Question about Kenmore Dishwashers
Kenmore Dishwasher 1374- Soap dispenser does not open during cycle- soap does not get dispensed
  • Kenmore Master
  • 43,501 Answers
There are three common problems that cause the Soap Dispenser or Cup not to open. I have a tip that will explain these problems in detail....
Dishwasher Repair Problem Detergent Cup does not Open
heatman101
Posted on Aug 29, 2010
Soap dispenser doesn't open during wash cycle
There are three common problems that cause the Soap Dispenser or Cup not toopen. I have a tip that will explain these problems in detail....
heatman101
Jul 23, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
The soap dispenser won't open during the cycle on my 15782 model Kenmore Dishwasher. I am using gel pack soap...so I do not have old soap caked in the receptical. Any thoughts?
Hi
Dishwashers use Bi-Metal strip to allow the dispenser to open/close. This strip when heat up causes the soap door spring to open up the dispenser. If this strip is not heated doesn't allow the door to open. The strip may not be getting 120V or maybe disconnected. Newer (plastic liner) Maytag dishwashers use a wax motor to open the soap dispenser. The plunger inside the wax motor slowly moves and pushes the plunger and door open. And, if this wax motor doesn't receive 120 volts, then it'll not work. Please check the voltage to the wax motor/Bi-metal strip; also inspect the connections to these. Hope this helps...
Daniel
Oct 26, 2010 | Kenmore 24 in. 15782 / 15784 / 15789...
Soap dispenser does not open during wash
Well you can please follow the below steps -
1. Remove any dishes in the dishwasher. Unhook the dishwasher's dish trays or racks from their tracks, and set aside. Empty the soap dispenser if it contains unused soap that failed to dispense. Use a wet rag to wipe down the interior of the dishwasher, as well as the inside of the dispenser.
2. Close the dispenser, and shut the dishwasher door. Turn the dishwasher on to a manual setting, then stop it and open the appliance. Check to see if the dispenser is open. If it is, continue to Step 2. If the dispenser is closed, skip to Step 4.
3. Switch dishwasher soap. Some dishwasher dispensers have difficulty with dry or liquid dishwashing soap, depending on the make and model of your dishwasher. Incompatibilities typically result in the dispenser sticking shut, which explains why the dispenser opens when empty. Switch to liquid soap if you are using dry powder soap, or vice versa.
4. Check the dishwasher soap dispenser's spring. The spring is located behind the dispenser top's hinge. Consult your dishwasher's original manufacturer's manual or user guide to find a replacement spring. Pop the old spring out with a screwdriver, and replace with a new spring. This should resolve any issues related to the dispenser failing to open.
Please post comments if you need more help or information..........
Good Luck!!
Thanks
Jan 08, 2010 | Kenmore Dishwashers
The soap isn't coming out of the soap dispenser during the wash cycle. when i open the dishwasher door the dispenser opens with all of its contents still sitting there!
I had the same problem once. Make sure nothing is stacked in front of the soap dispenser when you close the door. Slowly close the door and follow the soap dispenser to make sure it has enough clearance to open.
Let me know how it goes.
Regards,
Jul 19, 2009 | Electrolux Kenmore 24 in. Built-In...
Kenmore Elite Dishwasher 630 1630 9400 Soap Dispenser Problem
From your description even when the soap dispenser opens it is opening late which is why all the soap does not dissolve.
Try adding only half as much soap and see if it opens then - even a little spilled soap catching on that little latch mechanism can cause it to be difficult to close and stick opening.
Also make sure that the spring that controls the door is not broken.
May 19, 2009 | Kenmore 16602 / 16604 / 16609 Built-in...
Soap dispensing problems on a kenmore dishwasher elite 577-0
is your soap door open when this happens if it is then make sure there's no water or other liquids in the dispenser from loading the washer one tablespoon of water in there will clump up the soap and it won't drop when it pops open
Dec 25, 2008 | Kenmore 24 in. 15252 / 15254 / 15259...
Soap door won't open during wash cycle
its either the dispenser or the timer/pcb.
Mar 01, 2008 | Dishwashers
Dishwasher soap dispenser won't open during cycle
I had the same problem with my GE Adora. The dishes were getting cloudy and the soap dispenser would not open. Turns out the hard water deposits were causing the soap dispenser to stick shut. I purchased and used Dishwasher Magic which is a dishwasher cleaner designed to remove limescale, rust and buildup. I used as directed and now my dishes are sparkling and the soap dispenser pops right open.
Oct 26, 2007 | Dishwashers
GE Monogram DIshwasher
Before taking anything to bits, check you aren't just loading the machine in such a way that something (for us, it's usually a frying pan) is stopping the soap dispenser from springing open all the way. A.
Apr 21, 2007 | GE 24 in. Monogram ZBD6880KSS Stainless...
Dishwashers Logo
291 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
