Question about Amana ABB1927DE Bottom Freezer Refrigerator
Refrig not cooling - freezer okay - Amana ABB1927DE Bottom Freezer Refrigerator
  • Amana Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Posted on Aug 28, 2010
Vegetables in crisper are frozen, as well as liquids in bottom 1/2 of fridge door. The fridge & freezer temp controls won't adjust to our settings. Also, we're getting ice, but no water will dispense.
The freezer cools the refrigerator, so you actually get very cold air passing from the freezer to the refrig. The air from the freezer enters the refrig on the top and falls to the bottom where it is drawn back into the freezer. The temperature of the refrig is regulated by a thermostat and a fan that runs when the thermostat calls for cooling. If the refrig thermostat is faulty and causes the fan to run more than it should, there will be a freezing problem in the refrig at the bottom because cold air falls and warm air rises. If the refrig is thermostat is calling for cooling constantly, this will take more cold air from the freezer than is normal. Your freezer temp might be higher than normal and the refrig will be colder then desired. If the fan from the freezer is running constantly I would suspect a bad refrig thermostat.
May 06, 2015 | Refrigerators
Compressor vibrates and unit only cools to 20 degrees. tech says it "may" be compressor pressure valve ($1800.00) but no warranty. I cant find any such part listed for True T49-F commercial...
Okay first True uses capillary tube not an expansion valve.
You say the compressor vibrates not cooling ?
If the valves of the compressor are bad, he may mean
internal valves but usually pressures would not be good.
Give a little more detail please.
Apr 26, 2011 | True 49 cu. ft. / 1388 liter Commercial...
Hi, my Kenmore is 10 years old. Refrig isn't cold. Freezer temp is okay. Checked manual to check temp. Doesn't adjust. Now everything spoiled. Does it need new compressor?
heatman101
Aug 31, 2010 | Kenmore Refrigerators
Refrig was clicking on and off now nothing not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 02, 2010 | Frigidaire FRS26H7CS Side by Side...
Refrig cooling
Sounds like the evaporator fan is not working. Check to see if you can hear the fan running in the freezer. If not running, try removing the panel in the back of the inside freezer and manually spin the fan blade . This sometimes works.
Jul 03, 2009 | Refrigerators
Frig no longer cold
Hi, look inside freezer and see if there is a frost build up on the rear wall. Also listen to see if the evapotator fan motor is running.
Please let me know so I can assist you further.
Vic
May 27, 2009 | Frigidaire Freezer Refrigeration White...
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
48 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
