Question about HP Computers & Internet
In our monitor the above half screen is working properly, but the below half reflects the above half screen after 2 second. what is the problem and how to solve this??????????
  • HP Master
  • 4,924 Answers
First set the auto into the monitor settings ..bypressing the auto setting button ...
After that go to resolution settings by double click the image driver icon in the task bar (tray system ) ..and set a suitable resolution ..
try them one by one until the screen is looking normal ..
The same thing can be changed from the desktop properties...settings ....to do so ..right click on desktop ...choose properties..than settings ...and in there you will have resolution setting ...change them until the one that fits the best ...when you hit the right one confirm the change..and this is all..
Posted on Aug 28, 2010
I tried to use my acer as a second monitor and it is connected to my GTX 550 Ti graphics card just like my Benq monitor. Whenever I turn on my computer the acer monitor shows the acer logo and then s
Incorporating a second monitor is a great Idea, I've used three to four on my workstations for many years. Setting up multiple monitors involves more than just hardware, the card manufacturer's software and operating system is involved. Since you didn't note the OS, I'll assume Win7. First, simply right click the desktop, and select "Screen Resolution" to see a page headed "Change the appearance of your displays," below which show be a graphic that shows both monitors with a number "1" and "2" on each. Arrange them by dragging and dropping them to reflect your physical arrangement. Then, select the fourth drop-down titled "Multiple" Displays" and select "Extend desktop onto this display," then click the "Apply" button followed by the "OK." button. If your hardware and drivers are set up properly, you should have everything working at this point. Your Nvidia software should have installed a control panel item that you can use to make tweaks to your system. You can also contact Nvidia technical support for more detailed, OS-specific assistance.
Jan 17, 2015 | Acer 23" LCD Widescreen Monitor S230HL BD
Only half screen shows, half good, half bright close together lines horizontally at just above center and below
if you plug in an external monitor does it do the same thing? if so you have a bad video card, if not it's either the screen or the wire
Aug 01, 2012 | Samsung Q1U-P01 Notebook
I have a Toshiba Satellite model: A105-361S PSAA0U-01C002 I removed all screws from the base and opened the case to clean and undust the fan because my machine was shutting off after only being on for...
Unplug the power and remove the battery always when working inside the machine. Reconnect the cables and make sure they are properly connected at both ends, if you had static electricity on your fingers when you where working inside there is a chance you may have damaged the mainboard of the laptop. Start by reconnecting those cables again.
Oct 28, 2009 | Office Equipment & Supplies
DUAL MONITOR SHOWS VIDEO ON BOTH
Are you using Windows XP or Vista?
Anyway, you can set the screen properties easily.
On your Desktop, Right-click it and then choose properties. On the tabs, locate Settings. You should be number 1 and 2 there. If your secondary monitor is number 2, there is a small checkbox below those windows and check the box Extend my Windows Desktop onto this monitor. Click number 1 again and then check USE THIS DEVICE AS PRIMARY MONITOR. Apply the settings and then click Ok.
If the above works, congratulations. :)
If not, please do not hesitate to post back so that I can assist you further.
Aug 21, 2009 | Computers & Internet
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
Self-Test Feature Check
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
My monitor do not work right
Are you saying that you can faintly see your desktop or just the reflection of your desktop??
if you are saying you can faintly see your desktop it means that the fluorescent light isn't firing up properly, take it to a repairman or if its under warranty, take it back for a swap or a refund.
Mar 24, 2009 | Dell E152FPc 15" TFT LCD Flat Panel...
Dell flat screen goes white and colored block appears and floats
Check that your monitor is connected properly and tightly to the computer. If it is, then the monitor may be bad. Borrow a friend's monitor and try to see if it works, if someone else's monitor works, then replace your monitor.
Mar 11, 2009 | Dell gx 150 p3...
Wii remote will not follow command.
It's problem a radio interference, since the wii controller uses radio frequences to contact the device, try to resync the wii controller.
1. Turn the Wii console on and wait until the "Health & Safety" screen appears (don't press A).
2. Open the SD Card slot cover on the front of the Wii console, just below the disc drive, and press and hold the red SYNC button for 15 seconds. This will clear all synced Wii Remotes from the console.
3. Resync the Wii Remote by removing the battery cover and pressing the red "SYNC" button. Do this for all Wii Remotes you wish to use, and test for proper response.
4. If the steps above do not work, remove the batteries of the Wii Remote and leave them out for at least 2 or 3 minutes. Reinsert the batteries and sync the Wii Remote again. Test for proper response.
If after removing the batteries for several minutes, and resyncing the Wii Remote, your still unable to get the Wii Remotes to work, try syncing another Wii Remote if available.
* If another Wii Remote works, then your previous Wii Remote will need to be repaired.
Feb 09, 2009 | Nintendo Wii Console
Computers & Internet Logo
138 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
