I have CD-RW Rom but the Nero software disk that came with it will not download to my computer.
    Problem Solver:
  • 5 Answers
First of all you check the version of your computer, if it is able to support for latest veriosn computer, then took latest nero software from your friend or to market and then install it. I think your have been solved now.
Posted on May 07, 2008
DRIVERS FOR NERO BURNING ROM
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver
if you physically unplug your cd/dvd restart your computer the plug it back in the found new hardware wizard should activate
if you dont have motherboard disk you will need to download the drivers
http://download.cnet.com/dvdram-en-20071009085435-zip/3000-2110_4-172943.html
http://download.cnet.com/dvdram-en-20070907111350-zip/3000-2110_4-170034.html
http://download.cnet.com/dvdram-win2k-5025-en/3000-2110_4-172950.html
http://download.cnet.com/adaptec-udf-reader-driver/3000-2100_4-10021086.html
Adaptec's UDF Reader enables MultiRead CD-ROM drives to read UDF-formatted CD-R and CD-RW discs (such as those written with DirectCD) under Windows 95/98/98SE/NT 4.0/2000.
hope this helps
Sep 15, 2012 | LG GH22NP21 DVD-Writer - Internal...
I have bought a BTC extrenal disk drive USB 2.0 CD-RW 52x24x52x. My computer is regestering that it is in the usb port but it will not read any disks. I have an Acer travel mate 2300 laptop
A BTC CD-RW drive is compatible with Windows 95/98/NT/ME/2000/XP and it can read and write under Windows 95/98/NT/ME/2000/XP.
Under DOS, the drive can read CDs only.
The quality of CD-R/RW media varies from different brands. A CD-R/RW media with bad quality causes writing error and makes a CD-ROM drive difficult to read.
Please check if the disc has deep scratches, fingerprints, or other contaminants on the discs surface. Clean the disc if it is necessary.
1. Use the burning software which is provided by original supplier and bundled with this CD-RW drive or download the update file from internet. 2. More capacity of hard disk is needed if using hard disk as temporary buffer. 3. Place the disc correctly. 4. The blank disc needs full format first if using Packing Writing software.
Software such as; EasyCD Creator, Nero-Burning ROM, NTI CDMaker are the only supported.
Flash firmware for Windows mode: 1. Please download the appropriate driver file you need from this page. 2. Run the flash program under Windows. 3. Click on the ¡uUpgrade¡vbutton under the flash program 4. ¡uStatus Upgrading¡vis starting to flash the F/W 5. After flashing, the system will appear ¡uComplete¡IPlease restart your computer¡v, then, restart your computer to finish the flash procedure. Note: 1. BTC do not recommend you to upgrade your F/W, if the drive is working properly and does not encounter any irreclaimable problem issues. 2. BTC is not responsible for any defective reasons if the upgrading process caused the issue. Firmware for windows:V000F.exe
Dec 01, 2010 | Computers & Internet
I have a pacific digital cd rw model#u-30147=rv3 but no device driver disk..help please.
No need of Device driver. You actually need Burning software for example nero burning or some one other as you like.
Sep 23, 2010 | Pacific Digital (U-30106) CD-RW Burner
What did I do wrong? I copied doc files to a CD.
Is it a dvd-rom, dvd-rw, cd-rom, cd-rw?
What is the cd/dvd disk drive you are using?
(A dvd-rom, dvd-rw, cd-rom, cd-rw?)
This may be the problem.
Aug 22, 2009 | Compaq Computers & Internet
In CD Easy Write Reader
if this problem apperared then how much time spent you by use your cd/dvd rw i give you one suggest if you have cd writer+dvd rom then buy a dvd writer it can works or if you have already a dvd writer then check your region settings for check region settings go to my computer properties and after open properties. Go to Hardware then go to device manager and then go to properties of your drive then select the nation where you live then try it can work i think
Nov 01, 2008 | Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo...
Sony CRX320EE combo drive not reading data disks
Reinstall nero and search google for removing nero scout
Robert
please rate the solution.
Sep 02, 2008 | Sony CRX320EE-88B CD-RW/DVD-ROM Combo...
Samsung sh-s182 not read cd and dvd
Might be stupid Q, but was there a readable disk in the dvd drive already ?
It sounds like a software issues. What OS are you running ?
May 09, 2008 | Samsung SH-S182D DVD RW Dual Layer Burner
Sony CRX300E CD-RW/DVD-ROM Combo - DVD doesn't read
do you have software/program that supports DVD.
Try a different DVD/Movie/Disk or alternative.
Also install a program, such as Nero which will give you physical characteristics of the drive.
Finally go to device manager, and remove or uninstall the device, reboot the computer and setup again. This can sometimes remedy the problem.
ensure that the drive is set as Master/Slave. if on the same Bus/IDE channel as a hard-drive. set as master/slave opposite to what the hard-drive is setup as.
Hope this helps.
Mike @ Compurepair.
Feb 24, 2008 | Sony (crx300e) CD-RW/DVD-ROM (Combo)...
Why display "disk full" or "Wrong disk" and the disk is new
Try to used Nero, application that will help your driver execute the appropriate task to execute.
Please rate me SOLVED
Nov 19, 2007 | Teac (CDW552GA02) (CDW552GA02/10PK)...
Computers & Internet Logo
24 people viewed this question
David Payne
David Payne
