Question about Vacuums
My electrolux pronto 2 in 1 vaccum is not charging when i put it in the stand charger?
  • 2692 Answers
SOURCE: Electrolux Pronto 2-in-1: Looking for a part
Here is their on-line store to get the parts that you needed.
http://electroluxservice.stores.yahoo.net/
Posted on Jan 02, 2009
SOURCE: Electrolux Pronto 2-In-1 Stick/Hand... Problem:
www.stickvacrecall.com
Posted on May 07, 2009
SOURCE: My Electrolux Pronto is not charging. When I put
Call electrolux there was a battery recall
Posted on Apr 17, 2010
SOURCE: can the battery be replaced?
No but there was a recall on the battries, so try calling electrolux usa and they should replace it for free.
Posted on May 01, 2010
  • 3 Answers
SOURCE: Electrolux 2-in-1 Pronto does not hold charge, I
The battery replacement for the PRONTO is not a consumer level maintenance procedure.
However, I just replaced the 4 original EMX1600sS batteries by anotther model with the same specs and my PRONTO is working fine now. The battery model is
Tenergy 2/3A Size Rechargeable Battery 1.2V 1600mAh NiMH W/ Tabs
Those are a little smaller than the originals but with the same capacity of 1600mAh and can be easily found in the web.
There are other similar models available that could be used but have in mind the limitations for the dimensions and capacity in mAh.
The dimensions of the original cylindrical batteries are aprox. 33 mm (1 1/4") X 22mm (7/8").
Anything under those specs should work.
Good luck.
Posted on Dec 08, 2010
Charger Specs
You can go to the website of Electrolux and put in the model and get a manual for the unit in question...in the manual it should give you the electrical characteristics of the unit.
Aug 28, 2013 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The blue light doesn't stay on. What do I do?
Hi Alec from VacuumSpot here. In Australia these are sold as the ergo rapido. The most likely culprit is the charger itself we sell loads of Electrolux Ergo Rapido Chargers basically the best bet is to measure the output of the charger to see if it is working properly (watch video) if it isnt then simply replace the charger. If it is then replace the vacuum handset - Electrolux have made the handsets real cheap so you dont have to do a repair on battery or motor.
Oct 26, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Electrolux 2 in 1 Ergorapido stick Vacuum. Motor runs then cuts out after 3 - 4 seconds. Sometimes it will run properly for 10 minutes so batteries are good. Why does it cut our usually?
If the hand held is working correctly (By itself) try pulling up a little bit on the 4 metal connection tabs on the wand. The connection tabs were not making a proper connection on my unit.
Oct 20, 2012 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
The blue lights on the charger base for the pronto stick vac go out after about 5 seconds and the vacuum is not working. What do I do?
check that the contacts are connecting and are clean of debris. If they are you can check the charging plug to confirm it is putting out 15v if not replace the charging plug. this is a common problem. you can get parts online at http://www.vacpartswarehouse.com/Electrolux-EL1000B-BZ-Pronto-Stick-Vac-s/3734.htm?gclid=CKDFg_3Jv7kCFc4-Mgody1wAjg
good luck
Oct 21, 2010 | Electrolux EL1000A2 Pronto Bagless Stick...
I have the Electrolux Pronto 2-in-1 Vacuum and need a new charger Where can I get one as soon as possible Thank you
This is a good URL for your part
http://www.ereplacementparts.com/electrolux-parts-c-109672.html?osCsid=ip7otskdiu58aaud0fgvvv1f57
Oct 12, 2010 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
Lost charger
You have to call electrolux and order one their numbner 800-896 9756
Jan 18, 2009 | Electrolux EL1000A2 Pronto Bagless Stick...
Vacuums Logo
52 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
