Question about Dynamode RADSLC4WG Wireless Router (r-adsl-c4wg)
Ive lost my password to my router - Dynamode RADSLC4WG Wireless Router (r-adsl-c4wg)
I am unable to connect my iphone 4 to my router as i dont know the password, ive tried Administator and leaving it blank are they any other stand ones or will i need to reset the password?
Putting "admin" often works. Looking under the router for a sticker might reveal a password. Resetting it can be an option, but if it is a newer router, you might be lost because they don't usually have easily recognizable default passwords. They usually, nowadays, have unique passwords that are put onto the bottom of the router. Good luck.
Jul 27, 2011 | Computers & Internet
Ive lost my password on my laptop and reset my router to factory settings. So now my dell 1410 vista tells me it wont connect to an "Unsecure" network. Can i reset my laptops password for the...
1. you will need the original CD to setup the router again and set a new password for the router.
2. go through the set wizard which will prompt you with additional steps to setup router and other wireless devices
you will need to contact your provider for additional help such as ip address and ssid information.
Jun 13, 2011 | NetGear WGR614 Wireless Router
I recently changed the security type of my netgear router from WPA to WEP and i lost the keys to connect it. Now my router will not let me connect to it let alone connect to the internet. Ive tried so many...
In order to get your router back to the original settings, you must push in the reset button (usually on the back of the router) for somewhere between 10 and 30 seconds depending on the router. You may need a pin or something small to push in the button, because it can be recessed. Once you have reset the router, the username and password will be changed to the defaults, u-admin p-and password or u-admin p-1234, respectively. One thing you must remember is that resetting the router will change all of the router settings back to the factory settings. This means you will lose all of the changes you made since you got the router. Make sure to write down any things you've changed, so you can change them back after the reset. Also, I recommend updating to the latest firmware after the reset.
Jan 30, 2011 | NetGear WGR614 Router
I lost my internet password that had my internet code on it and now I cant get on to my I pod touch's internet I went to your website and tried this thing on changing admin password it didint work ive...
Try setting the D-Link back to factory specs. There is a small hole near the power cord that you can stick a straightened paper clip in to depress a micro switch and hold for about ten seconds with the power on. This will cause the router to forget its setting and revert to factory default, where the router will work with a default name that you can se but will not have a password. you must access your router later and install another password (Net Work Key) in order for the general public not to camp on your net work. See http://support.dlink.com/emulators/di524_revc/h_wizard.html
Jan 06, 2011 | D-Link AirPlus DI-524 Wireless Router
Network key
look on the back of the box and see if there is a reset button. Push that for 10 seconds to reset the router to defaults. You'll reset the password but need to res-etup the router to connect to the internet.
Nov 30, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Ive lost my password for my wireless internet how do i get it back
Power up the Netgear router and press the reset button (you need a sharp pointer) on the back of the router until the LED lights flash.
The router will now reset to the factory defaults.
The wireless router can now be configured.
Sep 26, 2009 | NetGear DG834G Router
Ive been using my laptop on a wireless net work (belkin54g0 and now Im locked out Idont have any idea what to use for a password
are you saying you lost your wireless key ? if you have no idea what it is, the only solution is to reset the router. this will bring it back to factory defaults.
Hope this helps
Thanks
Ranjit ranjit@supportminds.com
Aug 05, 2009 | Belkin (F5D7231-4) Wireless Router
Wireless connections showing up as ethernet connections
just change de wed key
go 192.168.1.1
user admin
password password
Jun 18, 2008 | Actiontec GT704WG Wireless Router...
Lost disk for d-link router
Also, if you do a IPCONFIG/all in command prompt (Start, Run, CMD). you can note down the Default Gateway address.
then put that into a Web browser and you will be on the Login page for your Router. If you remember the user name & password you can go in that way and secure it.
the default usr name & password is listed at this Link:
http://www.phenoelit-us.org/dpl/dpl.html
go to the exact model #. and use the defaults. If that doesn't work (you may have changed the defaults & forgotten it)
go to the following support site and download the Latest drivers or software you need.
http://support.dlink.com/downloads/
Good luck,
DjEnigma
Apr 02, 2008 | D-Link AirPlus DI-524 Wireless Router
Dynamode RADSLC4WG Wireless Router (r-adsl-c4wg) Logo
Top Dynamode Computers & Internet Experts
David Payne
David Payne
Are you a Dynamode Computer and Internet Expert? Answer questions, earn points and help others
