Question about Dirt Devil POOL CLEANER FOR ABOVE-GROUND POOLS
How do you hook the vacuum up? the instructions got soaked and i don't know how to use the vacuum for the pool.
  • 640 Answers
Here is a copy of the users manual for these pool cleaners. It has setup instructions and should help you get your cleaner running properly.
http://www.backyardcitypools.com/images/BWP/Dirt-Devil-D2000-Manual.pdf
Posted on Jun 15, 2011
WHAT AND HOW DO YOU VACUUM INTEX ABOVE GROUND SALT WATER POOL
I used the manual vacuum that came with the pool during the summer because I actually got in the pool and vacuumed), but ultimately, now that it is cold, I went to the pool store and bought a much bigger vacuum (that still hooks up to the water hose) and then a longer pole. It's just too darn cold to get in the water during the winter. :-) Hope this helps!
Nov 02, 2012 | Intex Automatic Salt Water System for ...
Pool chlorinator
Hi Chris, W/D here.
Here's a few things that you may or may not have checked:
1. You didn't state the age of the cell, or type. The generally last 2-3 years. I don't know how the power to the cell was checked, but clean the cell thoroughly before moving on. I use 1 gallon of muratic acid, and soak for about 5 minutes, then flipping the cell and soaking for 5 more minutes. Wear neoprene/chemical resistant gloves, and rinse thoroughly. Save the solution, as you can get several cleanings out of it.
2. Look for a fuse on your panel. The control boards are divided into areas of function. You'll need your wiring diagram, if the areas aren't clearly defined.
Hope this helps, --W/D--
Nov 09, 2011 | Pool & Spa
How do I hook up vacuum hose to skimmer?
I don't know exactly what vacuum system you have but I found the following link that might help: http://www.ehow.com/how_6304524_intex-pool-vacuum-instructions.html . I hope this helps.
Aug 27, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I don't know how to vacuume me pool. I have a hayward sand filter
all you need is a pole, a vacuum hose, and a vacuum head. connect the hose to the vacuum head and the head to the pole. Submerge the vacuum head and the pole into the pool and push the vacuum hose slowly straight down so that it fills with water. Once the entire vacuum hose is filled with water, plug it into the skimmer suction or wall port. You may have to adjust the valves at the pump to increase suction to wherever you have to vacuum hose plugged in to.
Hope this helps
Aug 01, 2011 | Hayward SAND FILTER, PRO SERIES
Use of pool vacuum
Try consulting the owners manual for these pool filters for more info. I can tell you that you need to have your valve set to rinse for normal vaccuming and waste for heavily soiled pools. Hope this helps.
http://www.backyardcitypools.com/images/hayward/pro-series-manual.pdf
May 04, 2010 | Hayward SAND FILTER, PRO SERIES
How do I hook up an aqua chem pool vacuum for an above ground pool?
i need to know the same thing,I hooked everything up as it looked right but no suction?I hooked the 1-1/4 hose to the vinyl liner vac. head then hooked the other end to my intake hole wich sucks into my filter,but i notice the filter water is not circulating properly,the filter itself is drained of water? will this burn it out or what?
Jul 18, 2009 | Vacuums
I have an inground pool which is clear however there is sediment on the bottom ,how do i vacuum it thanks
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=562395
Generic problem for all Vacuums
I have an in ground pool
posted by sibmrt on May 01, 2008
I have an in ground pool which is clear however
there is sediment on the bottom, how do I vacuum it
thanks
This is not a vacuum question as per the website and more of a question fro someone in the in ground pool company and they have pool cleaning equipment that works for the sediment on the bottom of the pool, my friend had one and it was called a vacuum pool snake or something like that. Sorry I could not help you with this question.
Thanks, Don – The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
When I vacum the pool which position of the pomp need to be:filter? waiste,or backwash?
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=561980
When I vacuum the pool
Posted by lovepuppies3 on May 01, 2008
When I vacuum the pool which position of the pomp need to be: filter, waste, or backwash?
This is not a question for the vacuum website, and I suggest that you check with an actual pool company because a vac dealer would not know the answer to the question, only a pool company would know. Sorry I could not help you this time.
Don – The Vac Man
Go Ahead. Use Us.
Dirt Devil POOL CLEANER FOR ABOVE-GROUND POOLS Logo
775 people viewed this question
Top Dirt Devil Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Dirt Devil Pool and Spa Expert? Answer questions, earn points and help others
