Question about Denon AVR-587
My Denon AVR 587 receiver turns on and off by itself repeatedly after being on for an hour or so
5 Suggested Answers
djnick989
  • 1067 Answers
SOURCE: Denon AVR-1905 remote
www.remotewarehouse.com grenteeed fit match
Posted on Jan 26, 2008
SOURCE: My Denon AVR-887 Keeps turning itself off
My AVR-887 IS SHUTTING OFF ALSO AFTER ABOUT 30 SECONDS.
Posted on Dec 04, 2008
SOURCE: Denon avr-1804 its turns back after 5 sec
Disconnect all speaker wires on back and then turn on. If it happens again, it's most likely a power supply problem. If it doesn't happen again, it was probably crossed speaker wires.
Posted on Dec 28, 2009
  • 5 Answers
SOURCE: Denon AVR older receiver but worked fine; now
Did you try to reset the unit? Resetting the unit has fixed every problem I have ever had......turn off unit.....hold down A+B at the same time then turn the unit back on...hold buttons for roughly 3 seconds....Let me know if it works.
Posted on Mar 09, 2010
How to hook up an equalizer on denon avr 587?
Use your tape, In end Out jacks on the reciever.
Oct 16, 2012 | Denon AVR-587
How can i resetting my avr 587 to the factory default. I can't get it to work correct now. volume comes on wide open when i turn it on.
Assuming you mean a Denon AVR 587,
1. Turn the unit off.
2. Press and hold Speaker A and B buttons at the same time.
3. Still holding Speaker A and B buttons, press the Power button to turn the unit on.
4. The display should flash on and off at 1 second intervals.
5. Release the Speaker A and B buttons.
Jan 28, 2011 | Audio Players & Recorders
Denon avr-587 shows h/p only in display,no audio out.
The problem usually is very simple - bad connection in head phone connector located on the front of the unit.
You need to find any headphones with 1/4 jack and plug it into receiver several times. It clean internal contacts in the connector and your receiver will work again. Good idea to use contact cleaner during the process. Thanks.
Jan 11, 2011 | Denon AVR-587
Denon avr-587
Make sure that the volume is not muted or too low on the TV...the TV volume output to your receiver will be performing the function of a pre-amp to your receiver. Then select the appropriate input on the receiver that you have the TV audio connected to.
Jul 17, 2010 | Denon AVR-587
I have no sound on the avr-587 zone 2 when set to tv mode, but do get sound in zone 2 when using the tuner. What am I doing wrong?
You need to run an Analog (RCA) cable from your Cable Box, DSS, or FIOS to the Analog input of the receiver. It does not see digital signal input on secondary zones. Hope this helps
Jun 21, 2010 | Denon AVR-587
Denon 528 amplifier cuts out after a few minutes
disconnect the speakers and see if amp will stay on. if this the case maybe suspect one of the o/p amps
Feb 08, 2010 | Denon AVR-587
My denon avr-587 won't turn on
disconnect all equipment from reciever recycle power if the power still not it needs repair
Jul 15, 2009 | Denon AVR-587
Denon AVR-587 Television input stopped - no sound
try plugging another device into the tv input and mank sure you have the input mode is set to auto if you still have no sound those inputs are gone
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-587&imageField.x=106&imageField.y=8
Feb 08, 2009 | Denon AVR-587
How Do I Connect My Dell Laptop to a Demon AV Receiver
use a 1/8in stereo to two male RCA plug to connect from your computer headphone out to an input on the Denon such as AUX or CD
Jan 25, 2009 | Denon AVR-587
Denon AVR-587 Logo
170 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
