Question about Canon PIXMA iP1200 Photo Printer
I am getting this message when I try to print: The waste ink absorber is full. Contact the service center for the replacement of the waste ink absorber. Is this something I can buy at Office Depot and where is it located on the printer so I can change it out?
    Sergeant:
  • 224 Answers
They are located under the ink when it's in it resting position, you can remove these little sponges with tweezers, when you open the lid the ink will move to the center and be out of the way of doing this.
Posted on Aug 28, 2010
Testimonial: "That was very quick and helpful... If I remove the little sponges, do I need to replace them or will it work without them?"
  • Kelly Aug 28, 2010
    You can clean and reuse them but iy will damage the machine if you don't reinstall them, Just use a cleaning solution that removes ink.
Posted on Aug 29, 2010
SOURCE: error
Service mode reset - but beware resetting the counter without replacing the waste ink absorber may cause ink to overflow out of the printer.
1) With the printer power turned off, while pressing the Resume/Cancel button,
press and hold the Power button. (DO NOT release the buttons.
The LED lights in green to indicate that a function is selectable.) .
2) While holding the Power button, release the Resume/Cancel button. (DO NOT
release the Power button.) .
3) While holding the Power button, press the Resume/Cancel button 2 times, and
then release both the Power and Resume/Cancel buttons.
(Each time the Resume/Cancel button is pressed, the LED lights alternately in
orange and green, starting with orange.) .
4) When the LED lights in green, press the Resume/Cancel button 4 times. (Each
alternately in orange and green, starting with orange.) .
5) Press the Power button. The LED lights in green, and the reset is performed.
(When the operation completes, the printer returns to the
menu selection mode automatically.) .
6) Press the power button to exit service mode.
Note:- if you accidentally press the Resume/Cancel button more than 4 times in
step 4 then just press the Resume/Cancel button at least 10
times and the printer will be returned to step 4 automatically.
BTW the other functions that are available at step 4 are -
press 0 times = power off
press 1 time = Service Test Print
press 2 times = EEPROM information print
press 3 times = EEPROM initialisation
press 5 times = Destination settings (country information, do not play with
this)
press 6 times = Printhead Deep Cleaning
press 7,8 or 9 times = not used in servicing so do not play with these.
press 10 times or more = return to menu (step 4)
Posted on Oct 11, 2008
SOURCE: Waste ink absorber full - contact service center for replacement
STEP 1:
- Disconnect printer from AC power
STEP 2:
- Press and HOLD the POWER button, and
connect printer to AC power
This simple power off procedure worked on my IP1500!
Cleaning the absorber was also easy. Power up with the cover open until the head moves to the left side then disconnect the power cord so the head is now positioned away from the pads.
The two pads can be lifted up easily with a pair of sharp tweezers then rinsed in running water. They will become white again and can be blotted with paper napkins then air dried in a warm location (I used an industrial oven set to 40°C). The wells in the rubber holder can be cleaned with cotton swabs before returning the two pads (left side first, then press down the right side).
Posted on Dec 22, 2008
  • 164 Answers
SOURCE: I have the message: Waste ink absorber is full.
If pineworks solution does not work, you may want to clean the print heads.
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your ip3000 print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
pineworks
  • 4041 Answers
SOURCE: Pixma IP1500 stops
Temporary Fix
This always works in case you need your printer for Emergency ^_^.
  1. Turn off the printer
  2. And unplug the printer power cable
  3. Press and Hold the POWER button
  4. Plug the power cable again
  5. The indicator (LED) should be green
  6. Press and Release the RESUME button, the indicator (L.E.D.) should be orange
  7. Press and Release the RESUME button again, the indicator (L.E.D.) should be green
  8. Release POWER button
  9. Windows will detect new printer and you just have to install it again.
  10. It will create a copy of Canon i320 printer. Just delete the old one and rename the copy.
  11. You are done.
Posted on Feb 13, 2010
  • 11 Answers
SOURCE: The waste ink absorber is full. It won't print
Contact service centre :)
or you can reset the waste ink tank and keep using the machine but it will damage ur printer and may gone permanently..
Posted on Mar 30, 2010
What is e 27 and e 8??
Those two are error codes, and they mean the following:
E8 - The waste ink absorber is almost full. Press the OK button to clear the error.
Printing can be done until the waste ink absorber becomes full. If the waste ink absorber becomes full, please contact your local Service Center for replacement of the absorber and machine maintenance.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc.
E27 - Manual does not specify what this means, but tells you what you should do: Turn the machine off, and remove the power plug from the outlet. About ten minutes later, plug it in again, and turn the machine on. If the problem is not resolved, the machine may require servicing. Please contact your local Service Center.
You can read more about the error codes on Canon website.
Dec 02, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Computer says"Waste ink absorber is
What is the make and model of your printer (I'm guessing it is a Canon?)
May 06, 2008 | Office Equipment & Supplies
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Printer won't print. Says to contact service
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Press the <RESUME/CANCEL> button to clear the error (1700)
Waste ink absorber error 1700
The printer has a built-in waste ink absorber to hold the ink used during print head cleaning. Eight flashes indicates that this absorber is nearly full.
Press the <RESUME/CANCEL> button on the printer to clear the error, so you can continue the print job. The printer will need to be serviced as soon as possible.
Dec 10, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Triangle and ON/OFF switch both flashing. Window reads 'CHECK PRINTER'. What exactly do I check? Window had been reading 'WASTE INK NEARLY FULL' for a fortnight, but I couldn't find out how to deal with...
The waste ink absorber is getting full.
The waste ink absorber is a part inside the machine, which absorbs ink used in the cleaning operations, etc. http://support-nz.canon.co.nz/contents/NZ/EN/8000137103.html
Nov 09, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Its appear " The ink absorber is full. Contact the service center."
Inkjet printers have a fibrous pad inside them that collects the waste ink from cleaning the print head. Over time, this pad fills up with ink and can no longer hold any more. When this occurs, the printer indicates a "waste ink full" error.
Replacing the waste ink absorption pads is something an authorized canon service facility can take care of for you.
May 11, 2009 | Office Equipment & Supplies
Printer says ''waste Ink absorber is full'' see service center
This is what the manual says: Ink used for cleaning is absorbed in a waste ink absorber placed in the machine. Press [OK] to cancel the error so that you can continue printing. Once the waste ink absorber becomes completely full, printing cannot be done until the waste ink absorber is replaced.
Canon recommends to contact a Canon service representative as soon as possible.
Nov 12, 2008 | Canon PIXMA MP150 All-In-One InkJet...
ERROR MESSAGE 2
How do I change the ink cartridge for the Canon Pixma 150
Sep 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon PIXMA iP1200 Photo Printer Logo
113 people viewed this question
old marine
old marine
