Question about Samsung SM920NW 19 inch LCD Monitor
The last time I turned on my pc the monitor worked perfectly, and when I turned it on now all i get is a black screen. Do I have to replace it? :unsure: I've had it since december 2006 and it's the SM920NW 19 inch LCD Monitor. I also tried connecting the screen to my laptop and there was no difference.
  • 11,361 Answers
More likely to be failed caps in the power supply just like the rest of SAMSUNG monitors as shown here.
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you
Posted on Aug 29, 2010
Why is my dell inspiron 531s stuck on black screen with input not supported message?
Start pc in safe mode and try to change resolution.
Then update the graphics driver.
May 06, 2014 | Dell Inspiron 531s Desktop Computer
Technika white screen lcd
Hi
to test if the lcd screen is faulty or if its the inverter
plug in another monitor to the external monitor plug
when you turn on the laptop if the 2nd monitor displays the desktop your lcd needs to be replaced
if the 2nd monitor is also black your inverter needs to be repalced
aries
Oct 19, 2013 | Computers & Internet
Pc sleep mode wont wake up
Try plugging in another working screen with a new cable, and if it didn't work then it might be your Graphic card (built in) (and does your screen work only when u turn on your computer for 5 sec or all the time its black screen?)
Jul 02, 2013 | Computers & Internet
Monitor suddenly went black.If on/off button pushed screensaver briefly flashes on but then back to black screen.Green power light is on but nothing on screen when using computer
Try to replace all bad capacitor on power inverter board and turn it on. Hope it will work perfectly.
Thanks for visiting FixYa. We answer your question for FREE. Please feel free to click on "YES" button in return. Have a good time...!
Thanks
Jun 28, 2011 | Hanns.G Corporation HW191D 19" LCD Monitor
I have a compaq FS940. It worked perfectly fine until a recent move were we had to diconnect everyhting. When i reconnected it all my monitor just instanlty goes to sleep. My modem works fine but the...
mdl34, Your monitor is listed as "time to retire" and get new unit on retrevo .com You might try "reseating" all the connections to the monitor and vga connector on the pc. examine all the connector "pins" in the cable connector and note any damaged or bent, crushed pins. Try moving monitor to a "known-good" fully booted pc to see if same problem occurs. Swap-in a good monitor to your pc to prove that pc is operating correctly. 12fixlouie
Aug 07, 2010 | Compaq Computers & Internet
Monitor black Replaced lcd inverter
The Inverter just proved that the power up is just fine, and Video Card are just in perfect shape. Try to see if you can finde a replacement for the ccfl in the screen.
CCFL is Cold Cathode Flouroscent Lamp, a type of lighting LCD screens use to ulluminate the screen.
Try to turn on you laptop, you will then flash a light on the screen, you will notice there is display, only dimmed. This should work after you replace them just fine. :)
Apr 26, 2009 | Dell Inspiron 1501 Notebook
LG 710s monitor problem screen turns green
Your AUTO settings button is stuck in! Try tapping on it a few times. Otherwise you may have to take the frame apart so you can get at the button.
Dec 28, 2008 | Amptron AMV 17V5 17" LCD Flat Panel...
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Black out
Connect it to another PC, if you get the same result, the problem is the backlight, they go all of the time. I am constantly repairing these things in stores.
Oct 20, 2007 | BenQ FP731 17" LCD Monitor
Good picture for 30 seconds then screen goes black with a faint ghost of the image
i hope the problem will be in LOT of the monitor...you need to replace the LOT
Jun 14, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Samsung SM920NW 19 inch LCD Monitor Logo
66 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
