Question about Itronix GoBook IX250 Notebook
SL53S PIII Did you install the cpu without a hitch? I am thinking about upgrading. If you have any idea let me know please
  • 3 Answers
I have just fitted one to my IX250, works perfectly and even throttles down when full power is not needed.
Posted on Feb 28, 2009
Upgrade compaq armada e500
It has been a while but I think it isn't a zif but a standard low profile socket. You need a good light and check the edges to see if you can see the layers or where the cpu edges are. You should see the color differences between the plastic or the socket and the cpu. From above it will look like just a cpu but from the sides you should see the cpu overhand the socket a small bit or be flush with the edges.
The cpu has to be a M series P3 and you may need to adjust bus speeds and/or ram speed to make it work. May also have to upgrade bios as well.
Nov 17, 2011 | Compaq Armada E500 Notebook
I have bought a PIII 1Ghz CPU to replace my armada 110 Celeron 700MHZ CPU, Sometimes it works well for about an hour then just turn itself off, other times only lasted a few minutes. I've noticed that the...
With out knowing your motherboard it's a guess. However you can look at the link below. Then scroll to the bottom of the page. Your SL52R should be the 4th cpu from the bottom of the list. It doesn't look likely and it definitely runs hotter. http://www.cpu-upgrade.com/CPUs/Intel/Pentium_III/RB80526PY700256.html
May 30, 2017 | Compaq Armada 110 Notebook
Just purchased CPU upgrade (Pentium 3, 1.4Ghs, 512K, 133Mhs) for my DFI TA-64B motherboard. The manual that came with the motherboard notes: "The frequency ratio (SW2 Switch) of CPUs greater than 8x has...
Your CPU needs a ration of x10.5 (10.5*133~1400Mhz), thus according to what you wrote, you won't be able to use it with your existing motherboard (or - only be able to use it as 1.00Ghz CPU).
Mar 14, 2010 | DFI Twin Sockets TA64-B Motherboard
I want to upgrade the cpu on a se440bx-2 slot 1 PIII motherboard
If you go to www.motherboards.org and type in your motherboard, it will find it and give you all the information that you need.
Nov 08, 2009 | Cornerstone INTEL SE440BX-2 SLOT 1 PIII...
How to install a 3 point hitch on a 140 farmall did not come with a 3 point hitch
I think a 140 is a IH Cub . I don't believe they had available a 3 point hitch. Please register at www.farmallcub.com and there are people there that have had a 140 apart and back together many times. IF there was a 3 point hitch available they will know about it.
GOOD LUCK
Mike
Oct 16, 2009 | Garden
I have a Azza PT-693BTX motherboard and i am trying to upgrade memory. Once installed it only reflect 1/2 of the capacity i.e. 512 mb show as 256 mb. I also have a PIII 748 mhz and would like to upgrade...
This board is now long in the tooth and will only support a max of 512mb in each slot upto a max of 1.5 Gb, however the chipset restriction will only allow it to "see" single sided ram memory, if the memory used has chips on both sides it will only read one side hence half the real memory is recognised. So use single sided 512mb for max memory yield. CPU is socket 370, the fastest made was the 1400 version using 133fsb, which your board supports, not sure if your bios would recognise this chip, however they were discontinued in 2003 so finding one would be difficult!
Jul 05, 2009 | Computers & Internet
Need faster PIII mobile processor for CPx 650 laptop = X ghz proc
I'm not sure about the CPU upgrade--these generally are hard to determine and this is complicated by the fact that Pentium III processors are no longer made, I would say that you could go on e-Bay and find one there (should be cheap) and try it.
An easier way to get a little more speed is to bring the memory up to the maximum the laptop will hold. (In your case 512 MB). That and set the paging file to allow the system to determine the size needed (Unless your system has Linux installed). Any further upgrades on an older system like yours are usually just a waste of money.
Jan 23, 2009 | Dell Pentium 3, 500 MHz Pentium III...
Which frequency of processor for QDI motherboard BrillianX-1S with BIOS 4.51 PG
hey there.
If you are planning to upgrade the processor with the latest one then it is not possible without upgrading your motherboard.
Because as per all the bus and system configuration requirement with ur CPU you must give the recommended bus speed, bus lines, Address lines, Ram supportive slot, and RAM Frequency.
Your motherboard must suuport all those requirement if you are upgrading ur Processor.
You are right that ur motherboard can only work with PIII CPU.
Upgrade ur motherboard with atleast of 845,945G Chipset to support up to core2 Duo Processor in Intel. OR with A8V-VM and above in Asus Motherboard.
(Gimme your acknowledge by rating me)
Romy
Aug 03, 2008 | Computers & Internet
CPU Upgrade
You pulled the processor out of your laptop ... that was a brave move ... generally laptop boards are fully integrated so there is very few options on changing the processor ... also because of the extreme heating conditions the heat sink bonding is very critical ... make sure you replace this properly or you will have overheating issues in the future ...
Mar 30, 2008 | Toshiba Tecra 8100 Pentium III, 850 MHz...
CPU Upgrade Help Compaq M700
You might want to check this out I think it answers the questions you are asking? http://h18000.www1.hp.com/products/quickspecs/10382_na/10382_na.HTML
Sep 30, 2007 | Compaq Armada M700 Notebook
Itronix GoBook IX250 Notebook Logo
184 people viewed this question
Top Itronix Computers & Internet Experts
Steven Wander
Steven Wander
Larry Chandler
justwinwin
Are you an Itronix Computer and Internet Expert? Answer questions, earn points and help others
