Question about ASUS K8V-VM (K8V-VM GREEN) Motherboard
I have re-installed the windows XP home edition on my ASUS K8V-VM ACPI BIOS Revision, after re-formatting the C disk (which had lost its partition). Everything is OK except that the sound does not work (on the board there is Realtek ALC 6 channel CODEC). I can not find on the WEB, for free downloading, the necessary driver. What can I do? Thanking in advance Cornel
  • corneliupope Aug 28, 2010
    The site address did not work
    Guru:
  • 266 Answers
You can download the sound driver from <a rel='nofollow' href="http://www.ziddu.com/download/11417644/AsusK8V-VMaudioforwindowsxp.zip.html" class="normal12blue"><b>http://www.ziddu.com/download/11417644/AsusK8V-VMaudioforwindowsxp.zip.html</b></a>
Posted on Aug 28, 2010
  • abdul vahid lakkal Aug 28, 2010
    you need to copyhttp://www.ziddu.com/download/11417644/A... and paste it to the address bar of internet explorer.you will get download link
Sir i want asus k8v vm grafich controll drivers
The drivers for this board can be found here:
http://support.asus.com/download/download.aspx
Select: Motherboard
Select: Socket 939
Select: A8V-VM SE
Select your OS (XP)
The first driver you need to install is the CHIPSET Driver VIA ChipSet HyperionPro Driver V507 for Windows 2000/XP/XP 64bit. (WHQL)This is located under "Others (2)" in the list.
Install the Chipset driver first and reboot
Hope that helps
Sep 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I m having asus k8v-vm bt no space for sound card
The Asus K8V-VM motherboard has an intergrated audio chip on the motherboard, Realtek ALC660. You need to enable it in the bios. If you do not have you're manual down load it from Asus; http://www.asus.com/Search.aspx?SearchKey=K8V-VM You'll also need Adobe reader installed to view the manual. Enter the bios menu. Open Advanced. See the top of page
2-21 in the manual. Set, High definition Audio to [Auto] Save and exit the bios. Also check out page 1-19. You can install the driver software from the Asus CD or download it from the Asus link provided above.
Realtek Audio Driver V5.10.0.5211 for Windows 2000/XP/XP 64bit. (WHQL)
Cheers'
Mike
Jan 10, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
I have asus K8V-vm and i installed vista home premium which is working very well but when i try to install any kind of games or any software it do not support it.What should i do!
switch to xp pro sp2..
i guess ur using ram over 1gb..(though it may support upto 2gb ddr1 400/pc3200 fsb probably)!!
replace it with a standby n check..it may b a faulty ram..
make sure ur system clock speed is matching..
if ur using more than 1 ram, both must b of the same frequency..(eg 400fsb+400fsb / pc3200+pc3200 [correct]; 400fsb+333fsb [wrong])..
check if ur hdd is working fine and without any humming or oscillating noise..
also go for a bios update frm: http://support.asus.com/download/download_item.aspx?product=1&model=K8V-VM%20Ultra ....
..if ur not professional, do contact ur system admin/vendor....
Oct 26, 2009 | ASUS K8V-VM Motherboard
BIOS issue or ? Rebooting PC into BIOS on ASUS A7V8X-X ACPI BIOS Revision 1003, 13.2.2003
If you lose time and day, means the little battery on your motherboard is done. Get a new one, replace it, should be fine then. As far as booting into BIOS, there should be a boot option, and you can boot into a hard disk, a usb or a cd rom drive. Of course in this case, choose the hard disk that has your operation system on it.
May 30, 2009 | ASUS Computers & Internet
Motherboard drivers
Here is the website but I would check the model number. I could not find it.
http://support.asus.com/download/download.aspx?SLanguage=en-us
Jan 06, 2009 | ASUS K8V-MX Motherboard
I need to install drivers on an old HDD for an Asus K8V mobo.
Hi gordonal123, installing drivers through safe mode is not recommended. If you want windows to function correctly than do a fresh install of windows. Over writing the Gateway hdd will cause you more grief. Windows registry will go nuts.
Link to download the Asus K8V drivers.
Here is what you need to do. Boot to your windows CD while using the Gateway system & hdd. Create a new partition within the free space of the Gateway hdd. (Follow windows onscreen instructions to create a new partition within the free space of hdd). (This will maintain the current windows function).
Restart windows when finished. Windows will create a second partition on the Gateway drive. Go to the Asus link above & download all the drivers for the K8V MB, onto the second partition of the Gateway hdd. Once downloaded & uncompressed into their own folders you can than boot to the windows CD & format the primary partition & install windows fresh onto the formatted partition. When finished you can install the K8V driver still located on the secondary partition. Copy & past these driver folders to your primary partition. Than use windows disk management software to erase / delete the secondary partition. (diskmgmt.msc).
When finished you'll have all the drivers for the K8V MB, no need to buy a PCI LAN card & more importantly a fully functioning windows with-out issues.
Good luck gordonal123!
Take your time.
Mike
Dec 30, 2008 | ASUS Computers & Internet
Asus k8v-vm mother board drivers
boot block compatible version ver 003
bad bios checksum, start recovery
is alone window seen in my computer
Dec 26, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
Asus k8v-vm motherboard rebooting problem
this is your bios battery put new one in and it should work
Nov 18, 2008 | ASUSTeK P5K Desktop Board - Core 2 Extreme...
Mb driver installation problem
i down loaded drievers please help me.
Aug 06, 2008 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
ASUS K8V-VM (K8V-VM GREEN) Motherboard Logo
109 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
