Question about Whirlpool Cabrio WTW6600SBT Top Load Washer
Water well my father in law pressurized my tank and now there is air in the line and dirt coming out of all the faucets. help
    President:
  • 1,294 Answers
You only have to shut the intake valve, disconnect the inlet pipes & clean the filters on the hoses. both sides. If the filters are damaged, replace. Open the wall faucet to let all the dirt come out into a bucket. Refit carefully, open valve. Check for leaks.
To clean your dispenser (where the water enters your machine) you have to refer to your manual. If it is not possible to clean out you have to replace it.
Posted on May 07, 2008
Hot Water Pressure from taps
Hard water deposits from the water heater in the supply lines to the faucets. Sounds like your water heater needs to be cleaned out -- not just drained of water. You need to get inside and clear out the deposits in the bottom of the tank. You also need to remove the hot water supply lines to your faucets and see of you can get the lines to run free from the deposits -AFTER you clean out the water heater. Remove the drain -put on a 3/4 in. ball valve for the drain and a hose bibb on that - you can hook up a 5/8 - or 3/4 inch hose to get the particles out of the drain of the water tank. You may have to blow back the water line, from the faucets, the hot water lines- to get the deposits out of the water lines. You also may have to blow out the faucets with the water line disconnected to clear the calcium out of the hot side of the faucet.
Feb 18, 2014 | Water Heaters
Tank air pressure
Hi Chris...
Normally you set the air first.... but it can be done either way, just be sure that you have about 1/4 of your tank an air cushion, this stops the pump from cycling on and off to fast
Bud
Apr 27, 2013 | Utilitech 20-Gallon Vertical Pressure Tank...
Culligan AC-30 Tank not Filling and Recharge only produces minimal water.
You should change filters and membrane and then proceed. Replace both filters not one. You mat to buy new RO unit that you can find filters on line ie store (less than you are going to pay for Culligan) PROCEDURE FOR RECHARGING REVERSE OSMOSIS BLADDER TANK WITH AIR
When you turn on the faucet you notice low water pressure from the storage tank and only a quick burst of water come out of the system, and it dies down to trickles. Is the tank defective, i.e., bladder has hole and not functioning properly? Perhaps.
If you have the above problem and the tank is heavy (full), then try to relief the pressure from the air valve on the tank side. Is water coming out? If the answer is yes, then the bladder has hole and is defective, and tank replacement is due. If air comes out then it is possible that the air needs to be recharged.
Notes on bladder tank, please continue reading:
RO Tank useful life is 5-7 years. If the tank has been serving you for that long it is possible that the bladder had a hole and that tank replacement is due. If the tank is not that old, it is worth it to evaluate it for air pressure. In an empty tank, air pressure should be 7-10 psi. In a full/heavy tank, air pressure should be 30-40 psi. To be accurate, air pressure should be 2/3 of incoming water pressure. When the tank is full, and if feed water pressure to the RO system is 60 psi, then a full tank should have 40 psi. The RO tank has a bladder inside, and this bladder separates air from water. On the lower side of the tank is the air valve which is connected to the compressed air chamber. The top water inlet/outlet port (where the tank valve is mounted) is connected to the pure water chamber. So, when you turn on the faucet, the compressed air would squeeze or compress the bladder to force the water out of the tank.
You do not want to believe the tank is useless and want to do extra testing? If your answer is yes, please continue reading.
TOOLS NEEDED FOR TESTING:
1. An air compressor or air pump (like a bicycle tire air pump)
2. An air pressure gauge that is able to read less than 10 psi, and
3. Adjustable wrench.
STEPS:
1. Shut off the water supply to the RO system
2. Turn on the faucet to allow water to run until it stops.
3. Check to see if there is still water in the storage tank by lifting the tank. If the tank feels heavy, that means you need to recharge the tank and continue the following steps. If the tank feels light, that means you don't need to charge your storage tank at this moment.
4. Locate the air valve on the side of the tank. It looks like the air valve on tires.
5. Use air compressor or air pump to pump air into the tank. Keep the faucet on while pumping air, so that all water inside the tank can be purged out.
6. After all water has been drained from the tank, use an air pressure gauge to check the tank pressure.
7. The tank should have 7 psi of pressure when it's empty. Add or purge air if necessary.
8. Turn the feed water valve back on, and turn off the faucet to allow refilling of the tank.
9. finished.
What if the tank does not hold pressure and you see the same problem again? Bladder is out and you need to replace the tank.
