Question about Garmin North America GPS Map Update Maps Software
I have a Nuvi 765T and I purchased the Lifetime Map Updates from Garmin however when I click the "garminmapupdater_naeu_g.exe" I get the error message "Garmin Map Updater has stopped working windows can check online for a solution" when I selected the "Problem Details" dropdown it shows "APPCRASH" as the "Problem Event Name."
  • mstrano Aug 28, 2010
    Hey Clay thanks for the quick response, but this did not fix my problem. I removed the Garmin Webupdater application and then shutdown and restarted and reinstalled the "WebUpdater.exe" for my correct windows and I still have the same problem.
    Hello Clay,
    I followed your last set of instructions. I downloaded CCleaner, installed the program, and used the program as you instructed to remove the WebUpdate program from the registry. I then redownloaded my Map Update file to make things as clean as possible. Unfortunately I have the same Gramin Map Updater problem.
    In the problem details here is what it says:
    Description:
    Stopped working
    Problem signature:
    Problem Event Name: APPCRASH
    Application Name: GarminMapUpdater.exe
    Application Version: 2.3.0.0
    Application Timestamp: 4c2b6561
    Fault Module Name: KERNEL32.dll
    Fault Module Version: 6.0.6002.18005
    Fault Module Timestamp: 49e037dd
    Exception Code: e0434f4d
    Exception Offset: 0003fbae
    OS Version: 6.0.6002.2.2.0.768.3
    Locale ID: 1033
    Thanks,
    Mario
You will need to fully uninstall the garminmapupdater_naeu_g.exe and then reinstall it to correct this problem. Also install free antivirus software and keep that updated and running to prevent bad files from downloading on your harddrive. Click on the link below to read more:
http://www.ehow.com/how_5192304_fix-appcrash-errors-computer.html
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
http://free.avg.com/us-en/homepage
Posted on Aug 29, 2010
  • 2,841 Answers
The application is crashing for whatever reason. Uninstall the Web Update Software, restart your computer, and then install it again. This will more than likely solve your problem. Download and install the correct version for your OS. http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Posted on Aug 28, 2010
  • 3 more comments
  • NOT ME Aug 28, 2010
    What operating system (OS) are you running? Between now and answering my question I want you to install this very safe free program.
    http://www.piriform.com/ccleaner
    When installing it watch for the section during the installation and uncheck the Yahoo Toolbar or you will also get it which you do not want. This program will help us to totally uninstall the program and clean out any left over registry entries from the Web Updater which may be causing a problem. As soon as you get it installed open the Tools Section and then click the Uninstall Tab and find the Web Updater in the list of programs. Click it and then click Run Uninstaller on the top right. This will do a much better job of removing the program than Add/Remove in Windows. As soon as it has removed the program click the Registry Tab on the left. Click Scan for Issues. When it finishes the scan click Fix Selected Issues on the bottom right. You can make a backup if you wish but in my 5 years of using this program I have found it to not be necessary as it is a very mild registry cleaner. Let it fix all the issues it finds which may be allot if you have never ran a registry cleaner. Now click the Cleaner Tab on the top left and let it clean out all temporary files on your PC. Let it clean everything out. Once you do all this restart your PC and try installing the software again. This program is very safe to use and will remove all files not needed. It will not only help to clear out any files left over from old software you have removed but will speed up your pc. I will be back online in a few hours.
    Hey Mario, you should have version 2.4.2 not version 2.3.0.0 as is indicated in your post. I still need to know what OS you are running? The link I provided takes you to the newest version.
    Hey Clay,
    Thanks for the response. The strange thing is that I did download and install version 2.4.2 so I can't imagine why the Garminmapupdater_naeu_g.exe error would say 2.3.0.0. Sorry that I neglected to mention that the OS I am running Windows Vista.
    Thanks,
    Mario
    Mario, I am out of ideas other than uninstalling it, running the Registry cleaner in ccleaner and trying it again. The fact that the error is showing a different version that what you downloaded makes me suspect that some part of the program is still on your computer even after your uninstall it. Did you restart after using ccleaner to remove it and clean up the left over registry entries? Try this. Uninstall it and run the registry cleaner in Safe Mode. After you do that run your security scans in Safe Mode just to make sure you are not infected. Then restart your computer and reinstall the program. To get to Safe Mode restart your PC and as soon as you hear or see anything start tapping the F8 key. Continue tapping it until you see Safe Mode screen appear. Choose Safe Mode and nothing else. If this does not work then I suggest you Contact Garmin support.
    OK Clay thanks for the suggestions but I did indeed follow your instructions completely. The strange thing is that I never had another Windows OS on this computer, or downloaded any other Web Update software other than the 2.4.2 so I am sure that this is a "glitch" in the "Garminmapupdater_naeu_g.exe" file code. Anyway I will attempt your final recommended process for the "Clean" Uninstall/Reinstall and see what happens.
    Thanks,
    Mario
When trying to put in an address the Garmin asks me for a country and then does not accept it after typing in the first letter. The other functions appear to be ok.
Hello
you need to update your map
Purchase your map updates (if necessary). You can purchase map updates for your Garmin Nuvi from the Garmin website. There are two basic options: a lifetime purchase or a one-time upgrade. The lifetime purchase gives you access to any new updates for the life of your device, while the one-time upgrade will provide you with the latest current maps, but you'll need to purchase again if you want to upgrade again later.
Make sure to log in with your myGarmin account before purchasing the map upgrade.
Connect your Garmin Nuvi to your computer via USB cable.
Open the "myGarmin" website and sign in with your Garmin account. Make sure to sign in with the account that you've purchased the map updates on.
Click the "myMaps" tab on the myGamrin dashboard. This will load a list of all of your purchased map upgrades.
