Question about Samsung SyncMaster 510N 15" LCD Monitor
Thank Ekse thank from you help and recommendation notice to me.i also think and suspect that main board graphics monitor have problem so i have send to computer shop for repair thanks :-)
  • Samsung Master
  • 13,433 Answers
Anytime :-)
Posted on May 07, 2008
Power light blinking and no pic not even the "no signal", i'm pretty handy around components but still would like to know if it can be fixed .
Hi
Test it with a different power cable and with a different computer or laptop, to definitively isolate the fault.
The power light blinking indicates an internal power management problem.
Monitors, TVs etc. do not have a user repair friendly internal work environment. Even when disconnected from the mains, they contain large numbers of high capacity capacitors which store enough charge to seriously injure or even kill an inexperienced repairer.
Whether you attempt the repair yourself or take it to a technician, any repair will most likely involve replacing the power inversion unit, which will probably be expensive.
Monitors are inexpensive and normally have a long lifetime, so I would recommend buying a new one.
If you do opt to go down the repair route, a repair technician with lots of damaged monitors and monitor parts in stock may have a used component to replace the damaged part.
I hope this helps.
Aug 25, 2011 | Acer V173 b Monitor
Viewsonic vx2835wm monitor, in DVI mode connection, altough getting signal from the PC(Other monitor connected and tested for graphic card problem-No graphics card problem!!) , Prompts "No input-signal"...
You will need to change the resolution of the screen on the computer to 800-600 and the bit to 24bits or 16bits, to do this right click on the windows screen, and click properties, goto settings.
You should see a slider at the bottem left of the screen to adjust the resolution, and a drop down bar on the other side for the bit rate. This should solve the problem, also you could open the scond screen also in the display properties, and drag what you need to see on the screen to that screen, you will know what i mean when you open screen 2 it just expands the desktop. hope this helps.
Aug 21, 2010 | ViewSonic VX2835wm Monitor
My computer is stating no signal
Hey,
The monitor of the computer is not getting a signal from the computers video card.
this can be caused by a faulty video card, or just the computer not starting up properly.
instead of replaceing parts I would recommend you take the computer to a professional or someone knowledgeable in computers to get it fixed.
Let me know if you need anything else.
Thanks,
Ekse
Feb 20, 2009 | Targa Computers & Internet
I have a Dell Dimensions 8300 with a GeForce FX5200 graphics card (version C.14.10.4502).It has D-Sub and DV1 outputs. The monitor is connected to the D-Sub output. However anything connected to the DV1...
Hey,
in windows, right click on your desktop, select properties, then settings and then click on the 2nd monitor, make sure the 2nd monitor is attached to the dvi, when the computer was turned on. so the 2nd monitor will appear in the settings.
this will give image from the dvi output. to get objects to the 2nd monitor drag them out of a corner of the first screen. debending on what side the monitor is at.
Let me know if you need anything elsed.
Thanks,
Ekse
Feb 18, 2009 | XFX NVIDIA GeForce FX5200 Graphic Card
Acer aspire one won't connect to projector
Hey,
On your desktop, right click, select properties.
now go to settings.
do you see screen number 2? select screen number 2 and check that the screen is enabled if not place a check on the checkbox and enable the monitor, now check the resolution and colors adjust them as you see fit, to move objects to the projector display drag them out from your laptop monitor.
Thanks,
Ekse
Jan 27, 2009 | Acer PD523 Multimedia Projector
I need help :)
This is not really my area of expertise. I think you would be better off asking Ekse. He would be able to guide you better in this regard.
Cheers!
ID
Nov 07, 2008 | ATI RADEON X1300 Pro 256MB PCIE Graphic...
Faulty hp en623aa flat screen monitor
my desk top is half display is ok and half display is white light & all program is look a lite
Jul 24, 2008 | Xerox XG-91D 19" LCD Monitor
Help about driver and softwera
which monitor you are using ...?
you mean you need the graphics driver or the monitor driver itself reply clearly i will get you the links...
and also tell me the model of the monitor if it is monitor driver & motherboard details if it is graphics driver ....
i am always here to assist you ..
reply me soon
Apr 07, 2008 | Mitsubishi Diamond Pro 900U 19" CRT...
Toshiba M4 Graphics problems
no. i think your monitor is old. some time we get voilatie or red screen .some time it take short or long time. and some time screen moving. main cause is lose joint part in monitor it can be fixeb by soilding every parts by expert.for conform u change other monitor.then u can get result . thanks
Dec 30, 2007 | Toshiba Tecra M7 Tablet PC
Samsung SyncMaster 510N 15" LCD Monitor Logo
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
