Question about Microwave Ovens
What is the best thing to use to get the burned smell out of the house,I burned up some meat, I've tried everthing that I could think of. I boiled bleach, I boild pine-sol,burned inscents and its still in here ,help me. Thanks Terry
  • Terry Sims Aug 28, 2010
    thank you I think one of these will help you have a nice day too
  • 10,515 Answers
There are few things that you could try.
1. Cut up a lemon into pieces and put it into a pot of boiling water on the stove. Let it boil for 10-15 minutes to freshen the air.
2. Cut up an onion and place it in a bowl of water. Leave it in the middle of the room overnight and it will absorb odors from the air.
3. Boil a handful of cloves in a pot of water to help to change the lingering smell in the air.
4. Wash all floors, walls and affected areas with 1 part bleach: 99 parts water (10% solution) or a water/vinegar solution.
Try the above options and see if that works.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Aug 28, 2010
How do you get rid of burn food smell in your home?
Get some nice simmering potpouri with a nice cinnamon smell and boil it in a bowl of water in the unit. Does pretty good job, then just regular cooking over time will take it away too.
Oct 10, 2017 | In Microwave Ovens
How to cook corn in microwave
Depends on your microwave and the popcorn. Your owner's manual will have instructions. The first couple times, it will probably be by trial and error.
BTW--the best way to get rid of stinky burned popcorn smell from a microwave is to microwave a small amount (1/4 cup) vinegar until boiling and let it set in the microwave for a while.
Apr 24, 2016 | In Microwave Ovens
Microwave burn smell how to remove
put an ozone generator inside for 5-10min. Unplug the microwave, then run the ozone generator for 5-10min. IF that does not work you may need to start replacing plastic bits inside.
Mar 02, 2018 | Microwave Ovens
Burned microwave smell how do you get ridd of the food smell
The best suggestion I have is to boil water for a half an hour. Be sure not to let the bowl of water run empty. Also, be sure to wipe the condensation out of the oven cavity after this procedure. Generally, though, continued regular use of the oven is what works best for this situation. It just takes time to get the burn smell out.... Good luck!
Nov 19, 2013 | Microwave Ovens
I left a pot of water boiling, causing lots of condensation on the microwave. Unfortnately, another house mate then tried using the R-1470 when smoke started coming out of it. Smells like electronics...
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
YOUR SAFETY IS PARAMOUNT
This is a job for a professional but if you are safety clued up, here's instruction.
Make sure the !!!!any capacitors are discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 or moving coil meter on high resistance range for short circuit, (DVM's won't show the fault!), the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Mar 01, 2011 | Sharp R-1470 Microwave Oven
Was using it last night to heat something up. When almost done, microwave made a zizt type of sound and went off. I turned it back on and it continued cooking, but I started smelling burned plastic or
More common then you think, i have gone through a couple microwaves in the last ten years, they both failed very similar to what you describe. One popped the breaker one day, reset the breaker and it worked again but had an odd smell to it. I took it apart and couldn't find anything burnt or melted so i tossed it and got a new one, i didn't want a microwave burning the house down! I would suggest unless your really tied to that microwave that you just replace it for safety sake. Four years or forty years old don't matter anymore, i had one microwave, LG brand, that died two months after the warranty expired and it would cost more to repair it then replace the thing!
Jan 11, 2018 | Panasonic NN-H964 1200 Watts Microwave...
Microwave smokes and smells like burning plastic
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
http://www.fixya.com/support/r5508031-microwave_oven_basic_troubleshooting
heatman101
Jan 25, 2009 | Kenmore 64663 Microwave Oven
Is the microwave possibly dangerous after it popped & now smells
Hello jeffnlaur,
The sound you heard could be any number of things but I would attempt to verify the basic preformance of the microwave was ok by placing a cup of water in the cooking compartment and switching the micro on for about 2 minutes.. The water should be close to or at a boil after this time ( depending on glass type and power output of oven). Listen for any other irregular sounds while it is running. You may have heard something in the soup pop or some of the electronics within the micro arc but it may not mean it is dangerous. Try the water test first and if it continues to exibit internal noises and burning a burning smell, I would discrad the oven. Table top models are very inexpensive and the cost to diagnose and repair would probably exceed the cost to replace,
In terms of dangerous, there are safety devices to cut off power to the magnetron and other components if warranted. Not sure that helps you but with limited info from your side, diagnostics are 'iffy' at best..
Regards
Rick
Jan 09, 2009 | Panasonic Microwave Ovens
Burn at bottom of microwave
First try cleaning the burned mark off. Dip a scrubber in lemon juice and sprinkle salt on it; this is also great for burned coffee pots. The smell can be gotten rid of this way: Boil lemon peel in water, then put the water in a spray bottle. Not only will it make your microwave smell fresh but the lemon oil will make it easier to clean. If it still smells of burning rubber, take the back off and inspect the wiring. IF you see burned wiring, please do yourself a favor and replace the microwave!
Microwaves work by making the molecules in food get "excited"-they move more-meaning, if there IS rubber burning, then there will be minute molecules of rubber in your food, which is BAD for your immune system. If it's just burned chocolate, though, it is harmless unless you are allergic.
Apr 03, 2008 | Danby DMW1400 Microwave Oven
Burnt cinnamin bun with waxed paper on top
Boiling water with baking soda then with vinegar seem to be the best tips.
I would do a Google search for "microwave smell" and you'll find a ton of links.
Nov 25, 2007 | Microwave Ovens
Microwave Ovens Logo
18 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
