Gateway MX3231 won't boot and I just bought a new power adapter
My power adapter recently broke,so my battery eventually died. i just got a new power adapter and plugged it in and the computer will not boot,i've taken the battery out and put it back in and tried again, and still no luck. any suggestions? do I need a new battery too? the computer is not very old, just over a year. any thoughts?
  • paiger1222 May 07, 2008
    Also, the original power adapter plug broke off while in the laptop, and for about 4 months the power would go on and off while it was plugged in, switching from using battery to ac every few seconds.
  • 4 Answers
Based on what you have stated, it looks to be your AC connector that is loose or broken from the motherboard. This connector just needs to be soldered back onto the motherboard. Have a technician look at this before you start spending money on a new battery.
Posted on May 07, 2008
Will not power on
MPC has since dissolved, leaving thousands of customers without dedicated support when their Gateway laptop won't start.
Remove the AC adapter from the laptop and attempt to boot the laptop from battery alone. Attempt to turn on the laptop.
Replace the AC adapter and remove the battery from your laptop.
Ensure the adapter is plugged in. Attempt to turn on the laptop.
Disconnect the AC adapter and leave the battery removed from the laptop.
Hold down the power button for 30 seconds.
Nothing should happen on the screen.
Reconnect the AC adapter to the laptop.
Attempt to power on the laptop.
If the laptop boots, replace the battery once the operating system loads.
Try the process again with a new AC adapter and battery if possible.
Contact Gateway support if you aren't a former MPC customer.
Alternatively, take the laptop to a computer specialist if it still won't start.
Nov 19, 2013 | Gateway 17.3" NE71B06u Laptop PC with AMD...
Recently my samsung galaxy s2 fell on the ground and shattered the screen! A day later the phone just died! I've bought and fitted new screen and housing but the the phone still won't charge or...
you need a new phone i think you broke the motherboard in the phone i did this as well and tried to fix it myself when i took it in to get fixed they said that the motherboard was broken and that i just needed a new phone... good luck look at it and make sure nothing else had been disconnected also look at the charge points and make sure nothing broke off and got stuck in there i know simple stuff... but sometimes thats the problem...
Jan 10, 2013 | Cell Phones
Gateway nv52 won't charge
It sounds like you either have a dead mother board or a bad power inlet. Did the machine work with the new battery while it was charged? If so, then the battery connector was good and the inlet was bad. If not, your motherboard could be dead. I've also seen where a bad battery connector would syphon off enough power to not power on the machine or charge the battery.
Nov 14, 2012 | Gateway NV5215u Notebook
Pavillion zv5000 won't boot
Hello.The most common reasons for power issues are the battery, power jack and power adapter/cord.Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.If no change, the power adapter is probably faulty and needs replacement.Hope this helps.
Nov 13, 2012 | HP Pavilion zv5000 Notebook
Flickering power light on gateway 7330 laptop
Return the laptop to the place of purchase, this is a manufacture issue.
Jun 20, 2012 | Gateway 7330GZ Notebook
What is the difference between mx3231 mx3228?
The screens are probably interchangeable. The two laptops have the same size screens, 14-inch Widescreen Ultrabright WXGA TFT. The major difference between them is that the MX3231 has a CD writer/DVD-ROM optical drive. The MX3228 has a dual-layer DVD writer. See https://support.gateway.com/s/Mobile/Q106/MagicLC/1009130sp2.shtml and http://support.gateway.com/s/Mobile/Q106/MagicLC/1008831sp2.shtml for the specs of both of these Gateway notebooks.
I hope this helps.
Jun 03, 2012 | Computers & Internet
Acer 4310 power problem
Sounds like your DC Power Jack where the Power Cord plugs into the computer is bad.
Take an ink pen and push the tip inside the jack and see if the little pin wiggles, if so the jack is bad. You'll have to take the laptop apart to fix it. Most times it is soldered onto the motherboard, so you will have to desolder the old and solder a new one.
If the DC Power Jack is bad, then eventually the battery is going to die and you won't be able to boot your laptop. If the dc power jack is bad, the ac adapter power cord can't charge the battery.
May 20, 2012 | Computers & Internet
Toshiba Laptop Wont Boot.
yes,if the battery doesn't charge with the ac adapter or turn on with it pluged in.it is common on comuters for the power adapter on the motherboard to go bad after a while.downfall of the laptop is that it is very hard to replace it(desktop easy because it is not built into the motherboard)you can either buy a new motherboard or a new laptop.if you got any more questions feel free to email me at gamecrazy944@yahoo.com
Aug 03, 2009 | Computers & Internet
Gateway 450ROG WiFi Not Working
Sounds like you need to look at that board closer. You wifi is not getting power.
Feb 21, 2009 | Gateway 450ROG Notebook
Gateway Laptop M350WVN- not booting at all
it may need to be left on charge for a while...
when u first boot by pressing power wait for a minute or so and press and hold power button til shut down then try reboot..also try boot from disk....need to distinguish whether motherboard or software issue.
Feb 05, 2009 | Gateway Computers & Internet
Computers & Internet Logo
156 people viewed this question
David Payne
David Payne
