Question about Dishwashers
Kenmore Dishwasher Model 665 stops cycle and a message appears on the control panel that says Delay water heat.
The top shelf of my Kenmore dishwaher Model 665 will not come clean - the bottom rack is AOK . Can anyone suggest a possible problem - do I need to call a repair person?
Posted on Aug 14, 2008
How to reset Kenmore Elite 665-16572202 Dishwasher...clean light blinks 7 times pauses then repeats. My model does not have a Heated Dry button it has an Air Dry button.
Here's the key sequence(s) to use, depending on how your keys are labeled:
Heated Dry - Normal - Heated Dry - Normal; or
High Temp - Air Dry - High Temp - Air Dry; or
Hi Temp Scrub, Energy Saver Dry, Hi Temp Scrub, Energy Saver Dry; or
High Temp Wash, Heated Dry, High Temp Wash, Heated Dry.
This will start the diagnostic cycle. Let the dishwasher run for a few minutes, and then press Cancel to stop the dioagnostic cycle and clear the error. Please note, that this clears the error, but if you haven't found the cause (water-not-heating error), the condition will come right back the next time you run the dishwasher.
Jan 19, 2015 | Kenmore Dishwashers
Kenmore dishwasher 665-1703 wont stop washing
Unfortunatly you are looking at the timer which is now built into the controller which would need to be replaced. If the relays are fused shut on the timer or the gears are missing some teeth then you will only get sofar I the cycle and the washer will just stay where it's. Sorry
Sep 08, 2012 | Dishwashers
Kenmore Dishwasher has died part way through a wash cycle.
The control module has failed, you can check for broken solder joint s or obvious damage but it's hard to diagnose the exact cause remotely.
Mar 12, 2012 | Dishwashers
Kenmore 665 no lights on panel water in bottom
This is commen with these. you need to take the door and remove the screws around it. You need to gain access to the controller. on the controller you will see a white peice with 2 balck wires going to it that is your fuse. replace this and that will solve your problem.
Jun 02, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Kenmore dishwasher skips the wash
Replace the electronic control board.Its located under the panel you select cycles from.
May 20, 2008 | Dishwashers
Kenmore Ultra Wash Dishwasher; Model 665.17539
I have a Kenmore 665 about 3 years old
Over the last couple months the touch pads have stopped working and I am now down to one control the water miser!
Do I need a new control pad and is that easy to install ?
Thank you for any sudgetstions
KC
Jan 15, 2008 | Kenmore 24 in. 16032 Built-in Dishwasher
Dishwashers Logo
829 people viewed this question
Top Dishwashers Experts
