STAIRVILLE DC-405B - Televison & Video
Raypak model c-405b-en not heating. Flames coming on but hot water not circulating to pool.
check manual bypass by plumbing round plug the spring might be broken then water bypasses heater
Nov 23, 2015 | Raypak Pool & Spa
Tip
ERROR codesCanon 7050
Canon 7050 E000 Heater (Reset by unplugging machine) E001 Heater triac, DC controller, AC driver (reset by unplugging) E005 Fuser cleaner belt at end. Replace. E010 Main motor, DC controller or DC driver board E011 Any motor ( main, scan, cleaner belt, duplex, toner, lens) DC driver, DC controller, duplex driver board. E020 Toner out signal has been sent for at least 3 minutes E050 Duplex E203 Scan motor, DC driver, DC controller E210 Lens home sensor not actuated or won't deactuate E240 Controller board E241 Controller board E242 Controller board E400 DC controller, Doc. Feeder board, 24V power supply E500 DC controller, sorter board, 24V power supply
on Jan 19, 2010 | Office Equipment & Supplies
How the SMPS is working in telecom? What are the functions of SMPS? How it is Converting AC to DC? What are the parts are there inside the SMPS and their function?
smps involves ac to dc and dc-dc switching at high frequency because the type of a transformer in smps is a high frequency transformer and a current gain due to the ferrite application.to do a dc to dc switching you need a mosfet,smps ic e.g uc3845,dc capacitor and some passive components.
Aug 31, 2014 | Eaton Powerware® 9120 UPS System
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
I HAVE LOOKED EVERYWHERE FOR A BATTERY FOR MY ADVENT DIGITAL CAMERA (ADV 1182E) BUT NO LUCK. CAN ANYONE TELL ME IF ANOTHER BATTERY CAN BE USED??.
Three years ago a guest on FixYa wrote this:
quote
Here's a list of cameras that use the same battery.
ADVENT:
ADV1172E
BENQ: BENQ:
DC C500, DC E43, DC E53, DC E63+, DC E720 DC C500, DC E43, E53 DC, DC E63 +, DC E720
KONICA MINOLTA: KONICA MINOLTA:
DiMAGE E40, DiMAGE E50 DiMAGE E40, E50 DiMAGE
PREMIER: PREMIER:
DS-4331, DS-4346, DS-5330, DS-5341, DS-6330, SL-6, SL-63 DS-4331, the DS-4346, the DS-5330, the DS-5341, the DS-6330, SL-6, SL-63
ROLLEI: ROLLEI:
Prego DP4200, Prego DP5200, Prego DP6200 Prego DP4200, Prego DP5200, Prego DP6200
End quote
Nov 27, 2010 | Cameras
I want to know the meaning of code 6010,6013 and 7018.
The first two numbers are the streangth. (60=60,000lbs) the 3rd is the posititon 1 : Flat, Horizontal, Vertical, Overhead.2 : Flat and Horizontal only.3 : Flat, Horizontal, Vertical Down, Overhead. The fourth digit is the current and coating 1 : DC:ROD+ ................... cellulose sodium
2 : AC or DC:ROD+ or DC:ROD- .. cellulose potassium
3 : AC or DC:ROD- ............. titania sodium
4 : AC or DC:ROD- or DC:ROD+ .. iron powder titania
5 : DC:ROD+ ................... low hydrogen sodium
6 : AC or DC:ROD+ ............. low hydrogen potassium
7 : AC or DC:ROD+ or DC:ROD- .. iron powder iron oxide
8 : AC or DC:ROD+ ............. iron powder low hydrogen See this attached link:http://www.jeep-l.net/info_jeep/weld_rod.htm
Jul 04, 2010 | Welding Tools
If I wanted to replace my Raypak C-405B-EN pool heater with a Jandy pool heater what model would be the best fit....
Jandy makes a 400 model that's comperable. Can I ask why? Laars use to be standard but that time is long gone. Ray-Pak is the leader in the industry for long life technolegy. Pentair and Hayward make some of the best on the market. I'm not telling you what to do but it could be worth your time to shop around for such a big ticket itim.
Jun 23, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
Intermittent dc jack connection for Gateway mx3215
Here is how to disassemble Gateway laptop,
Here is replacement DC socket (needs soldering),
Here is DC board (no need soldering, but expensive).
Hope this helps.
Mar 17, 2009 | Gateway MX3215 Notebook
Advent camera battery charger
ADVENT:
ADV1172E
BENQ: BENQ:
PREMIER: PREMIER:
ROLLEI: ROLLEI:
Hopefully this will broaden your options when searching for a compatable charger.
Mar 23, 2008 | Cameras
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
