Question about Frigidaire Dishwashers
How can I properly drain the water out of the bottom of my frigid dishwasher? Model #FDB520RHBO
  • Frigidaire Master
  • 43,501 Answers
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Posted on Aug 29, 2010
Water in bottom of a frigidate professional dishwasher
Hello shellytake5 - Often when there is standing water in the bottom of the dishwasher, it is because more than likely the control or drain pump assembly is faulty and possibly need replacing. However, if the unit is making a grinding noise then it is recommended for the drain motor to be diagnosed. If this problem persists, you can locate a certified technician directly through the manufacturer website or in your local directory to determine what may be causing the issue at hand.
Apr 16, 2013 | Electrolux Frigidaire Professional Series...
Maytag dishwasher model DWU9906BAX, 15 years old, in the past 6 months we have been finding dirty water in the bottom between uses. We have made sure the 'drain' cycle emptys the bottom after...
This is truly a drain pump fault as it fails to pump out the dirt and water. In a period of time the drain can get choked and so it will not drain out efficiently. so it is best to remove the pump and clean up the drain section which must solve this issue. keep the washer tilted to drain properly.
When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Sep 15, 2011 | Maytag 24 in. DWU9902 Built-in Dishwasher
My model DU810swkqo dishwasher will not drain completely [leaves about a couple of qts of water in the bottom after cycle.It has started dripping water out the bottom of the door.Can or does it need drain...
Hello
If the water won't drain from the dishwasher, first manually remove as much water as possible and then check the sump area for paper or any other large object. Make sure the door is properly latched. The pump will not drain if the door is not latched properly. Check the belt, drain line, air gap, drain valve and solenoid assembly, the motor, and the pump. If your dishwasher uses a belt to drive the pump, and it has broken or come off the pulley, replace it.
A cup or so of water in the sump area of your dishwasher is normal. It is there to prevent the seals from drying out. The dishwasher will pump this old water out before beginning to wash.
If you have recently installed a garbage disposer in your home, make sure that the drain plug on the disposer has been removed. It's just a little plastic piece that blocks the hole where you hook the dishwasher drain hose. If your dishwasher drains through the garbage disposer, you need to run the garbage disposer before you run the dishwasher to make sure that the drain is clear.
There is a drain hose between the drain valve or pump and the garbage disposal or drain line. If an obstruction has blocked this, then your dishwasher won't drain. The drain hose is connected by clamps to the drain valve and the disposer or drain pipe. Remove it and visually inspect it for a clog or a kink. Try to remove any debris. If it is in good condition, just put it back on, and if not, purchase a new one to install.
If you don't have an air gap in the drain line, at least use a high drain loop. Making a large loop about 18" off the ground with the drain line can prevent any back flow into the dishwasher from the sink.
If you have one, the air gap will be located on top of the sink. The air gap is there to prevent any siphoning of standing water from the sink. When your dishwasher drains, the air gap diaphragm will form a seal and allow the water to drain properly. If the diaphragm in the air gap is faulty, it's possible that water can leak onto the cabinet and into the sink area. When this happens, then the air gap must be replaced.
Like the inlet valve, there is also a drain valve on most models. When no power goes to the drain valve it remains closed and prevents water from leaving the machine. When the valve receives power during the drain cycle, the solenoid opens and allows the water to leave the machine. If your drain hose is attached directly to the pump, you don't have a drain valve. The motor simply reverses and the pump sends the water in the opposite direction, which is out of the machine.
If the motor doesn't turn or work properly, the dishwasher may not drain. Make sure you have power to the unit. If you notice that the motor hums but won't turn, it could be seized, and you probably need to replace it.
Small objects can sometimes get stuck in the pump. When this occurs, you'll need to open the pump and remove any debris buildup. The dishwasher pump is usually mounted directly to the motor and runs off the motor as well. The pump is also attached to the bottom of your dishwasher and pushes the water from the dishwasher.
Aug 06, 2011 | Dishwashers
DU943PWK model, water is sitting in bottom, won't drain
Hi
Thanks for using FixYa. Dishwasher not draining properly or not draining at all issues can arise due to different reasons. Usually, these issues are related to kinked hoses, knocked out disposer unit (if connected with the dishwasher drain hose) & clogged drain pump & filter. Also note that dishwashers do not drain completely after a finished cycle and this is normal. Dishwashers are designed to leave some water in the unit to ensure that the heating element doesn't overheat. If you suddenly begin to experience a large amount of water being retained in your dishwasher, you have a problem. Some of the most common reasons include that the drain hose isn't working properly, the drain pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines. First check whether the drain is not clogged or blocked and the line is not kinked. Check all the hoses for blockages & also clean the air gap. If you have checked the drain hose and can't locate the problem, then it is an issue with the drain pump of the dishwasher. Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Oct 27, 2010 | Whirlpool Dishwashers
My model FDB1100RHCD doesn't drain all water. lots of standing water in bottom of unit.??
Hi
Thanks
Rylee
Oct 07, 2010 | Frigidaire FDB1100RHM Builtin Dishwasher
Dish washer not draning all the water
Could be a couple of things:
The drain is partially blocked.
There is some debris in the bottom of the dishwasher causing this.
The motor is not reversing properly. Some dishwashers the motor reverses to pump the water out.
There is water flowling back down the discharge tube.
Sometimes there is a flow director in the discharge tube that keeps the water from the drain from flowing back down that tube and it is not working properly. Check all these things. To give an detailed and particular answer please provide the model number and brand of your dishwasher...
Aug 03, 2010 | Dishwashers
Not draining properly
Check for plugged drain hoses in your dishwasher, also make sure that the pump is working correctly
May 06, 2010 | Kenmore 24 in. 15689 Built-in Dishwasher
I have Dishwasher FDB520RHBO and it smells like rotten milk/eggs each time we wash dishes. The filter is clean and it is less then one year old. What could be wrong?
Check your main drain system, where you discharge the water.
Remove the machine hose and collect the washed water in a bucket. Check the m/c for smelling. No mell noticed then check the main drain.
Apr 16, 2010 | Dishwashers
Maytag dishwasher will not drain water - remains in bottom of tub
Without a proper model number, it sounds like either the drain pump is defective or something is stuck in it or the drain tubing is clogged. Best off to call a reliable service company such as Sears.
Jan 31, 2010 | Dishwashers
Fisher & Paykel Dishwasher leaked
From what you describe, drain water from the top drawer is getting into the bottom drawer or waste water from the disposer is backing up into the bottom drawer.
1. Each drawer has its own drain hose. Each hose should terminate at the drain point with a 'Y' adapter.
2. Inspect the drain point (under the sink where the drain pipes are) to make sure this 'Y' adapter is present. (you should see two drain hoses from the DW). If not present, then the DW drain lines are not installed properly. (Someone took a shortcut and installed the 'Y' adapter behind the DW)
3. If terminated properly, make sure the drain hoses extend upward as they leave the drain point.
It is important the drain lines are connected properly to ensure proper drainage from the DW. Consult the installation manual for complete details.
Jun 08, 2008 | Fisher DD603B / DD603W / DD603H Dishwasher
Dishwashers Logo
89 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Robert Roath
Robert Roath
Level 1 Expert
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
