Question about Weather King 10AJA4201AH Air Conditioner
My rudd ac quit working opened panel and found black round part is blowout
  • 455 Answers
Hello That is the START capasitor,disconnect it & get and install a HARD START KIT on the run capasitor.It is a simple 2 wires that plug on the run cap and will do the job of the defective factory one.
Posted on Aug 28, 2010
Coleman ac compressor quit working
The black plastic capacitor is the compressor start capacitor, it is only in the circuit until the compressor gets up to speed. The black box is the start relay, it stays closed until the compressor gets up to speed the opens taking the start capacitor out of the circuit. The wires should go from it to the small metal round capacitor and the black box.
You can Ohm out the start relay, it should be closed between Terminals 1 and 2 and the coil is from 2 to 5. You can also check the 2 capacitors, you need a Volt Ohm Meter that has a capacitor testing scale. The microFarads should be on the capacitors you will need to cut the bleed resistor on the start capacitor before testing it.
Jul 18, 2013 | Coleman Mach III Air Conditioner
Where can I buy blowouts for my daughters first birthday? I want pink or girlie designs and so far have not found anything l like in the shops.
Check out the Party City site. I just love their girlie options for blowouts....Disney, hello kitty, Cinderella and more. I think you are going to have a great time choosing something for your daughter. Enjoy and congrats.
http://www.partycity.com/category/birthday+parties/birthday+favors/girls+party+favors/blowouts,+noise+makers.do
Feb 25, 2013 | Event Planning & Celebration
My Black & Decker Leafblower Leaf Hog BV4000 type 2 quit running suddenly while using. It had run about an hour, was not warm to the touch and is 2 years old. Is thuis a common problem and what might
Same thing here after i did my neigbours yard!!!! i found out it was the switch the latch that moves it wont I am trying to work a away round it hope this helps
Nov 18, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
The heater is showing me ac, and is not letting my heater to light up
its either a bad vaccum switch that is closed and cant open or its a ignition control module or (fenwall) not sending power for it to open open panel and slide down cover there is two round black saucer looking switches replace them or jump them by connecting wire to both leads bypassing the switch if heater turns on need vaccum switch if not ignition control module
Jan 24, 2011 | Hayward 400fdn Low Nox Nat Gas Swimming...
When i'm doing 60mph on the highway, my steering wheel starts to shake
Usually what I see when I encounter this type of problem is an out of balance or out of round tire, loose steering parts, loose suspension parts, or a combination of all three. I would start by having the tires inspected and spin balanced. A tire that has become out of round or has developed a bulge in it is often close to complete failure [flat or blowout] so I would have it checked out as soon as possible as it can be quite a safety hazard. It only takes a short amount of time to have the steering and suspension checked for any loose or worn parts while they are checking the tires so I would have that done at the same time. Good luck, hope this helps!
Aug 01, 2010 | 2003 Honda Civic
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
Dec 06, 2009 | Ruud UAMB042 Air Conditioner
How do reverse polarity on rudd ac compressor
Is this a 3 phase compressor? If it is it will have markings L1 - L2 - L3 and it will not have a run capacitor, then just reverse any two compressor wires. If it's single phase then you can't without Burning up the start windings, it will be marked C - S - R and have a run capacitor, these markings are on the Compressor.
Jun 22, 2009 | Heating & Cooling
Has not ever run properly
is it a heat pump? I would be suspect of the line voltage transformer have 24v. if transformer is not matched to line voltage you can have erratic problems their is an under lying problem. that is being missed find a good contractor . Tom
Jun 17, 2009 | Ruud UBHC Air Conditioner
DeWalt DW911 Radio/Charger
the second fuse is behind the circuit board,in middle of the radio.
there are 4 screw holding circuit board. Still looking for 2 AA battery.
Oct 09, 2008 | Dewalt DC011 AM/FM Radio
REST BUTTON ON RUDD AC
There is no reset button. Check your main power panel for the circuit breaker. Check the fuses in the outside disconnect if it has fuses. Some only have a reversible block.
Jul 07, 2008 | Ruud UBHC Air Conditioner
Weather King 10AJA4201AH Air Conditioner Logo
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
