Computer won't turn on
I can't get my computer to boot up. It keeps freezing and rebooting before I can get into my profile, sometimes I can't get that far. I was able to finally get into it via Safe Mode and then pulled all my really important docs off. All my email is still on there and I'd like to get it back. I checked to see if it needed to be defragged but it didn't and I ran check disk for 2 hours but no problems.
So, based upon that little bit of info, any clues as to what it could be? The computer was purchased on 12/30/04 so it’s 3 ½ years old. Micro Center special: PowerSpec 8344, 256MB RAM (I think I doubled this but can’t remember), 2.8GHz, 80GB HD (less than 1/2 full), running XP professional edition sp2.
Any wisdom you can share would be most appreciated. Thank you.
David
  • dbuff May 14, 2008
    Thanks for the info. My hard drive was bad so I replaced it and added more ram to my existing 512MB. Thanks for the suggestions.
    Master:
  • 474 Answers
Sounds like it may be a heating problem but if its doing it even after its barely been on a few minutes, then it could be a hardware issue. If you can boot in safe mode then try the basics.
First, power it off, remove and re-insert all the hardware I .E. the memory and the video card and any other PCI installed devices. Also try resetting the bios. unplug the machine and pop off the watch battery thats on the systems mainboard, wait a minute and then put it back in and plug it in and turn it on.
Also try booting in safe mode and checking the device manager for hardware errors.
try to back up all your stuff and try doing a System restore to a time before you started having the issues.
Also, WINXP uses about 512MB of ram just for the operating system, i suggest 768MB or more.
As a last resort, re-install windows.
Posted on May 07, 2008
My dell inspiron 530s is booting up but then when I try to access the control panel it freezes up and won't let me do anything. It also does not let me access any of my programs. I try to work with it...
your profile is damaged you could try logging in using another profile or restart your computerDuring the boot process you will see on the screen to press delete to enter setup
Press and hold delete during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart another option
restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer you could select the option start at last known configuration that worked this will tell you if and what file has been corrupted or missing then you will know if its a hardware issue then select restart if the problem still persists f8 back into safe mode you might need to select your operating system to load into safe mode click start control panel administration tools computer management in the left panel events + to expand then system you will see all errors in right panel right click select properties this will tell you what has occurred and the time it occurred you might use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option
hope this helps you
Aug 05, 2011 | Computers & Internet
My computer keeps freezing when I run video
A possible RAM issue; having problem you applications
Mar 14, 2010 | Gateway 816GM PC Desktop
POWERS UP BUT THEN FREEZES AFTER ABOUT 4 MINUTES
Need to test and isolate where it exactly freezes? After dell logo, after windows logo or while inside windows? Now, if it only freezes inside windows try to turn off your windows updates and antivirus first and check if still freezes, if yes then try booting in safe mode, reboot system then keep tapping on f8 once dell logo appears. Check if laptop keeps freezing in safe mode. Please let me know.
Oct 01, 2009 | Dell LATITUDE C600 PIII 750MHZ 128MB 15GB...
Emachines w2828 keeps shutting down reboot/Screen Freeze
I dont thing this is a virus problem but a heat problem. if you dont mind getting inside the box see how clean it is and put your hand on the power box case .. then unplug all the hardware except the mother board then turn the unit on, if it goes on then plug 1 hardware at a time.
Sep 04, 2009 | E-Machines eMachines Desktop PC
Compaq desktop freezes on me when am working
check the viruses in your system why freeze that... if the same problem after that try to reinstall the os
check another parts
Jun 07, 2009 | Computers & Internet
COMPUTER WILL NOT BOOT
This does not sound like a power supply issuse
Try This:
tap F8 while booting the PC
This should take you to the Advanced Boot option window
Use you up & down keys: Safe mode With Command propmts(Enter)
Operating System (Enter)
Sign in under your user name( or owner)
once at a command prompt (Black Screen)
Tyoe chkdsk /r (Enter)
You will get a message ( This valume is in use would you like to start a chkdsk on reboot (Y) (Enter) Reboot PC
This should start a chkdsk after the chkdsk is complete reboot the PC you should go to you profile (desktop with Icons)
Good Luck
Dr Geek MD
Feb 22, 2009 | Gateway GT5220 PC Desktop
My computer is turning on and off continually
download memtest and burn the iso to a cd and boot from it to test your ram, it usually only takes a few minutes to see if your ram is bad or not, otherwise ive had computers with bad system boards (blown capacitors) that reboot themselves, and also computers that are overheating reboot themselves, check to make sure all air vents aren't blocked and that all of your case fans run well
Feb 19, 2009 | Gateway GT5220 PC Desktop
Computer freez
well u could try going into ur bios befor it freezes and make it boot from the win98 cd instead of ur HDD or use a boot disk or just take ur cmos battery out and it will reset ur bios so it should work
Jan 13, 2009 | Computers & Internet
Computers & Internet Logo
82 people viewed this question
David Payne
David Payne
