Question about Roper REX4634KQ Electric Dryer
Their is a squeal in the rotation, which diminishes after 5 or 10 minutes, but never completely quits.
    President:
  • 1,430 Answers
It could be several things, drum rollers, idler pulley, belt, or felt seals, blower wheel. Here is a couple links that should help http://appliancehelponline.com/dryerrollervideo.html
http://appliancehelponline.com/dryernoisyge.html
Posted on Aug 28, 2010
How can I figure out what's squealing? Where can I find belt diagrams?
I had something similar with two seperate vehicles after replacing everything I could think of it turned out to be a bad bearing in my alternator on both vehicles.
Aug 04, 2014 | 2005 Hyundai Elantra GLS
Squealing sound when it starts cycle. it quits about 1-3 minutes after.
depending on the exact model, this could be your pump on reticulate mode (I W model). when they start squealing like this, it can often lead to overheating, which will make the whole machine stop cycling.
Sep 28, 2013 | Fisher and Paykel Washing Machines
My maytag dryer has a loud squeal. I replaced the belt, but the squeal persists
Check to see if the belt has landed in the groove instead of on the outside of the drum. One might assume that the groove is there for the belt, but inspection of the drum will show previous belt location about an inch beside it. To fix, rotate the drum counter clockwise while pulling the belt away from the groove on the bottom of the drum. Once it has rotated a complete revolution, it should be in alignment and the noise should disappear.
Jan 14, 2011 | Maytag MDE8000 Dryer
All,dash lights came on-gas,all,then power dies down,lights conitually go dim,car quits running,before this i heard a squealing noise,what is going on w/car
Could be a bad alternator diode and it wasn't keeping the battery fully charged, which could be indicated by dimming lights, loss of power, or completely quitting when voltage becomes too low to properly fire plugs.
The squealing could have been a locked up alternator (probably caused by a bad bearing) and the drive belt is slipping on the drive pulley, making the squeal.
Hope this is of some help.
Dec 26, 2010 | 1998 Kia Sephia
Amana Electric Dryer Model NDE 7800YW squeals when running will quite after 5 to 10 minutes
my amanadryer will run for 10 minutes and then start squealing and quit.wait 15 minutes and it will restart and do the same thing. any help???
Mar 09, 2010 | Dryers
How do you turn off the tire pressure synsor?
BMW sensor on your air pressure, in fact, no! information about whether there is pressure or not the calculated DSC computer from signal ther you give sensors ad the ABS. function is quite simple. ABS sensors constantly monitor how the wheel rotates and each DSC unit calculates the signal and recognize the differences in wheel rotation. When the pressure is not air physically rotated more than a round where the air pressure is due to changes in area of circumference empty rounds that diminishes and puffy round is larger in ! Security systems from BMW are really so perfect that even a slight difference in rotating do to reveal! Reset can be found in your board computer and no need special types and tricks it in the car seting menu. This is standart function
Feb 16, 2010 | 2006 BMW 3 Series
M & S Systems MC350A - intercom dial if rotated will squeal
no, but I have exactly the same issue - did the original poster get a solution?
Jan 18, 2010 | Audio Players & Recorders
Dryer squealing?
you need to replace the felt around the door if it is not this it is in the motor and I would just use it tell it dies then replace. thank you for using fixya
Jun 19, 2009 | Maytag MDE308DAYW Electric Dryer
Upper freezer is squeling
The most likely cause of the squealing is the eveporator fan motor. It may continue for quit a while before it finally quits. When it stops completely the evaporator coil will freeze solid and there will be no air blowing from vents to refrigerator.
Dec 20, 2008 | Whirlpool Refrigerators
Squealing NOISE possibly from fan belt
Belts stretch from new. Try to tighten them again. Hopefully the are not glazed or this may stay with you.
Dec 14, 2008 | 1988 Dodge Grand Caravan
Roper REX4634KQ Electric Dryer Logo
43 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
