Question about HP Deskjet D2660 All-In-One InkJet Color Printer
I don't know how to reset ink level on hp deskjet d2660 printer. please help me......
SOURCE: Can't find ink levels on my printer
I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
Posted on Sep 02, 2008
  • 320 Answers
SOURCE: HP Deskjet F4280 Ink Level
when you refill the cardtridge, you can not reset the ink level... because refilling doesn't show the ink levels.. you no need to worry. if ink is there in the carttridge it will print...
Shouldn't worry about it. They are only a rough guide. The only time to worry about it is when the printer stops working and it has told you it's run out of ink! Thank you.......
Posted on Jan 29, 2009
aicaxz
  • 511 Answers
SOURCE: I used to refill the ink cartridge of HP Deskjet D1460 by injecting ink. The problem is the level of ink is not resetted to full level, its still very low level. However, the printer prints normally
Close the top left pin at head contactor (1 pin only), with tape. Plug it in head carriage. Unplug it. Close to top rigtht with tape too. Plug the head. Unplug head. Remove all the tape cleanly. Plug again. See ink monitor.
Posted on May 31, 2009
bob_computer
  • 3153 Answers
SOURCE: How do I reset the ink levels on a HP Deskjet
First try the information below
Check that you removed the protective tape. some cartridges have two of these pieces of tape one over the head and possibly on on the contacts to the printer.
If you recently re-filled or had the cartridge refilled or even bought one of the many cheaper replacement cartridges you should read on
Most modern cartridges have an ink level chip built on to them.
Should the level drop below 25% then most of these chips lock up and will not reset.
Re-filling them will have no effect
If you are lucky you should be able to find either a chip resetter around on the INTERNET or maybe even local
OR
Even better empty cartridges that never need to be reset.
The second option is my preference
I realise these are not for your specific printer but there are others listed on both those sites as well.
cheaper cartridge problems have been on the rise recently and that is for ALL makes of printer.
Posted on Sep 07, 2009
SOURCE: I can't reset ink level indicator for HP Deskjet F4280
AFTER REFILL PRINTER STAY IN ERROR CARTRIDGE BLINKING
Posted on Jan 28, 2010
RESET HP DESKJET D2660 FREE
Try installing the latest printer driver.
You can download the HP printer drivers from their support WEB site. Please click on this link and select your model printer to download :- http://welcome.hp.com/country/us/en/support.html
Aug 27, 2012 | HP Deskjet D2660 All-In-One InkJet Color...
I WANT TO INSTALL MY HP DESKJET D2660 PRINTER IN MY COMPUTER
Hi luissdomingo,
To Install your HP DESKJET D2660 PRINTER,
Insert the driver (disc), then click run. its automatically install, then once have prompt Finish, just click then you can now use your HP DESKJET D2660 PRINTER.
If you dont have HP printer drivers from their supportWEB site. Please click on this link and
select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
Hope this helps.
Thank you for using Fixya.
Sep 07, 2011 | HP Office Equipment & Supplies
Catridge problem model D2660: "blink' lamp
Hi Friend, Do you know that behind every problem, there is always a solution. So therefore, I have quick, easy and real solutions to your Printer Problem. Just click here for you Solutions.
Dec 09, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
Why stil show empty after installation of refilled ink cartridge
As you were using a refilled ink cartridge, it needs to be reset. When you refill your cartridge, it will read as low or empty when you try to print with the cartridge.
There was a embedded serial number in the contact strip located on the back of the cartridge and your printer remembers that serial number and gives the message of low or out of ink. The internal memory is located in the printers firmware and is not in the software. It will remember the previous two cartridges ink level.
On this matter I need the exact model of your HP printer so I can assist you more further on this.
Let me know from you again here soon. Just leave a message and I will attend you ASAP.
Thank you for using fixya.
Jun 22, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
Hii need to reset the hp deskjet 680c printer.i don`t know how to do this. thanks for you attention. regards.
h10032.www1.hp.com/ctg/Manual/c00256077.pdf -
Above is your user manual.
Turn off your HP DeskJet printer. Turn it back on and connect it to your computer using the USB cable.
To reset the INK Counter, see below.
Click open the "Start" menu on your computer. Click on "Control Panel," and double-click "Printer and Faxes."
Locate the icon of your HP DeskJet Printer along with its model number. Right-click this icon and click on "Properties" from the pop-up list.
Click the "Services" tab and select "Service This Device."
Select the "Estimated Ink Level" tab. Click the option "Reset Ink Level." The printer will then show a refreshed ink cartridge level for your printer.
To reset all settings and print test page. see below.
* Press and hold the Power button.
* While holding the Power button, press and release the Resume button four (4) times.
* Release the Power button. A self-test page will print.
Jun 17, 2010 | HP DeskJet 680c InkJet Printer
I need to reinstall my hp d2660 printer but i lost the cd, how do i install it without? or can i?
hi,
The drivers can be found on the web from multiple locations.
I would recommend you genuine drivers by going on the HP website only. You would be required to choose the operating system and then youcan proceed with driver download.
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=3742936&lang=en&
Please let me know if the provided information has been helpful.
Please rate me if the information provided was able to help you.
Jan 06, 2010 | HP Deskjet D2660 All-In-One InkJet Color...
Deskjet f4185 reset ink level...
for colored is only 3ml and the black is 8ml
Aug 03, 2008 | HP Deskjet F4180 All-in-One InkJet Printer
HP Deskjet D2660 All-In-One InkJet Color Printer Logo
1,367 people viewed this question
Seeker5211
Seeker5211
