Question about Kenmore 44102 Front Load Washer
Kenmore front loader trouble
Front loader not draining or spinning. shuts off after a few seconds. Sears said it's the control board but the young man wasn't here that long to figure that out and they want 350.00 to fix it.
Help.
  • 172 Answers
If it is shutting off after a few seconds is the washer filling with water. If not you may need a water valve. If it fills with water then stops you may have a bad control and $350.00 is not really to bad for that repair. Besides if he is wrong he is stuck with the part not you. If he is correct then your washer is fixed and $350 is alot better than $1200.00 for a new one, so check that water and good luck to you. Mike
Posted on May 07, 2008
Control locked light is on. Have replaced control board but control still locked
This advise is for Kenmore Elite and Whirlpool Duet front loader washers and dryers with a Control Lock problem.
This may or may not be an indication of a serious problem. In the majority of the cases, this is a simple operator error. Nearly all these model appliances have some sort of Control Lock feature on the front panel now. This is a designed safety feature that is used to prevent small children from manipulating the controls. The controls can be easily locked or unlocked by pressing and holding the following button on the front panel:
Whirlpool Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 3 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 3 seconds.
Kenmore Elite Dryer - Press and hold the AUTO DRY LEVEL button for 3 seconds.
These instructions may not be all inclusive for all Kenmore and Whirlpool models, but they are the most common. Chances are, if you have a Control Lock feature, the instructions will be printed on the front panel adjacent to the button that is required to lock or unlock the controls.
NOTE: These instructions may also work for newer model Maytag, Hotpoint, Admiral and Fridgidaire model front loaders as well. Refer to your owner's manual or front panel for instructions pertaining to your sepcific model.
If the Control Lock feature will not lock or unlock the appliance, unplugging the unit for AT LEAST 30 minutes is recommended in order to reset the main control board. In many cases this is all that is required to correct momentary glitches.
Hopefully, this simple advice will save you an expensive service call.
May 28, 2015 | Whirlpool GEW9250 Electric Dryer
WhirlpoolGB AWO 3751 Door firmly shut but red door locked indicator starts to flash and programme will not start.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 21, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool duet washer GHW9300PW4 .... The control lock is on .. I did get door to open, It will not shut off and none of the cycles will light up or start.. Please help..
Aug 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore front load washer: 4172952990. Does not spin. Clicks... at the beginning of a cycle it will spin for a few slow spins, then nothing. Had the Sears technician in. Said that it was the Speed...
Our kenmmore front loader is having a problem with the pump. When it empties there is dirt with the water. Is there any way I can get at the pump and clean it? It is working 70% and as long as I have the drain hose on the ground the water will drain. When I shake the hose dirt comes out and sometimes it says F21. Can anyone help.
Oct 11, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore HE4T Front loader control lock indicator light is on and will not let me use any other controls.
Sep 05, 2009 | Kenmore Washing Machines
Kenmore front loader Model 48102 will not start
Mar 14, 2009 | Kenmore Washing Machines
Kenmore front loader washer model 11042822201 drain and spin
Based on what you said about clicking noise from pump and pump getting hot (this pump is liquid cooled-sealed) I would recommend replacing the pump first then the control board. Board is located on top right front corner, not inside console area, simply slide the top back to see this. unit slides back to unmount. however as I said before this code did not exist and usually means bad board and this is common on whirlpool made machines. you do not need buy this from sears, use sears for part numbers these are whirlpool numbers.
Mar 12, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front loader washer model 11042822201 won't drain and spin
As I have not received a response, I'm assuming these hints have taken care of your problem. If you have any more troubles, feel free to drop me a note back.
Jun 30, 2008 | Kenmore Elite 45986 Front Load Washer
you need to replace the speed control unit (board) in the lower right corner in the back of the washer it is faulty
Jan 24, 2008 | Kenmore 44102 Front Load Washer
Kenmore Front Loader-Doesnt Aggitate nor Spin
the speed control board needs to be replaced in the lower rirght corner of the washer
Sep 12, 2007 | Kenmore 44102 Front Load Washer
Kenmore 44102 Front Load Washer Logo
Ron Lankford
Archaeology
Archaeology
reliableservice
