Question about Kenmore HE2 Plus Front Load Washer
Our HE2 has gotten so loud since we bought it in 2006. It makes a very loud buzzing sound. We get different error codes quite frequentlly and have to restart the thing on a different setting to get it to do anything. What a piece of ****! So expensive and we are very disappointed with it.
  • 530 Answers
You probably have a bad pump and or something stuck in it. take the kick panel off and check your pump filter. more than likly you are getting a code f21,f02,or sud?
when checking your pump filter be prepared with some towels about 4- 5 ccups of water will come out
Posted on Aug 28, 2010
Singer Touch-tronic 2000 makes loud humming/buzzing noise, stitch selector lights quit working, needle bar stopped moving.
Sounds like you've got a thread jam going on in the bobbin case area. Good cleaning and a new needle will probably fix it. See: https://answers.yahoo.com/question/index?qid=20091202121550AAHxN8y
Apr 20, 2014 | Sewing Machines
Makes a really loud buzzing noise during operation
Unit uses a Magnetron and likely a power board called an inverter to run it. Someone would have to open the unit in a way where they might pinpoint where the sound is coming from and then take action--does not of course sound normal or good to me.
Dec 10, 2012 | Samsung SMH1622W
The blower turns off but the unit keeps making a loud humming/buzzing sound intertherm E3EB-015H
It sounds to me like you have a transformer that is going to need replaced before too long.It is normal for a transformer to make a low humminig/buzzing sound that you describe but as they get older sometimes they get quite loud.The good thing is they are not hard to replace nor are they very expensive.
I have seen them just be loose on their mounting screws and you might get by just tracing the sound down and tightening the screws. Thank you and good luck.
Feb 11, 2011 | Intertherm Heating & Cooling
I have a whirlpool duet 2 1/2 years old I t has started to make a loud buzzing hum sound (that sounds like old top loader mixing valve malfunction?) and has error code 5d what is this ?
Actually, your error code is "Sd" and indicates that the washer thinks that there are too many suds in the basket / drum.
Your buzzing sound is also likely to be the water inlet valves, common to top loaders as well, as the washer is adding additional water to rinse excessive suds out. Check your supply hoses for kinks, connections for scale buildup inside, as well as the screens on the inlet ports of the washer itself.
A kinked or restricted drain hose can also throw an Sd error code as well.
Jun 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Buzzing/Ratcheting sound while drying
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 19, 2009 | Kenmore HE2 Plus Front Load Washer
Does the quinny buzz seat 2006 and carrycot fit the 2008/9 frame
Hi new frame should be ok, the only frame that is different is the older 2005 frame, if you remove your seat unit and check the posts on your seat unit (the bits that slot onto the buzz chassis) if they are both the same and have rounded ends then this is the older model and wont fit the newer frames, but if one of the posts is rounded and the other is shaped like a turret then all the frames 2006 onwards will be ok. :)
May 16, 2009 | Quinny Buzz Jogger
Opening the Quinny Buzz
It sounds like your gas is running low. if you registered with Quinny when you bought it they will fill this up for you free of charge, best to contact them on their website.
Feb 04, 2009 | Quinny Buzz Jogger
Kenmore HE2 Plus Front Load Washer Logo
119 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
