works on theirs then your pc has a problem with the usb ports.
Aug 05, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hi, I have got a problem with my Seagate free HDD 320 GB, I lost my original USB cable bought with the Hard drive, then I bought another USB common cable. I tried to connect it prompt the following: Light...
Start -> Run -> devmgmt.msc. Check any yellow marks or explainary marks or red x marks. Right click on that and UPDATE driver.
If not working, please try with another NEW cable..
Jun 17, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
Nu pot formata hdd seagate free agent go 250GB
poti descarca manualul de utilizare pentru Seagate FreeAgent Go facand click pe acest link:
http://www.seagate.com/staticfiles/support/freeagent/fa_go_qsg_r2.pdf
Citeste cu atentie si vei gasi modul de formatare a unui astfel de disk.
Daca pot fi de ajutor in continuare, anunta-ma! Daca raspunsul meu a fost de ajutor , te rog voteaza-ma.
Mar 10, 2011 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How can you connect a seagate 250gb external hdd to a ps3 120gb
i have just bought a seagate external 1tb hdd to store more stuff on but it wont connect to my ps3 slim 120g what can i do
Nov 16, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Computer (windows XP)not recognizing external usb device (seagate FreeAgent go 250 GB)
i had a few problems myself and i figured out that the plug was busted inside so i got a new 1 and it works :)
Aug 12, 2010 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I cannot use format my free agent go. It shows that I/O device is error and sometimes show that the parameter is incorrect
u have to connect your hdd on anther usb port and try to format if its not work then change the cable of hdd then try to format your hdd
Nov 13, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
I'm sorry my enlish verry littl. Mi HDD Seagate FreeAgent Go 250 GB USB 2.0 Hard Drive No runing. I chenj cabl
Hi. Is the power light on the drive on? Is it flashing (this indicates an error)? If it is check the usb port you are using. You cannot use a usb hub, a usb port on a monitor or any other port that is not directly connected to the computers power supply. If you are using a dock make sure that both of the plugs are connected to powered usb ports. I could not get this drive to run until I plugged it into the right port. Use only the short cable that comes with the drive or the dock that is made to use with the drive. I hope this suggestion helps.
Jan 15, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Tryi8ng to install portable 120GB hard drive (seagate)
If your USB ports do not supply enough power (older computers) then the drive may fail to show up in My Computer.
The Seagate should have a special Y cable. There are two USB connectors on one end that must both plug into your computer - one for data and power - the other for power only. The other end of the cable has the mini USB which plugs into the Seagate.
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=External_Drive_Troubleshooter_-_Windows_Error_Messages_-_Common_External_Drive_Errors&vgnextoid=14d24a3cdde5c010VgnVCM100000dd04090aRCRD#clicks
Mar 22, 2008 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Seagate FreeAgent  Go 250 GB USB 2.0 Hard Drive Logo
154 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
