Question about Carrier 38BRC060 Air Conditioner
The fan on my Carrier central air conditioner a/c model 38ER036300 does not move when the compressor kicks on. The unit will heat up and then will start. It also will start when I give it a small push. The 30 amp circuit breaker will also vibrate for about 4 seconds and then will be fine.
  • Stan Gracyalny Aug 28, 2010
    Should the fan blade move freely when the unit is off? It seems to have resistance. Does it need lubrcation or is it a sealed bearing?
  • Carrier Master
  • 43,501 Answers
The capacitor that gives the fan motor the "kick" to get it started is bad...that capacitor is localed in the electrical compartment and is often a dual capacitor with the compressor. If there is only one cap in there iwth three terminals then it is a dual one if there are two caps in there then the small one or the lower number mfd one is the cap for the fan motor...
Anyway, you will need to find and replace the cap with the same size in mfd's and voltage. both values are printed right on the side of the cap. mark the wires as you remove them so that you know where to get them back on the new cap.
heatman101
Posted on Aug 28, 2010
  • 2,272 Answers
The condenser fan supposed to rotate whenever you turn the air conditioner on cooling mode (regular air conditioner units).
No, it not supposes to spin if it not on cooling mode. Is this regular central air conditioner units or heat pump?
The main purpose of the condenser fan is to help dissipate the heat from the condenser coils. If the condenser fan is not rotating, you either don't have power to it, the capacitor ruin or the condenser fan motor need to been replace.As you said that it spins when you give it a small push so this indicates that there is power but the motor is weak and that is causing the problem.
Check out.Thanks.
The fan on my Carrier central air conditioner a/c model 38ER036300 does not move when the compressor kicks on. The unit will heat up and then will start. It also will start when I give it a small push. The...
Hello YES the blades have to move freely.If it has oil ports look on the side of the motor for a YELLOW plastic plug/cap there are 2 one at the top & one at the bottom.Pry them off/loosen with a small screwdriver & squirt #20 oil in the holes.3 in one oil will work also.If there are no plugs it is factory sealed & it is new motor time.
Aug 28, 2010 | Carrier 38BRC060 Air Conditioner
The fan on my carrier a/c model 38brc060360 does not move when the compressor kicks on. it will start of i give it a small push
That is probably just a bad capacitor...that is what gives it the kick to get it going...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Aug 17, 2010 | Carrier 38BRC060 Air Conditioner
Neither A/C compressor or fan coming on in ouside unit.
The bulge is a telltale sign of a defective capacitor along with the tripped breaker. Replace it and cross your fingers.
Jun 21, 2010 | Carrier 38CKC036 Air Conditioner
Very hot outside. blower comes on but outside fan
Check the voltage source for the fan and compressor
Check the start capacitor for the compressor.If its over heating :bad compressor
Jul 05, 2009 | Carrier 38BRC036 Air Conditioner
Fan wont turn off
the control board is bad safety feature of carrier board . Tom
Jun 29, 2009 | Carrier 38CKC042 Air Conditioner
Carrier central ac high efficiency
usually capacitor,burnt wires or bad compressor.kill the power and check the terminals at the compressor.they have been known to burn off if the connection is loose.
Sep 06, 2008 | Carrier 38CKC042 Air Conditioner
Carrier central ac model 38EN036300
If you have an electronic thermostat, they can short out, leaving the compressor running. Also, the big relay that runs the compressor can get its contacts welded together. See if the contacts are stuck closed.
Jul 27, 2008 | Carrier 38CKC036 Air Conditioner
Central Air Conditioner
Turn the power to the indoor unit off. Remove the cover where the fan is. Feel the motor of the fan. If it is very hot the bearings have likely gone out. If the fan is cool to the touch I would call a service company because you likely have an electrical problem that will require some training to solve.
Jul 09, 2008 | Carrier 38CKC042 Air Conditioner
Carrier 38BRC060 Air Conditioner Logo
266 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
