Question about Whirlpool LER4634J Electric Dryer
I washed, then dried a rug that instructs to "air dry." (Now I see the instructions for proper care...) I have A LOT of little rubbery pieces in the dryer and I have a fear of setting the dryer on fire if I use it. I have vacuumed, cleaned everything reachable. Is it okay to use it? (Yes, I have turned it on and had a burnt rubber smell.)
    Novelist:
  • 172 Answers
Also get a long skinny brush made for dryers or fridge coils, and (with the dryer off) run this down the lint filter slot. Also inspect your dryer duct, and brush that out if needed.
Posted on Aug 29, 2010
  • 1,305 Answers
Even tho you've cleaned out the lint trap and the drum, small pieces of your rug have most likely passed by the filter, or thru the seam where the drum meets the front and rear panels. I would recommend pulling off the front cover, and vacuuming out the "innards" of your dryer. That way you can be confident that you're good to go. You can also remove the lint filter and with a vacuum edging tool **** out any visible "chunks" in the duct. Let me know if you need assistance opening up your dryer.
Posted on Aug 28, 2010
Testimonial: "Thank you!!"
I need instruction book for American Home 5 tray food dehydrator
Dehydrating is a process, so any of these should be OK for you.
[PDF]Dehydrator Manual - Nesco www.nesco.com/files/pdf/fd39_manual.pdf
  1. Cached
  2. Similar
Your Nesco®/American Harvest® dehydrator will provide both satisfying and .... to operate properly, the base tray is included as one of your 5 trays. (You may expand .... houses. Sulfating isn't recommended for use if individuals are on restricted sodium diets or ...... Eat dehydrated foods dry or rehydrate for use in recipes.
[PDF]5-Tray Food Dehydrator Manual - Ronco
https://www.ronco.com/media/wysiwyg/pdfs/5-tray-food-dehydrator.pdf
  1. Cached
Food Dehydrator. 5-Tray. White .... period of time in all the fun recipes and crafts presented in this manual or ... best part about it though is, home dehydration saves a lot of ...... their sea voyages, Pilgrims found Native Americans drying food ...
[PDF]tc-food-dehydrator-manual - Koolatron
www.koolatron.com/manuals/tc%20food%20dehydrator%20manual.pdf
  1. Cached
  2. Similar
With proper care, your Total Chef Food Dehydrator is designed to provide years of use. ... 5. Unplug from wall outlet when not in use and before cleaning. Allow to cool ... North America ... you can create by drying fruits and vegetables at home. ..... 5. Trays may be fully loaded, if desired, with pieces barely touching but not.
instruction book for American Home 5 tray food dehydrator Google Search
Oct 03, 2016 | Kitchen Appliances - Others
Tip
THANK YOU !!!!! and thanks to my 15 yr mechanically inclined son...he did do...
This advice is for Kenmore Elite and Whirlpool Duet model FRONT LOADERS displaying the “F02” error code.
“F02” is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a “SUDS” error may also be generated as a secondary error. This is an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
  1. Check the drain hose to make sure it is not kinked or clogged.
  2. Check the electrical connections to the pump and ensure the pump is running.
  3. Remove the drain pump filter and check for foreign objects and/or debris.
To check the drain pump, click on the following link for step-by-step instructions.
http://www.fixya.com/support/r385844-checking_drain_pump_kenmore_elite_front
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
on Aug 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Easy and correct wash dry instructions
Just as I suspected, this is made out of synthetic materials. [main body] Invista Lycra, [compression] PWX FLEX, [panels] Powermesh
I suggest that you set it on "hand wash" setting on your washer. If that is not available, use "Delicate" or "Gentle" cycle. If you don't have a washing machine, best thing to do is hand wash it. Fill a clean sink with water, add a little bit of gentle detergent (many different brands are available and labeled as "gentle care". I use Seventh Generation, which can be bought at regular grocery stores and even Target!
And then hang dry it. Dryers ruin clothing especially manmade materials. I typically hang something at night and it is dry by the morning. Also recommend hanging your top in the bathroom as the enclosed area has a greater deal of circulation/ air flow than other areas of the house.
Seventh Generation
Nov 24, 2015 | 2XU Mens Black Short Sleeve Compression...
How should I properly care for the cover of my HAGALUND sofa-bed from Ikea?
According to the manufacturers website the care instructions are to wash in the machine at 60 degrees Celsius, separately, and iron dry on a high temperature.
Aug 16, 2012 | Furniture
How should I properly wash and care for my new KARLSTAD sectional sofa from Ikea?
According to the manufacturing notes about care instructions they suggest removing the cover and machine washing in hot water (140F). Do not tumble dry and iron at a high temperature.
Aug 14, 2012 | Furniture
I lost my instruction manuel and i dont know how to put oil in the airfilter
pop air filter of.Carefull not to let anything get down into engine. Remove sponge. If theres 2 sponges then you need to coat the inner sponge. pour a little onto sponge and squeeze so it gets into all the holes. give it the sponge a good last squeeze holding over jar to get rid of excess as this will prevent air from entering engine. Fit air filter back on. Good idea to have a few spare so when one is used others can be washed and dryed. Either wash in wasing up liquid and dryed or nitro fuel and dryed.Hope this helps.
Aug 06, 2010 | Tornado 110 Nitro 4wd 2 Spd Off Road S30...
Drying problems with hotpoint wdl 540p washer dryer
As it is a new washer, your best course of action is to the Hotpoint web site.
www.hotpopint.co.uk
then click on : after sales, for product advice.
Please leave a rating for my suggested solution.
Thanks.
Feb 17, 2009 | Hotpoint Aquarius WD640 Front Load...
Rugs won't dry
just air dry your rugs instead.
Jun 22, 2008 | Bosch Washing Machines
Whirlpool LER4634J Electric Dryer Logo
192 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