Click the drop-down menu in the "Recent Map Purchases" section. Select your Garmin Nuvi from the list of devices.
Install the Garmin Communicator Plugin when prompted. This is required in order for the Garmin website to transfer the map files to your Gamrin software on your computer.
Download and install Garmin Express. This is the program that allows your computer to interact with your Garmin Nuvi.
Register your device in Garmin Express. If you haven't already registered your device, you'll be prompted to when you start Garmin Express. You'll need to register in order to update the maps.
Click the "Updates" tab in Garmin Express. This will show all of the available updates for your Nuvi, including the new map update you just purchased.
Click the "Show Details" option next to your Map Update. Click the "Install" button that appears. You will need to accept the agreement before the update installs.
Wait for the maps to download and install. Once you agree to the terms, the map update will begin downloading to Garmin Express, and will then be transferred to your Nuvi. This will likely take several minutes to complete.
unplug the Nuvi when the update is complete. The Nuvi will reboot and begin installing the updated software on the device. This may take another couple of minutes.
You can download garmin express here
http://software.garmin.com/en-US/express.html.
Apr 19, 2015 | Garmin Nuvi 610 GPS Receiver
L do I know if I have life time updates on my gamin nuvi 100
Usually if you have lifetime traffic and map updates, the model comes with LMT which means Lifetime Map and Traffic updates. Or LM means Lifetime Map updates.
Sep 20, 2014 | Garmin nuvi 1300 Car GPS Receiver
How can upgrade my garmin nuvi 255w gps?
Using the Garmin WebUpdater will update the operating software.
Map updates subscriptions are available as lifetime or onetime updates and are registered to the map that is installed on the Nuvi.
http://www.gpscity.com/garmin-numaps-north-america-lifetime-updates.html
http://www.gpscity.com/garmin-numaps-update-city-navigator-nt-2012-north-america.html
The Nuvi 255w is an older unit and is probably due to be replaced. Once the battery dies on the unit, it can not be replaced easily.
There are a number of Garmin GPSs that come with lifetime map updates.
http://www.gpscity.com/search/q=lifetime/&p=1&c=1&t=Automotive+GPS
Dec 24, 2011 | Garmin nuvi 200W GPS Receiver
Good day we have a Garmin Nuvi 350 we looking for free updates for voor the nuvi. good you tell us were we can find them. the computer is a Apple. i hope to hear soon from you thanks miss...
Free Garmin Map updates can be downloaded within 90 days of purchase or are free for a life time when it's purchased with lifetime map updates.
Software updates are always free.
Maps / software can be updated online by registering your Garmin at MyGarmin.com using the serial number and your name. On this website you'll be guided through the steps to download / install the required web browser plugin to communicate with your Garmin Nuvi.
When connected over the USB cable - MyGarmin.com shows compatible map or software updates. These will be free in the conditions mentioned above.
Note that updating a map online requires a 3Gb download. This can take a very long time and requires a stable internet connection. Also your Mac need to have at least 5 Gb of free space to install the Map.
A Nuvi software update is much smaller and takes less time to complete.
Jul 09, 2011 | Garmin Nuvi 350 Car GPS Receiver
I have a Garmin Nuvi 1490t, I purchased it last year and received lifetime map updates. I am trying to update the maps on it because they are out of date.
Details of how to update your maps are at http://www.fixya.com/support/r5628920-update_garmin_satnav_maps
The only difference in updating when you have a lifetime map update is that when you click on GET MAP you are taken to the download screen instead of the payment screen.
Mar 30, 2011 | Garmin GPS
Does this Nuvi 265W for $150.00 has the lifetime maps?
Hi.
No it doesn't. Garmin devices have one free map update included when you buy it new. You need to register your product online to get it.
You can purchase lifetime map updates on garmin.com or buy one upgrade at a time.
Feb 10, 2011 | Garmin Nuvi 265W GPS Receiver
How can i update maps on my garmin nuvi 370 that i bought about 3 years back??
You can purchase map updates online from Garmin. Here's the link I use: https://my.garmin.com/maps/chooseDeviceType.htm
You'll need to connect your Garmin to your computer with a USB cable. Then go to the Garmin web site and follow their directions. You can buy a single update, or buy a "lifetime" (of the device) subscription to map updates.
Oct 09, 2010 | Garmin Nuvi 370
How do I get free map updates for my garmin nuvi 200w
Garmin allows you one free update as long as you download it from their website within 60 days of your purchase date. After that they will charge you either $100.00 per year for updates or $200.00 for lifetime updates.
Apr 25, 2010 | Garmin nuvi 200W GPS Receiver
I tried to update my garmin. The screen doesnt move (or continue to download) I allowed for block ups.
You need to download and install the Garmin WebUpdater and Garmin Communicator Plugin both available from Garmin's website onto your computer. This allows updates to be installed directly to the 765T and provides the necessay USB drivers as well. The 765T must be connected to your computer when performing all updates or upgrades.
You may need to create a MyGarmin account and register your Nuvi 765T.
Resetting the 765T: with the unit off, press your thumb or finger in the lower right corner of the screen while turning the 765T on. This will clear all user data, base map software will remain intact. Connect 765T to computer and proceed with the Garmin WebUpdater.
Dec 22, 2009 | Garmin nuvi 765T GPS Receiver
How do you download updated maps to he garmin nuvi
You can purchase map updates from stores that sell the units, or new this year you can buy updates for the life of your unit from the Garmin website which cost $120. You can get up to 4 updates per year. If you wish you can just purchase a single update for $70.
http://www.garmin.com/garmin/cms/us/maps/numaps-lifetime
Also download the Garmin Webupdater software from the site which allows you to connect the Nuvi to your computer and will give you free software updates for the unit itself.
Nov 17, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin North America GPS Map Update  Maps Software Logo
604 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
