Question about Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White
Well my home has a oven and we haven't been using it for a while so now we dont know if we disconnected the oven or it doesn't work it self.
  • 28 Answers
I would suggest that you clarify if the stove is plugged in first, and if the breaker for the stove is turned off.
Posted on Aug 29, 2010
Self clean oven cycle doesn’t work
that leaves you with 2 options 1 call a repairman COSTLY or 2 revert to the old way of manually cleaning it with oven cleaners ,rubber gloves and paper towels .labor intensive. personally with all the problems I hear about using the self cleaning I prefer doing the manual way
Nov 05, 2017 | Ovens
Whirlpool self-cleaning oven: RBD275PDB14 . . . I DO NOT want it to self-clean. Is there any way to DISABLE the self-cleaning feature?
Just don't use it. The finish in the oven is made to work with the self-cleaning operation; it naturally facilitates burn-off at high temperatures. It is normally impractical to remove and replace the finish, besides, it's harmless as far as I know. If you are worried about someone accidentally activating self-clean, you could tape a coin over the self-clean button. (If you have a curious child in mind, the coin may actually draw attention to the button and invite its operation - you know better than I who or what you are dealing with.)
There is no good way to disable the self-cleaning function without replacing the controller with a custom-built and programmed unit. The button is in a matrix with other buttons, so attempts to disconnect it would disable other buttons and generate a controller error that would prevent the range from operating.
Jul 08, 2017 | Whirlpool Ovens
E-1 & F-5 come on after about a minute when attempting to use self cleaning. the micro switches work & the solenoid has been replaced. could it be the ERC ?
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa
Oct 21, 2011 | Whirlpool GMC305PD Electric Single Oven
I used the self-clean for the first time and my oven door is still locked and the display doesn't work at all. Model #YKESS908. What can I do to unlock the oven door? I have checked the circuit...
Hi
You can set the unit on self cleaning and then after 15 minutes stop the cycle, let it cool down for an hour and then open the door. If the issue remains then you'll have to replace the door lock assembly, then you can open the door with a coat hanger by pulling the latch towards you. Hope this helps...please post back for further assistance.
Daniel
Sep 09, 2011 | KitchenAid Ovens
We turned the self cleaning on our double oven...it now has no power and is completly locked. HELP! We have checked the fuse box and it is fine. Something is wrong with the oven it self...how can we fix...
This is no guarantee, but try disconnecting the power from the appliance for about 5 minutes and then turn it back on. This causes a system reset. If this doesn't work, you may need a replacement control board.
Aug 27, 2011 | Whirlpool Ovens
Need to know how to use the "self cleaning" method for my GE Profile Spectra oven. Also would like to know how to use the convection part of oven also. Thank-you for your help.
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
Apr 15, 2011 | Ovens
I've got a self cleaning oven don't know how to work it what do i do
Hello there!
It depends over a lot ot sets of those self cleaning oven...
IS there any instruction manual for that device, there must be, search over the internet i really dont know what could i suggest to you if i dont have any details. Good luck! =)
Sincerely
Aleksandar Adzic
Apr 16, 2010 | Frigidaire FEB27S5A Electric Single Oven
Door lock light blinking ,oven wont work on a older gibson self cleaning oven.
It sounds to me that the door lock switch itself is stuck in the "on" position. If you don't use the self-cleaning feature, I would suggest simply disconnecting the switch. If you DO use the self-cleaning feature, you may want to consider replacing the switch or inspect it to make sure there isn't debris, grease, etc., stuck in it, making it stuck on all the time.
I hope this helps! :) Please let me know if you need any further assistance in this matter and I'll be more than happy to help!
Feb 21, 2010 | Ovens
How to use self cleaning oven
  • When using the self-cleaning feature on your oven, the temperature within the oven rises to an extremely high temperature, usually around1000 degrees. The oven will remain at this temperature for a set periodof time, often from 1 to 3 hours.
  • Self-cleaning ovens differ from traditional ovens in that they require a timer to control the amount oftime that the self-cleaning feature operates. They also require extrathermostatic controls to control the extremely high temperatures.
  • While the mechanisms inside aself-cleaning oven are quite complex, the concept behind aself-cleaning oven is fairly straight forward. The extremely hightemperatures incinerate dirt and debris from your oven, thus cleaningit for future use.
  • Safety is very important when using yourself-cleaning feature. You must ensure that the oven door is completelyclosed while the self-cleaning cycle is running. 1000 degreetemperatures are obviously extremely dangerous. Self-cleaning ovenswill come equipped with a secure oven door latch for this reason.
  • The crucial door locking system isinitially engaged to signal that you are ready to use the self-cleaningfeature. When the oven reaches a certain temperature, the door locksystem will ensure that the oven door cannot be opened until the cycleis complete and the temperature has returned to a manageable level.The result is a clean oven without the use of harsh oven cleaners orabrasives.
REMEMBER YOU ARE WORKING WITH 220 VOLTS - USE EXTREME CAUTION!!!
Nov 11, 2008 | Ovens
Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
48 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
