I have been given a Durabrand SA51AR 5.1 Home Speaker System 6 speakers 40W RMS. Unfortunately it does not have any cables, nor does it have the instruction booklet telling me how to connect the cables etc. Is it possible to purchase the booklet, and the cables.
  • 6,993 Answers
the booklet for this unit is not available for sale. But you can get the cable for connection from any electronics accessories shop withing your vicinity.
God luck.
Posted on Aug 28, 2010
Want to use my current speakers with a new surround sound system. Current system is 5.1 channels, rated at 100w per channel @ 8. Ohms. New System is rated 145watts, 5.2 channels at 6 Ohms. Will b ok?
Hi Ronald.
8 Ohm speakers will work just fine as replacements for the
6 ohm speakers. When fitting speakers you need to consider
The power handling capability. The impedance and the frequencies
involved. Power handling is expressed in wattage ie 100W.
Unfortunately this can be expressed in rms, max or peak music. The rms value (root mean square) is the only really relevant figure as this is the continuose handling power at 1 KHz. The impedance
is the resistance that the amp sees but is not a dc resistance and
varies with frequency. The lower the impedance the more power
will be drawn from the amp. In the event of a short circuit across
the speaker the amp will try to deliver infinite power into an infinitly
small load in an infinitesimal amount of time and will self destruct.
Using an 8 Ohm speaker draws less power than a 6 Ohm speaker.
Connecting speakers in parallel; results in the impedance beingreduced. For example two 8 Ohm speakers in parallel will result
in a 4 Ohm impedance load but in series will be 16 Ohms.
Incidentally the the .1 (5.1) is the sub woofer which only has
to handle the bass frequencies, a small percentage of the
amplifiers overall frequency response..
Connect your speakers and then power up the amp last
after double checking there are no shorts on the speaker
cables.
All the very best from Vintie.
Jan 07, 2017 | Audio Players & Recorders
Tip
How to install a 5.1 home theater system
1. Read the installation guidline/connection diagram given with the product.
2. u will get 5 speakers and a subwoofer. speakers are front left & right, rear left & right and center speaker.
3. install the front spearkers both side of the TV at ur ear level.
4. install the centre speaker at the centre above or below the TV at ur ear level.
5. install both the rear speaker at the back side wall corners (min 1.5 feet from ur sitting position) at a hight of 5 feet. face the speakers towards ur sitting position.
6. keep the sub woofer at the right side corner of the room.
7. note that the room should be a closed one with less air ventilession & use a carpet on the floor to get clear sound.
8. use co-excial or optical fibre cable to connect ur home theater system to ur TV, DVD player or audio device.
Now u can enjoy ur home theater.
on Aug 15, 2010 | Audio Players & Recorders
How to hook up cable box, dvd player, and tv, to the home theatre system
Instructions things you'll need:
  • Composite video cable
  • TV
    • 1 Place the front left and right speakers on each side of the TV with the speaker labeled "Center" either above or below the TV screen. Set the rear speakers behind the seating area at head level and place the subwoofer on the floor a few inches away from the wall, which can absorb bass sounds if the sub is pressed against it.
    • 2 Connect the plug on the end of each speaker to the jack labeled for that speaker on the back of the Durabrand receiver. The cables are permanently attached to the speakers, so each may need to be moved closer to the receiver. For example, the left front speaker connects to the jack on the receiver labeled "LF."
    • 3 Plug the video cable from the Video OUT jack on the back of the receiver to a Video Input jack on the back of the TV.
    • 4 Plug in the Durabrand receiver and TV to the electricity and switch on both components.
    • 5 Press the "Input" button on the TV remote several times until the Durabrand signal displays on the screen.
Mar 25, 2011 | Durabrand STS98RW Theater System
Same prob i also have the same problem my dvd is connected via scart to my tv i have nothing on my tv to connect the system to i have red and white on my dvd and also video so will this system work
i have just bought a DURABRAND SA51AR home theatre system, to go with my DURABRAND 2127N tv. and DURABRAND CG5660-M freeview set top box. i have connected all my output leads obviously the speaker ones. but my input i have only one red yellow white jack on my tv and three sets of red and white jack leads with home theatre system. cant get no sound no matter how many times iv swapped the input leads ... any idea s whats going wrong :oS :(
Apr 30, 2008 | Durabrand HT-3915 System
DURABRAND SA51AR
Based on your description, your Television has stereo outputs. Multiple channels may be "encoded" into those outputs, but your home theater system would need to interpret these encoded channels through one of its pairs of inputs.
I would try plugging the 5A51AR's Right/Left (Red/White) "Side Speaker" inputs into the TV's stereo outputs and see if the unit provides output to all speakers. There may be a switch on the unit labeled "Surround-Decode" or similar which needs to be set for this type of operation.
Feb 15, 2008 | Durabrand HT-3915 System
Installation manual
looking over the wikipedia website - - asda was purchased by walmart....the manual you seek may no longer be available as part of that company name...im still searching for info on a dvd /radio player myself...good luck to you...tddsim729@yahoo.com
Feb 07, 2008 | Audio Players & Recorders
Connecting Durabrand SA51AR to computer
Each "red and white" represent a stereo pair (Right and Left respectively. What type of connectors are on the SA51AR? I will guess TS (tip sleeve) or Phono for the sake of this answer.
It sounds as if the PC's outputs are stereo TRS (tip, ring sleeve) 1/8" female connectors, which is normal. TRS connectors carry both the Left and Right signals whereas Phono and TS only carry one signal each.
Radio Shack has converters which will allow you to plug a "red and white" connector in one end (either TS or Phono) and will provide a TRS output on the other which will plug into your PC's sound outputs. That way, the Red/White pair for "Side Speakers" (front L/R) can plug into the one grey jack and the Rear (rear L/R) can plug into the black-jack, etc.
Connecting durabrand SA51AR
COnnect to the CD/MP3 audio pair.
Dec 28, 2007 | Durabrand STS92 System
DURABRAND HOME THEATER
if you have a cable box run the subwoofer thru that . should work fine but you will have to turn off sub to kill volume as its running thru cable box not the audio of the tv
Nov 06, 2007 | Durabrand HT-3915 System
 Grubhead
Grubhead
