Question about Roper MHE14XKB Microwave Oven
Roper above the range
Wife was changing the lower light bulb above the range , when the old burned out bulb broke in her hand , and must have still had power to it , and now the oven will not kick on, however the timer and clock does come on and even counts down as if it is working , pulled ceramic fuse under upper cover and then check out , and the board would not even turn on timer
  • 1 more comment
  • Anonymous Oct 27, 2008
    I had the same problem when I went to change the lightbulb. The microwave made a "fuse going bad" noise and would not work, while the timer and clock do work! My husband took it to a repair shop where they want $200.00 to replace the computer board. I think we paid about $200.00 for the microwave 20 months ago. Sounds like we may be getting the run around.
  • Anonymous Dec 10, 2008
    after changing a burned out light bulb the fan and light come on when you open the door. however the microwave still works.
  • verohans Feb 17, 2009
    how to remove broken bulb over the range
  • Roper Master
  • 9,098 Answers
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 10, 2008
How do i change the bulb on ag821azh microwave x2
follow this steps and use the VOM for fix it. God bless you
Light Bulb
If the microwave light bulb is not working it is usually located behind the upper grille and behind an access panel, and above the lower panel. On counter top units you will need to remove the outer cover to get to the bulb. If that doesn't solve the problem check the on-off switch, and control board
Main Control Board
If the microwave light bulb is not working check the light bulbs, sockets and wiring. If they are good the main control board might be defective.
Light Bulb Socket
If the microwave light bulb is not working and a new light bulb doesn't solve the problem, the light bulb socket might be burned out and need to be replaced.
Jun 19, 2013 | Microwave Ovens
I have a roper mounted microwave above my stove. i just need to know what kind of bulb goes underneath it.
Since you obviously intend replacing the bulb yourself (good for you!) you should first remove the old bulb and that will make it easier to find a new one. Chances are, its a common bulb, readily available wherever light bulbs are sold. Or, at the very least, a hardware store like Tru-Value or Home Base.
Feb 03, 2010 | Roper MHE14XKB Microwave Oven
Lite bulb & fan stopped working but oven works fine.
had the same problem (self induced) and shorted out the oven.  took the control board out and found i had burned the circuit between the connector and high/low light microswitch.  just jumped the circuit with a piece of solder, reinstalled the board and the fan and light started working. it doesn't have a low light setting anymore but who cares, just saved 130 bucks.  not going to tell my wife how i broke it, only how i fixed it. very proud of myself and learned a little bit, mainly unplug the unit before working on it.
Jan 10, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
F6 error... microwave not working
is the microwave itself working? because same thing happened to us apparently the guy who changed the bulb didnt unplugg the thing first and well it burned a part of the circut board cost us about 90 dollars to fix it.....
Oct 05, 2008 | Roper MHE14XKB Microwave Oven
GE Spacemaker XL1400 Microwave - Lights wont cut off
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too, due to a shorted relay.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa.
Aug 24, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Interior Light
If it's avantium, it's on the web, but it's a real pain and requires small hands.
Pull the power before getting thbulb.
Jan 01, 2008 | GE Advantium 120 Convection/Microwave Oven
Roper mw under cabinet light
You probably need to have the receptacle replaced that the bulb screws into
Oct 29, 2007 | Roper MHE14XKB Microwave Oven
Sharp R-1500 range lights
Are any other bulbs in the home going out prematurely? If so, I would check the actual voltage of your power outlets. If not, the bulbs may be getting grease or debris on them from stovetop cooking. This can cause hot psots and premature failure. I recommend wiping them clean with alcohol on a cloth before installing them. I recommend that folks always have their hood fan on when cooking on the stovetop. Also, you might check with a local home center (Lowe's, Home Depot, etc.) to see if they have some high-quality (non-Chinese) substitutes.
Aug 08, 2007 | Sharp R-1500 Microwave Oven
Light bulbs burning out
That does sound odd! On one hand, I would suspect that maybe the door is getting slammed and that vibration may be contributing to the failure. But that would be much more likely for an incandescent bulb than a fluorescent type. Which is yours? You may have a bad connection on the socket which is causing some excess heat. Does the blown bulb look funny on the ends or at the connection? Assuming you're using the bulb your manual calls for, and the socket is okay, it may be a problem on the control board. Once you've digested this reply, let me know what you find and we can take it from there.
Oct 20, 2006 | GE Spacemaker JVM1640SJ Microwave Oven
Roper MHE14XKB Microwave Oven Logo
251 people viewed this question
Top Roper Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Mark Cheong
Mark Cheong
Are you a Roper Microwave Oven Expert? Answer questions, earn points and help others
