Question about Whirlpool Duet GHW9150P Front Load Washer
Water wont stop even if i unplug i had to cut the water supply off
    President:
  • Whirlpool Master
  • 2,651 Answers
Yea sound slike you ohave a faulty water inlet valve, stuck in open positon,removet he hoses and repace the inlet valve on hte washer.
Posted on May 08, 2008
Maytag bravos x econocserve wont go through all the cycles and then you have to select the drain and spin to finish the clothes
You may be over sudsing the machine and it thinks the water is not drain and stops. Run a empty load on a cold water cycle and not hot water. then cut back on the soap. if you use fabric softener the cut back even more.
Feb 01, 2016 | Maytag Washing Machines
The water is overflowing and wont stop even when unplugged
WHOA turn the water off behind the machine and replace the inlet valve. .
Sep 01, 2015 | Whirlpool Ultimate Care II LSQ9549L Top...
Amana top load washer overfills with hot water and wont stop unless you shut supply off. NTW5400TQ1
Okay you say only hot water if you unplug does water still come in if so bad inlet valve if it does it on both then the pressure switch is bad or there is a hole in the tube that goes from tub to pressure switch
Feb 17, 2015 | Amana NTW5400TQ Top Load Washer
Kenmore elite heavy duty king size top loader water will not stop running to the liquid detergent dispenser even when the tub starts filling Causing the machine to over flow
could be the water valve not closing properly, try unplugging the machine see if the water stops if not replace water valve. Also check pressure hose for cut and pin hole thx
Mar 01, 2014 | Washing Machines
Water wont cut off
Does the water run if you push the timer dial in to stop the cycle or does it run even if you unplug the washer?
Dec 31, 2011 | Whirlpool LSR7333 Top Load Washer
Water is continuous once the system says it to open, thus the program stops there and no more spinning. Water level setting is not functioning. Water inflow stops only when pressing the pause...
Sorry but it requires a service call as it is not the sort of fault/problem which could be fixed other than by a technician, I would suggest. Also it is impossible for us to remotely know exactly what could be wrong.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Jun 26, 2011 | Washing Machines
Whirlpool WW1206
WW1206 Whirlpool Washing Machine CONTINUOUS WATER PROBLEM.
Water is continuous once the system says it to open, thus the program stops there and no more spinning. Water level setting is not functioning. Water inflow stops only when pressing the pause position. Even if the water supply is cut off, no spinning is experienced. The program still continues and waits for the automatic water supply cut off as programmed, but the water level indicator does not work. rince and spin programs work because there is no supply of water in the program.
PLEASE KINDLY ADVISE
Jan 17, 2011 | Whirlpool Washing Machines
Washer wont stop filling even when its washing. GE
Replace water inlet valve, it's stuck open. You may try removing hoses to valve and see if something is holding it open
Jun 29, 2009 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal De
