Question about GE Refrigerators
MY Fridge stopped making ice, then the too warm light came on. I have a digital thermometer in the fridge and freezer. Freezer fluctuates between 16 and 23 degrees, most often staying around 22. Fridge 34-38. I don't hear any noises and compressor seems to cycle properly. I have cleaned the condenser? Thank you.
  • gburg1 Aug 28, 2010
    I don't believe you understood my problem. I understand that the freezer should be about 0 degrees? I feel that the no ice problem is a result of freezer not being cold enough? All temp settings are at 9 which is the coldest.
    I feel that the freezer is not cold enough to produce ice. All settings are at the highest setting. The condenser has been cleaned and no noses are heard. Freezer 18-24 degrees, fridge 34-38 degrees.
    President:
  • 1,197 Answers
Almost all refrigerators use a capillary tube system. This means that they are crically charged with freon. This basically means that evrything must be in in perfect balance on teh system for the unit to function properly.
The only thing that a consumer can really do to insure the unit to run properly is to keep the condenser coil clean. Clean it at least two or three times a year!!!!!! The condenser coil is a natural collector of particles from the air. There is nothing you can do to prevent this from happening. So, ge tin there and clean it every few months. All it takes is a brush and a vacuum cleaner or shop vac.
If this does not clear up the problem, you may have to consult a prefessional for help.
Check to see if the defrost timer is operating properly. If it is not, the evaporator can form a block of ice all the way around it. This hinders heat transfer from the freezer and, you guessed it, keep the food from freezing in the freezer.
This requires a complete overhaul of the refrigerator system ...including a new freon charge ...or possibly a new capillary tube. If the compressor oil has boiled (because of excess heat), particulates coming off the boiling oil get pumped into the system and will clog the capillary tube.
If the your compressor is still running as you say it is, you may be all right by rectifying one of the two previously explained issues. If it does not , then call a professional to fix it
Most combination units have the cooling located in the freezer compartment and use a fan to 'stir' the cold air and distribute it to the refrigerator compartment. If this fan fails, then the fridge no longer gets fed any cooled air or at least very little.
With the compressor running, hold a couple of wet fingers near the vents in the fridge that are located in the back and top. If you don't find a fairly good stream of cold air coming oout of the vents, then the fan is definitely bad.
These fans have only sleeve bearings of sintered bronze with graphite embedded in them. They can build up enough loose graphite to jam the motor shaft so the fan cannot turn any more. Sometimes, if the bearing is not too worn, you can work WD-40 or similar into them by spraying while turning the fan with a finger (power off, of course!). The WD-40 should be used to wash out the graphite from the bearing, don't expect it to really lubricate, it is a good solvent but evaporates pretty quickly. Once the fan turns easily, grasp one or more blades and move it left or right, up or down, to feel if the bearing has now too much play. If it does, replace the fan, they aren't expensive (that's why they fail).
Posted on Aug 28, 2010
    Brigadier General:
  • 3,513 Answers
Refrigerator cooling defrost freezer
Buy a freezer thermometer from any supermarket, it has a guide.
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Nov 20, 2013 | Kolpak SK8-818-CI
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
I have a GE mdl PSI23SGRCSV side by side. initially the digital temp displays for both freezer and fridge sides went to 16 on freezer side and 43 on fridge side. This happened almost overnight it seemed....
it may be that your fridge is now low on freon the techs now do not know what to do the best thing to do is to call the tech and ask them to test the compressor pressures and see if it is low on charge. unless you know how to take the lower back panel off (the one that is probably cardboard) and feel the lines on the compressor and see if it is really cold and really hot that means that it is cooling properly but if it feels a little warm cominv out of the cooling side and hot on the return side then you need more freon.
Mar 04, 2011 | Refrigerators
My refridgerator freezes the milk, How do i stop it from doing that? The temperature setting is in the normal range and the condensor coil is clean.
There are two setting on a fridge. One that sets the temp of the freezer and one that adjusts the temp of the fridge part. The fridge setting just adjusts the opening between the freezer and the fridge. So the fridge gets it's cool by stealing a little from the freezer. i'd get a fridge thermometer and set it it the fridge and see what the temp really is. The knobs in the fridge may not be accurate. Set the fridge and then move the thermometer over to the freezer and set that. Move back and forth until you get what you want. Usually the lower part of the fridge is a little colder then the top. However if you use the fridge a lot then every time you open the door the cold falls out and the fan will come on and start taking cold from the freezer. Another very cold spot is next to the vent where the cold air comes out from the freezer. Usually up top near the ice maker.
Sep 22, 2010 | Samsung RB215LASH
My Maytag fridge is not working, but my freezer works fine. What do I do? The freezer is on the bottom, with the fridge being on top
Hi
Do you have any ice cream in the freezer? If it is soft than the freezer is also too warm. If you do not have icecream then you will need a thermometer to check freezer temps. Freezer needs to be 10 degrees F or colder down to -10. fridge should be 34-38... Sometimes freezer temps can seem cooler than they are with out a thermometer to test it. Also look for frosting up inside the freezer. Check that your door seals are in good condition. check that doors are closing completely.
Please let me know If I can help further.
Apr 14, 2010 | Maytag MBF2556HEW / MBF2556HEB /...
Intermittent freezing and fridge warm
The ice builds up in the freezer compartment because the defrost cycle is not working. Check the timer , the defrost elements the defrost thermodise.
God Bless.
Jul 07, 2009 | Freezers
My fridge won't cool down or freeze
Your condenser is likely dirty clean it. the compressor could be tripped out on over load (to hot) unplug the fridge a couple hours should do it . plug it back in make sure the thermostat is on and set correctly if that does not work you will need service. Tom
Jun 17, 2009 | LG LFD25860
Freezer stopped making ice two days ago. Today fridge and freezer warm
Check the defrost timer. Rotate the dial on it to see if anything changes.
May 04, 2009 | Freezers
Refrigerator in garage
Yes it is very possible that exactly what you are describing can be happening. Also try a thermometer frozen in a cup of water to get more accurate temps. Also 33 in the fridge is very normal for the cold control set on max and the heater installed. Let me know the temps in the frz with the thermometer sensing product temp not air temp which fluctuates often.
Dec 22, 2007 | Frigidaire FRT21P5A Top Freezer...
Refrigerators Logo
181 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
