Question about ViewSonic VE155b 15" LCD Monitor
AS SOON AS YOU TURN ON THE MONITOR IT SHOWS NO SIGNAL ON THE SCREEN. SO THERE IS SOME POWER TO THE SCREEN OR YOU WOULD GET NO SIGN OF LIFE AT ALL AND THEN IT SHUTS THE SCREEN OFF YET THE POWER LIGHT SHOWS YELLOW INSTEAD OF GREEN
    President:
  • 4,070 Answers
Hi! If this is the case, the problem will surely be on the monitor cable going to the pc. If the cable is loose or faulty it will give you a no signal message. YOu will need to secure the cable of the monitor for it to work. Hope this helps and thank you for using FixYa!
Posted on Aug 28, 2010
How to turn my 1080 hp monitor on connected to my computer
Look for the power button/switch on the monitor
Oct 13, 2017 | HP Computers & Internet
My emx-mcp61p-avl has power but no display no beep. video card is new and compatible with my motherboard. RAM is new also.
Just because the ram and video card is new does not mean they work. But since you say it has power, I'm assuming it boots up all the way except the screen is not displaying.
If this is a laptop try the steps below.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If so that proves your video card is ok. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If it is a desktop try the steps below.
Try connecting another monitor to the computer. Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor shows the display, then your original monitor is bad. If the Borrowed monitor does and same as your original monitor and does not show a display then your video card has an issue.
May 30, 2012 | Computers & Internet
No sign of life from the display half but the bottom reads life.
If you have already checked the connections from the screen to the PC, check that you have a power light on the screen. (Green or Amber). If no light, check power to screen. If it is amber, then the screen is not getting a signal from the PC - recheck connections. I would suggest you try and connect the pc to a different monitor to check whether it is the screen or the PC.
If it is the same on another Monitor or if the power button is green on the screen, then the pc is not sending information properly. Turn the pc off manually by holding the power button on the bottom half for about 10 seconds. All lights should go off from it. Now turn it back on again and see what happens.
If you see loading windows and then goes black, do the following:
Turn off the pc (bottom half). Turn back on and as soon as you pressed the button to turn on, start tapping the F8 key until you come to "Windows Advanced options" screen. use the arrow keys and go to Enable VGA mode. Press the return key twice. If it loads to windows, then fine. If not, then you may have a problem with the display adapter.
Hope that helps
Nov 11, 2010 | Computers & Internet
Monitor keeps going into sleep mode and it won't turn on so i can use it.
Monitors go to SLEEP mode when there is no computer signal coming into them. As soon as a computer signal reaches the monitor, it will automatically wake up and show the images in the screen.
Mar 27, 2010 | HP Compaq FP5315 15" LCD Monitor
I have a Microtek 710S which suddenly will not show anything other than a black, blank screen. When I turn on the button in the bottom center of the frame, it alternately changes color every second or...
Does it show any sign of life when you poweron the PC? With the PC powered on, remove the data cable of the monitor (yes the D plug) from the PC and insert it back. See if there are any signs of life. If there are any signs of life, reboot in safe mode by pressing F8 at bootup. If it boots in Safe Mode, then go to Control panel->Display->Settings->Advanced. Remove the Monitor and let windows detect the monitor. Same thing can also be done from Control Panel->System->Hardware->Device Manager-. Monitor. Remove the monitor and from Actions select Scan for New HW.
Oct 02, 2009 | Microtek C783GM 17" Flat Panel LCD Monitor
Sampo Flat Screen Black unless unplug and plug back in
i had the same problem now my monitor wont even turn on if i do that the power light just keeps blinking maybe its a sign of a dying monitor
Jan 16, 2009 | Sampo PD-70 15" Flat Panel LCD Monitor
Benq FP737s - Not working suddenly - Black screen
Most like just burned out and needs repaired or replaced.
Nov 11, 2007 | BenQ FP737S-D 17" LCD Monitor
Having trouble
You have a collection of unrelated problems I am affraid.
#1 The white line is a terminal LCD panel and will need to be replaced. Repair is far more expensive then it is worth.
#2 The video card sounds like it is dead as well. Sounds strange that you can see the test signal though right? Wrong, the test signal is running through the internal section of the controller IC. As soon as you connect a video cable to the monitor it tries to swap to external mode which is damaged, hence no picture.
Check the video board for any signs of damge to the transistors at the input, time to drag out the magnifying glass.
Hope it helps, good luck =)
Apr 27, 2007 | Dell E153FP 15" LCD Monitor
ViewSonic VE155b 15" LCD Monitor Logo
95 people viewed this question
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
