Question about Peg Perego IGOR0040 John Deere Turf Tractor with Trailer
I need to remove the rear wheel in order to replace one of the motors. Any idea how to remove the right rear wheel?
    Genius:
  • Peg Perego Master
  • 1,508 Answers
You can do this by popping of the black hub center of one wheel and then use a needle nose pliers and bend the metal push nut in half this should allow you to pull it off and then remove the washer and then the wheel, this should allow you to pull out the axle and wheel from the other side, then you should be able to pull the motor and gear box out
Posted on May 04, 2012
The right rear wheel intermittently locks up on my lawnmower when going forward stopping forward movement temporarily, until I move it backwards to "unlock" it. Any ideas?
There is an excellent 3 part video that may help you to fix this problem. Please see the 2nd and 3rd videos:
https://youtu.be/Vk_tpjKlbjM
https://youtu.be/DdiewLxTQDc
Things you can try:
(1) Remove casing over rear wheel drive assembly and perform a test run to assure all parts are moving as expected
(2) Lubricate the shafts with lightweight motor oil where the shaft penetrates into the gear box of each wheel
(3) Remove each rear wheel, inspect gears for damage and free movement. Grease up each drive gear and the shaft.
(4) Inspect gears on each wheel for damage.
(5) If none of the above fixes the problem, try swapping out the front wheels to the rear wheels provided the front wheels can accommodate the gearing on the rear wheels
(6) If this doesn't work try replacing the small gear assembly on the right rear wheel
These steps are illustrated in the videos.
Good luck and hope this helps.
Oct 11, 2016 | John Deere JA65 Self Propelled Mower
2006 Tahoe. Where is the auxiliary blower motor located?
It is located behind the right rear quarter panel , In the back right of the interior !
Remove the right rear quarter trim panel. Refer to Rear Quarter Trim Panel Replacement - Right Side in Interior Trim.
Removal Procedure
  1. Remove the rear seat. Refer to Rear Number 2 Seat Replacement or Rear Number 2 50-50 Seat Replacement in Seats.
  2. Remove the Third Pillar trim panel. Refer to Third Pillar Trim Replacement .
  3. Remove the garnish molding. Refer to Body Rear Corner Garnish Molding Replacement .
  4. Remove the door sill plate. Refer to Liftgate Door Sill Plate Replacement .
  5. Remove the quarter panel trim screws.
A lot involved in this but not to difficult !
  1. Remove the rear door sill trim plate. Refer to Front Side Door Sill Plate Replacement or to Rear Side Door Sill Plate Replacement .
  2. Remove the lower rear seat belt cover and bolt.
  3. Remove the trim panel from the vehicle.
Remove the sill plate. Firmly pull the sill plate up and out from the retainers.
Remove the sill plate from the vehicle. Start from the front of the door sill. Use a flat-bladed tool in order to pry the door sill plate.
Rear Side Door Sill Trim Plate Replacement
Use a flat-bladed tool in order to pry the door sill plate. Remove the sill plate from the vehicle.
Remove the rear upper garnish molding. Refer to Rear Upper Garnish Molding Replacement .
Pull down on the upper corners of the garnish molding in order to disengage the retaining clips. Pull in order to disengage the remaining retaining clips. Remove the rear corner garnish molding from the vehicle. Inspect the rear corner garnish molding for broken or missing retaining clips. Replace the retaining clips as needed.
Good Luck ! Fun job !!!!!
Jun 07, 2015 | 2006 Chevrolet Tahoe
How to replace the blower motor in 73 ford ltd
By now the blower motor should have been replaced a few times so hopefully it will be less hard. Disconnect the orange power wire at the rear of the right hood hinge and the black ground from the upper cowl. Remove the right front tire and wheel assembly. There should be an access panel in the fender. Remove it and you should see your blower motor. Remove the 4 motor mounting screws and disconnect the cooler tube from the motor. slide the motor and wheel assemby out the acess hole.
Hope this helps.
Jan 19, 2014 | Ford LTD Cars & Trucks
Removal of rear wheel on Suzuki VL800 to repair puncture
In order to remove the rear wheel assembly, you are going to need a motorcycle lifting jack stand or similar device.
1. Stand the bike on the side stand
On the left side of the rear wheel:
2. Remove the 2 froward facing bolts.
3. Remove the allen head bolt with the wide head.
On the right side of the rear wheel:
4. Remove the brake adjuster nut on the end of the actuating lever.
5. Remove the Toque link nut at the bottom of the wheel assembly.
6. Remove the axle nut (castle nut and cotter pin).
7. Place the motorcycle jack under the swing arm or chassis tubes to stabilize the rear end.
8. Remove the axle.
9. Remove the axle from the splined drive gear and place the wheel assembly on the ground.
10. Pull the wheel assembly rearward.
Reverse the process to replace the wheel.
Jan 03, 2011 | Suzuki VL 800 Volusia Motorcycles
Removal of rear wheel to repair puncture
8. Remove the axle.
Jan 03, 2011 | 2001 Suzuki VL 800 Volusia
I have obtained a new motor for the rear passenger side wheel but am having trouble getting to the screws behind the rear wheel. How do I remove the wheel so that I can install the rear motor? ...
I had this same problem, but eventually figured it out.
The wheel comes off by removing the little black piece in the center of the yellow hubcap. There are a couple of snap tabs in this black piece, but it comes out well enough. You'll see the end of a metal rod going through the center of the wheels. Remove the star-looking washer and pull the wheel off. The other wheel will now come out as well, taking the rod with it.
Behind the wheel, you'll see 2 screws that hold the motor assembly in place. You'll also need to remove the seat and black cover to access the motor assembly.
Good luck.
Sep 07, 2010 | Peg Perego John Deere Turf Tractor
What is the proper procedure to remove the rear wheel from the 2002 Intruder 800 without damage to the driveline?
2. Remove the two forward facing bolts.
7. Place the motorcycle jack under the swing arm or chassis tubes to stabilize the rear end. Lift the motorcycle until the rear tire is just off the ground.
8. Remove the axle.
9. Remove the wheel from the splined drive gear and place the wheel assembly on the ground.
Sep 03, 2010 | Suzuki VS 800 Intruder Motorcycles
I've taken the seat off, completely exposing the two motors on my son's john deere turf tractor (12v). i need to replace one of the motors. how do i remove it after i've disconnected the wires?
you have to remove the center cap from one of the wheels then remove the metal push nut, this will allow you to slide the wheel and rear axle off, then you have to remove the two screws that hold the motor and gear box in place, then you can take out the motor gearbox assembly, then there two screws to remove the motor from the gearbox, then do them in the opposite order to put it back together
Sep 02, 2010 | Peg Perego John Deere Turf Tractor
Rear wheel removal
8. Remove the axle.
Aug 10, 2010 | 2003 Suzuki VL 800 Volusia
Peg Perego IGOR0040 John Deere Turf Tractor with Trailer Logo
284 people viewed this question
Top Peg Perego Toys Experts
Adam Fjeld
Adam Fjeld
Gary
Gary
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
