Question about Bosch 1" Sds+ Bulldog Rotary Hammer Drill 11255vsr
Bosch hammerdrill 11222evs the whole chuck assembly came off. how do i put it back on?
4 Suggested Answers
  • 90 Answers
SOURCE: i wanna change th chuck
if you don't have a screw in the spindle inside the chuck it will just unscrew. well, not just, you have to put a very large allen wrench in the chuck and hit it hard to loosen the chuck. doesn't sound right but that is the only way.
Posted on Aug 30, 2010
H2_Brad
  • 425 Answers
SOURCE: how to replace knob assembly on bosh 1 1/8 rotary hammer drill 11222evs
Here is a link to the parts diagram. It shows what position the knob needs to be in the remove it. You also have to push the button in further then normal. I just use a small screwdriver. Once you rotate it further past the last position you will be able to lightly pull up on it while slowly rotating and it will release. It has tabs molded into the plastic knob so it can only come out when they align with the housing it fits into.
Bosch 11222 diagram
Posted on Aug 22, 2012
  • 304 Answers
SOURCE: I,m having trouble getting the chuck off my 13618 bosch 18v hammerdrill. I have removed the screw then chucked a piece of hexed stock into it and reversed a half inch impact to it and it won't bre
Make sure it is in low gear on drill mode. try with just a bar in the socket and hit the end to shock it. This is sometimes better than a constant force.
Posted on Nov 22, 2012
Chuck not gripping drill bit
Most people who having the little bosch rotary hammerdrills do not use lubrication on the chisel.
and the chuck will notwork ing on only the ball because in most case of this the camshaft drive are worn out the locking sleeve.
Apr 11, 2014 | Bosch Drills
Nov 21, 2012 | Bosch 13618 - 2G 18V Brute Tough Cordless...
Need to replace the chuck on a Bosch 1194 VSR Model number 0 601 194 739
open the jaws of the chuck up all the way. There is a retaining screw at the bottom ( under where the drill bit would go). this screw is reverse thread. once the screw is out, get a 3/8 inch allen wrench. chuck the short end into the drill chuck. set the drill on a workbench with the chuck hanging off the edge a bit. Hit down on the allen wrench with a hammer ( counter clockwise) and the chuck will unscrew normal thread.
Oct 21, 2010 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
I wanna change th chuck on my DW505 hammerdrill
Aug 09, 2010 | Dewalt DW505 Electric hammer drills
How to remove bit retainer or chuck from drill
Grasp the chuck and twist the sleeve counter clockwise and pull up.It will come off. To replace the chuck slide it back onto the drill shaft, grasp the chuck collar, twist it counter clockwise and push down on it, it will slid back onto the shaft and lock into place.
Nov 20, 2009 | Bosch 11222EVS 1 1/8" Sds Plus Rotary...
Chuck on Bosch 1194 vsr drill is rusted... how to remove?
you are half right. The screw that you see is a chuck retaining screw (LH thread) to keep the chuck from loosening up when in reverse. What you need to do is if you have one remove it first and then find a bent handle allen wrench about the size of the chuck capacity, lock the shorter end in the jaws and then position the wrench at about a 30 deg angle and put the chuck on a block of wood or bench and take a hammer and hit it counter clockwise. If you have a wrench small enough to lock onto the spindle use it and brace it on the bench. If this tool has a high and low setting use the low and if clutch equipped the drill only. Let me know if you need more help
Jun 26, 2009 | Bosch 1194AVSR 1/2" Vsr Hammerdrill
My rotozip RZ20 keyless chuck will not open.
open the chuck and look in the center there is a screw allen type most times or a star screw in the middle that connects it to the drill shaft just tighten it up should work fine then!
Apr 27, 2009 | Bosch RotoZip RZ05-1100 RZ5 Base kit
Bosch 18volt brute force cordless drill how do i remove chuck
Put the screw back in the chuck, tighten it up then back it out 1 turn. Take a punch, put it in the chuck and give it a quick hit with a hammer. That should do the trick.
Jan 31, 2009 | Bosch 33614-2g 14.4v Brute Tough 1/2"...
REMOVE CHUCK
The only way is with a special chuk key , and is not available to customers, if you still want to replace by yourself, you can by the whole gear case cover assemble that cames with the new chuck, but is is expensive.
Jan 08, 2009 | Dewalt Heavy Duty Xrp 1/2" 18V Cordless...
Bosch 1" Sds+ Bulldog Rotary Hammer Drill 11255vsr Logo
201 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
Tim Venetis
Are you a Bosch Drill Expert? Answer questions, earn points and help others
