Question about Microwave Ovens
AEG HK654070XB manual - Microwave Ovens
How can I get a user manual for AEG convection oven Model # EW 64 L
http://kitchen.manualsonline.com/manuals/mfg/aeg/bp5003021.html Type in your model # in the search bar :-)
Dec 27, 2017 | AEG Microwave Ovens
I inherited a Vitamix Super Total Nutrition Center, Whole Foods VMO 103. There were no manuals or video and no recipi guides. Can these be purchased? My best friend has a 5000 and loves it. Thanks!
What you need to do first of all for the problem to be easily be solve is to know the serial number of the (your) oven written on the recipe or some time on the manufacturer stinker either at the back or under the of the oven, after all this have been know to you then you should visit the below address to get your oven the best manual for your oven
www.usersmanualguide.com/aeg/microwava
/www.usersmanualguide.com/aeg/dishwashing
Thanks.
Jul 28, 2011 | Microwave Ovens
My AEG Micromat_Combi microwave has started coming up with an E14 error message, have you any ideas please.
The motor opening some air valve is probably stuck. See "AEG “micromat_combi 635” halts with error E14. What to do?" at http://appliancewiz.com/questions/47/aeg-micromatcombi-635-halts-with-error-e14-what-to-do for some images and instructions.
Oct 31, 2008 | AEG Microwave Ovens
Door latch has broken and is stuck inside locking mechanism
I'm not familiar with non-US models, but you would probably have to use needle nose pliers to pull it out.
If that won't work, you'd have to remove the outer cover of the oven, and then you can see how the door latch heads (the hook-like devices sticking out of the door) interact with the door latches and the opening mechanism.
Then you can call AEG at the number in your manual to see if they will sell replacement parts.
If you don't have the manual / IFU, then I would suggest contacting the manager at the dealership from which you purchased the oven to see if they have contact info for AEG.
To replace your latch heads, normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
Oct 19, 2008 | AEG MCD343EUM 750 Watts Microwave Oven
ENLIGHTENMENT ON AN ERROR CODE
The first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Otherwise, your best bet is to contact AEG customer service here:
http://www.aeg-electrolux.co.uk/node137.asp
I'd bet that customer service will not know the meaning of the code (if it's not in your owner's manual) and they will steer you to a service center.
The service center will probably not tell you what the code means, preferring instead to repair it for you.
Good luck.
We're happy to help and we appreciate your thoughtful rating of our answer.
May 26, 2008 | AEG MCC663 Microwave Oven
Microwave Ovens Logo
82 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
