Question about Microsoft Windows 98 for PC
Unable to find PCs in network from a Windows98 PC
When i try to ping any other PC on a network its pinging but when i try to find a PC in the network search shows no PCs found.
  • anushree May 08, 2008
    \\IP also doesn't work.
    Master:
  • 441 Answers
Try this:
1.click start>run>type \\IP of the other computer
Posted on May 07, 2008
  • Serwen Bagadiong
    Serwen Bagadiong May 10, 2008
    Do you have a firewall installed on that computer?
2 Suggested Answers
jonniewalker
  • 1031 Answers
SOURCE: unable to find PCs in a network from a WINDOWS 98 PC
restart the system and check again
Posted on May 08, 2008
Unable to connect to cable network after downloading network drivers
You need to be sure that your network settings are properly set. If you're behind a router, make sure that your computer is in the same network with it. Ping any website like google.com and see the result by entering this command in command prompt: ping google.com. Here is a picture showing what you should see if everything is ok.
If your result is something like "Destination host unreachable" or "request timed out" try this command: ping 173.194.66.103.If you have ping with the second command - you should fix your DNS input in Network settings. Usually for DNS server you should use the IP address of your router.If you have ping in both scenarios - you should check Internet Options of your Browser. Make sure you have entered proxy settings if you're using one. Make this initial diagnostic and write about the results so that I could help you.
Dec 07, 2011 | Gateway 505GR PC Desktop
The 4 network connection are blinking al the time The connection led home is not on
The 4 Network connection are blinking means there is some traffic passing on those ports.
Please try to do some ping test between the 4 PCs which are connected to that switch.
If ping test is fine that means some problem with the LED Home but not with the entire box
Oct 28, 2010 | Zyxel PLA470 HOMEPLUG AV SWITCH WRLS4PORT...
Cant ping on a same network
the information you give sounds like your trying to set up a network, if this is the case you will need to set up the network in the netwok program on your computer....icon found in control pannel or on start menu ....shia
May 22, 2009 | Intel Computers & Internet
The printer can not be ping from the network PCs
try assigning a different IP to it and see if it can be ping afterwards. If the same thing happens even with different IP, chances are, its NIC is defective and needs to be replaced.
Feb 17, 2009 | HP LaserJet 4350 Printer
Trouble networking copier to computer
you might have to set up the nic card in the machine. set it to a static IP address (not DHCP), then ping it from a PC..
If you can ping it, then instalation should find it!
I dont understand " time warner connection to rout both computors thru " ?
you should have.
One broadband Modem...
One Router which all pcs and machine's are connected to...
do ipconfig/all to figure out the pcs IP address, arp -a shows the arp table. determine what IP address to give the machine.
the machine should have a nic card with a light on it, if that light is green when you connect the cable, then the nic card is working.
then proceed to install the drivers to the PCs.
Oct 23, 2008 | Toshiba E-Studio 3511 Color Copier
HP 9040n NOT RESPONDING
Try connecting this printer to a different network wall point in the building. If still no change then move back to original wall point and try changing the connection at the Switch end in the comms room.
If still having problems then try pinging the printer to see if it gives time out or execessively high pings. Got a PC on the network and in windows open a "command" prompt and type ping -t XXX.XXX.XXX.XXX where the address of the printer should be place of the x's.
If linux open a console and type the same thing ping -t XXX.XXX.XXX.XXX.
Regards
Please dont forget to rate!
Regards
Feb 28, 2008 | HP LaserJet 9040n Printer
2wire blocking traffic between hosts on internal network?
Are both computers part of the same workgroup/domain?
Nov 28, 2007 | 2wire HomePortal 1800HG Router...
Why do we always have to click repair
What the repair option does is more or less disable and then enable the network connection to refresh the systems settings. This article explains what exactly it does: http://www2.lut.fi/atk/palvelut/PCTUKI/Windows/XP/Repair_NetWork_Conn.html ? Attempts to renew the DHCP lease, if the connection obtains its IP address through DHCP, using a broadcast message. ? Flushes the Address Resolution Protocol (ARP) cache using the command arp -d * ? Flushes the NetBIOS cache using the command nbtstat -R ? Flushes the DNS cache using the command ipconfig /flushdns ? Reregisters the NetBIOS name and IP address with WINS using the command nbtstat -RR ? Reregisters the computer name and IP address with DNS using the command ipconfig /registerdns So if this is what is being done, lets try to trouble shoot each symptom and see what resolves it. My first inclination would be to check your DHCP scope on your server, and see if your scope is running out of space. Also check the lease length and see if it is set to a small amoutn of time. Your PCs could be losing their IP addresses and thus need to get new ones all the time. Are you pinging by IP or name. I would do most of the ping tests by IP as that would remove any of the name resolution issues you may be encountering. Is the wireless brindge doing any type of mac-address or arp filtering? Also, can machines in the extension always ping each other constantly? This would help narrow down the problem to see if it is an IP problem on the hosts or a possible network equipment issue.
Sep 21, 2006 | HP Broadcom NetXtreme 10/100/1000 Network...
Microsoft Windows 98 for PC Logo
29 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
