Question about Whirlpool Refrigerators
Exterior panel between freezer and refridgerator that magnetic strip sticks to is very hot.
  • Whirlpool Master
  • 909 Answers
Have seen it many times before especially on Whirlpool fridges before. It is not detrimental to the running of the fridge but has the tendency to warp the door fridge seals. In my opinion, when the fridge was piped up, instead of running the high side (hot pipe from the compressor), through the radiator first and then to the fridge body, they have done it in the opposite way. As a result, All the heat from the compressor is going firstly into the fridge frame to eventually exiting and then going to the radiator.(Thats why it is so hot between the doors). To rectify this, you need a technician to swap the pipes over at the back as already discussed, then regass..
Posted on Aug 28, 2010
  • Whirlpool Master
  • 1,606 Answers
Pull the refrig out and remove the back panel . Check that the fan which cools the compressor is working . If so , then check that the coils are clean from the front , of dust , lint , pet hair , etc .
Posted on Aug 29, 2010
Broken freezer door handle
The O in you model should stand for Overlay panel and that would mean the handles were purchased separately to match the rest of the cabinet work. The handle is also mounted to the wood panel. To remove the panel pull the freezer drawer out and look at the metal trim across the top. You should see a strip across the middle of it. That strip is held in with magnets. Put a piece of duct tape on it and it should pull out. If there have been any spills it can cause the strip to stick and you may need a putty knife to help pry it free. Once the strip is out you will see the screws holding the top trim in place. Remove the trim and the panel will slide out the top of the drawer and the screws holding the broken handle will be accessible.
Sep 28, 2013 | Sub-Zero 650 / O Bottom Freezer...
Freezer door does not have the vacuum suction that it did have
Check the door is square to the frame and no shelves are sticking out stopping the door from closing properly. The seal should be magnetic and stick to the frame quite well.Check no metal strips have come off so the magnetic seal isn't attaching to the frame
May 20, 2012 | Frigidaire 20 cu. ft. / 566 liter Upright...
Refridgerator door shutting causes freezer door to open
Check for a draft connecting main body to freezer body, theory is air compression transfer from main compartment to the (smaller) freezer compartment. also a quick fix would be to add more magnet strip or bare the metal that makes contact to the magnet strip that seals the door, if its a latch, Inspect the surface area that locks the latch to mount. Draft checking is achieved by blowing a fan into the smaller compartment, vice versa and having strands of string hanging around in the opposite compartment, if the string nudge indicates an air passage point. Also, check the level of the fridge, if the fridge is uneven (assuming the front is tilted downward) the momentum of the door closing will push the fridge backwards and whip it forward effectively opening the freezer door.
Oct 14, 2011 | Refrigerators
The center wall that runs vertically between the freezer and refrigerator compartment is very hot on the end that is exposed when you open the refrigerator door (hot enough that the magnetic strip that...
Well, that is were a heating wire runs to evaporate condensation at the seal. So it is normal that it gets slightly hot, but if really hot, then call for service
Jun 18, 2017 | KitchenAid Superba® Architect® KSRP22FSMS...
My door won't stay shut. How can I adjust the door or is it a problem with the gasket?
First of all is this top freezer/refridgerator new or has the consumer had it for awhile? If not new, could have frozen food, piece of ice, etc obstructing the door. If you have frost(ice build-up) you could probably turn down the temp adjustment, might not need to be quite so cold, just a suggestion. Open the door and check the seal for damage, there is a magnetic strip in the seal that sticks to the body of the fridge keeping it shut along with vacuum etc. Check seal before calling service (800) # for further advice/ servicing. Good luck, best regards.
Feb 09, 2011 | Haier HRF10 Top Freezer Refrigerator
Kitchen Aid Fridge KSRF25FRBL00 - Hot Panel between doors
This strip is warmed to prevent condensation forming here during humid weather. Some models use a refrigerant pass of the compressor to warm this strip other use a heater that can be controlled by a 2 position switch in the refrigerator control panel that reads something like "Turn this on if moisture appears on cabinet exterior". If you have no such switch you should be aware that the strip is ALWAYS warm but barely noticeable until you develop a problem in the cooling system.
Check temperatures in the freezer (Zero Degrees approx.) and refrigerator (Approx. 30). If these are normal don't worry about the heat from that strip. If you find a temperature not normal you have the beginning of a cooling problem unrelated to that strip.
Aug 20, 2009 | KitchenAid Superba Architect KSCS25IN Side...
LG Refridgerator LFC257060ST Keeps Beeping
Please check whether the doors are aliened properly to the body and if there is a small warp it could result in escaping of cooling resulting in poor cooling of both the freezer and the refrigerator chamber.
The magnetic gasket is the next reason for poor cooling. So please ensure that the gaskets are having magnet attached to the full length. Broken magnetic strip inside the gasket could also result in partial closing of the door leaving behind plenty of gap allowing the cooling to escape.
Just insert a visiting card between the gasket and the body and if you could do so then the gasket is not effective and requires replacement.
Jul 10, 2009 | LG LFC25760ST 25 Cu. Ft. Panorama French...
Water accumulating in the bottm of refridgerator
HI, Now that you have the ice out of the drain, There is an after market drain transfer heat strip kit you need to buy and add.
Please let me know if I can help you. I have the kit on my web site www.whirlpoolpartssurplus.com
Let me know if I can assist you
Thanks
Vic
May 17, 2009 | Refrigerators
Refridgerator top freezer exterior wall hot
Hi.........
Folow these steps. It's worth a try.
1.Pull the fridge out from the wall and unplug it.
2. Clean the dust and lint off the compresser and everything else.
3. Also clean under the fridge.
4. The frame around the freezer door should cool down.
If the cooling fan was stuck , that may also be a cause for your refrigerator wall becoming hot.Check that too.
Hope My info is useful....Bye
Sep 19, 2008 | GE Profile PSW26P Stainless Steel Side by...
Fridge Door not shutting/sticking
the fridge door stays shut only by strip magnets inside the door seal. cause is possibly that the hinges are out of line or the cabinet distorted. try levelling the fridge and tilt slightly backwards
Apr 03, 2007 | Zanussi ZEBF250W Bottom Freezer...
Refrigerators Logo
110 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