May 01, 2017 | Tools & Hardware - Others
Price Pfister hot water runs slow
Check the supply line and valve to see if any dirt or foreign.matter got into the line or valve when you changed out your faucet. if this is not the problem you may have a faulty faucet. You may be able to back flush the faucet with a garden hose by leaving the hot side open, but you will get wet. If you used Teflon tape on the supply line and it is a compression fitting, some of the tape could be blocking the water. for more info go to waterheaterflush.com
Oct 16, 2012 | Price Pfister Plumbing
The pressure in my Delta faucet is suddenly low. The pressure throughout the rest of the house is fine. What is wrong? I replaced several pieces of the faucet but nothing worked.
Take the hoses off on the bottom of the faucet and blow air back through the faucet. Dirt can plug up the small openings right where the water enters the faucet. By the way I hope you checked the areator on the end of the spout, Dirt can plug that up also.
Nov 11, 2009 | Delta 2402 Classic Single Handle Kitchen...
Well water comes out brown, low pressure
picking up sediment[silt-mud-dirt] holding tank probably bottom filled with it turn off well and flush out holding and hot water tank if one and install inline filter after holding tank to stop any further debris getting into water lines your pump is sucking the silt up from the well usually happens to places that have had really bad rain season or flooding
Oct 03, 2009 | Plumbing
Is it possible to contaminate the membrane and filters by placing drain under pressure in order to clear and forcing water out the overflow on the side of the faucet of the whre 25 Reverse osmosis system
OK, now I understand. First, on the Reverse Osmosis Membrane Housing Outlet Ports there is only a Check Valve attached to the Permeate (Pure Water) Port, not the Concentrate Port (Drain Water). The Permeate line is what fills the storage tank, so you don't want back pressure from the tank reversing into the membrane filter which could severely damage it. So, there is a high Risk for Sewer Water to Back-flow into the Membrane Filter and Contaminate it as it is discharging water to the sewer drain if there is any noticeable pressure restriction in the drain distribution manifold. Second, this is why "Air-Gap" Faucets are supposed to be used when installing Reverse Osmosis Systems. With an Air-Gap Faucet, there are three (3) attachments for tubing at the base of the faucet, and a small hole drilled out underneath the lever or handle of the faucet. The 1/4" pressurized drain line tube from the RO System attaches to the 1/4" barbed fitting under the faucet base, then a 3/8" drain line tube attaches to the 3/8" barbed fitting. So when the drain water is pumped up to the faucet under pressure, it returns to the sewer line under Gravity, or No Back Pressure. Then, if the plumbing becomes restricted in any way that the RO Unit can't drain into the sewer under gravity feed, the hole drilled in the base of the faucet allows the back pressure to be escaped to the atmosphere, and if necessary drain water out of the hole until the plumbing pressure restriction can be resolved. This eliminates the possibility of a reverse flow pressure situation from occurring. Hope this helps, and you can always visit us online at www.puresafe.com We have filter cartridges for all makes and models of RO Systems, and 1/2 micron filters that no one else in the trade is using at this time. Thanks, Victor
Aug 05, 2009 | Whirlpool WED6400S Electric Dryer
Water system in my Coleman pop up not working
Make sure you have a water regulator connected to the water source before connecting it to your RV or the pressure could blow out your plumbing. The force of the water coming from the faucet can be too much for any RV and a regulator can be purchased from RV dealers, camping world, and even some Wal Marts carry them.
Jun 22, 2009 | Coleman Campers Grill
No water coming out of my filter faucet.
Okay.
Here is what I would suspect at this point:
- Incorrect air pressure in tank, or
- Clogged filters
To check air pressure:
Empty tank and check pressure -- it should be 7 PSI.
Note: There is a rubber bladder in the tank in which the water is stored -- if this bladder is ruptured, the air pressure in the tank will not hold.
So, adjust air pressure, try system again. If it works for a while and then stops, empty tank and check air pressure for 7 PSI.
Clogged filters?
If the system doesn't work when tank pressure is adjusted, empty tank and check pressure again. If pressure is still 7 PSI, then replace filters.
If tank pressure is not 7 PSI at this juncture, it's probably a ruptured bladder and the tank will have to be replaced. But before you take that tack we should "talk" again.
Please let me know the results...
thanks
Charlie
P.S. I'm assuming you have adequate water pressure on your household system. You're not noticing a drop in pressure anywhere else in the house -- is that correct?
May 27, 2009 | Price Pfister 532-7PCC Marielle Pull-Out...
Whirlpool Cabrio WTW6600SBT Top Load Washer Logo
95 people viewed this question
Dan Webster
Dan Webster
Sal De
