Question about Lincoln Electric Ranger 305G K1726-4 Welder
Fuel gauge stuck on full - Lincoln Electric Ranger 305G K1726-4 Welder
Why is my fuel gauge stuck on full even though there is only 50% of petrol in the petrol tank
Hi,it must be that the gauge or sender unit are faulty,check sender unit first.
Apr 09, 2016 | Cars & Trucks
guage stuck in the tank or loss of ground/power to sender..
Jan 04, 2014 | 1997 Honda Civic
2000 kia sportage fuel gauge stuck on full 2000 kia sportage fuel gauge stuck on full
sounds like a faulty fuel sending unit. it reads the amount of fuel located in the tank and sends that info to the cars computer and guages
Oct 27, 2013 | Great Plains Industries Gpi& Fuel Pump
Fuel gauge stuck
Check pig tails for fuel pump
Mar 10, 2012 | 2009 Yamaha Roadliner Midnight
The fuel gauge is stuck on full. what will cause
In most cases a bad or broken ground at the sensor connection at the fuel tank.
Mar 05, 2010 | 2000 GMC Yukon
Fuel gauge stuck on full for my 2000 ford taurus SE
it is probbally the fuel pump in the gas tank. It has a float like the one in your toilet and a sensor attached to it to tell you how much gas you have.
Aug 08, 2009 | 2000 Ford Taurus
Fuel gauge is stuck on full for a 2001 Buick
Gm cars are common for having defective fuel tank sending units in the tank. Yours likely needs replaced.
May 17, 2009 | 2001 Buick Century
Fuel Gauge Stuck on full reading
replace fuel pump/Fuel gage sending unit (All in one) also wire pigtail to asmbly Pontiac Montana's are prone to wire falures and shorts $300+ if done in drive way alot more if you have a shop do it!
P.S. REPLACE ASMBLY WITH AS LITTLE FUEL IN TANK AS YOU CAN...!
May 04, 2009 | 2000 Pontiac Montana
need to replace the sending unit
Sep 19, 2008 | 1988 Ford F 150
Lincoln Electric Ranger 305G K1726-4 Welder Logo
Top Lincoln Welding Tools Experts
Steve
joe2639
Level 1 Expert
Are you a Lincoln Welding Tool Expert? Answer questions, earn points and help others
