Question about Mtd 22" Yard Machine Push Mower
Gas leaking from MTD 22 push mower - how to replace fuel line? tank does not have any holes. Leak most likely from the line\bulb that you push to prime.
canbruce75
  • 1776 Answers
SOURCE: GOT GASOLINE IN OIL TANK.
Empty the tank of the tainted gasoline (Maybe add the right amount of oil and use it for a trimmer, etc), fill tank with fresh gas and clean the spark plug, since it is probably fouled out. You may have to clean the carb with some carb cleaner, and clean your plug a few extra times, but it should be fine. Hope this helps. Good luck.
Posted on Jul 15, 2009
  • 474 Answers
SOURCE: i have an MTD 3.5 hp Tecumseh lawn mower. The
it could be a bad line between you fuel tank and bulb. or it could be the pick up tube in the tank
Posted on Sep 17, 2009
kel1guy2002
  • 3740 Answers
SOURCE: mtd 22" yard machine staryts and dies using prospray.
Remove the float bowl again and remove the BRASS Jet in the bottom of the venturi throat. Clean the pin hole of the Jet so that you can see through it. DO NOT force anything through it. Just clean it. Underneath the jet is the venturi tube itself. It is also unscrewed with a screw driver. Remove it and clean all ofthe holes in it. Then reassemble tube and jet in to the venturi. Check the BOWL NUT for 2 holes. If the holes are clogged your engine will suffer from a lack of fuel. Lastly check that you have FUEL flow from the tank to the carb. If the tank outlet hole is clogged you will also have a lack of fuel problem.
Posted on Apr 11, 2010
Testimonial: "Thank you for your very helpful advice and detailed insructions as to what to do to correct this problem with starting my mower. runs like new now. Thanks again for taking the time to help me out. Grump."
  • 420 Answers
SOURCE: MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Posted on Jun 04, 2010
SOURCE: push mower starts, then dies, ad nauseum
i have a 21",4,5 hp yard machine with a briggs
Posted on Aug 26, 2010
Yard machines by mtd 11b-509n062 lawn mower is leaking gas from what appears to be a fuel line. The fuel line is a few inches below the gas cap.
Not sure what the question is. If the fuel line is leaking it is because it is not on the bottom of the tank well or it has a crack and needs to be replaced
Aug 10, 2013 | Mtd 22" Yard Machine Push Mower
Tip
Easy way to install fuel line and primer bulb return line into gas tank
Chainsaw fuel lines enter the gas tank from holes in top of tank. They are sized for a tight fit to prevent leakage. Make it easy on yourself when pushing the line through the tank by cutting a long lengthwise taper cut with razor knife 3 inches or longer to easily feed through that tight hole. Once started you will then have to grab it through the gas cap hole with needle nose pliers, then cut the tapered end flush and add fuel filter. Readjust inside length by pulling from above, then cut to length to upper carb fitting. If connecting to primer bulb a filter is not required and make sure the line goes to fitting on primer bulb marked tank.
on Nov 17, 2015 | Fuel Line & Primer Bulb Repair Kits 2...
My carburetor is leaking gas and i've only used it about four times
sounds like the Needle valve is not stopping fuel flow into the Bowl OR the Flaot in the carburetor has a leak and has sunk .
Teh needle valve has a rubber tip on teh end to close off the flow of fuel. Todays Ethanol gas Ruins the rubber tip. Thank the government for mandating this horrid Carburetor killing gas.
Sep 19, 2012 | Mtd 22" Yard Machine Push Mower
MTD Briggs and Straton 22" Mower Wont Start Brand
You probably have dirt in the carburetor. Or, you may have water in the fuel. As long as you have spark, then there is nothing else that it could be. Unless you have taken it apart already; have you done this?
Jim
Aug 16, 2011 | Mtd 22" Yard Machine Push Mower
Push mower starts, then dies, ad nauseum
Guessing you have a briggs and stratton motor with a tank mounted carb.Remove the tank and carb. from the mower and replace the rubber diaphram between the carb. and tank and clean it while its off
May 09, 2010 | Mtd 22" Yard Machine Push Mower
Mtd 22" yard machine staryts and dies using prospray.
Apr 09, 2010 | Mtd 22" Yard Machine Push Mower
Mtd ym 21" starts but wont stay running
Just checked my dad's for same problem. First thought is its not getting gas from tank; line is clean and no holes. On his 22" MTD push, i took off the air cleaner housing to expose the carb. Sprayed carb cleaner in carb throat, checked for smooth butterfly valve action, and also cleaned small jet/opening on left side of carb housing. Put it together and it ran perfectly. Don't buy a kit until you at least try this, its cheaper!
Oct 13, 2009 | Mtd 22" Yard Machine Push Mower
I have an MTD 3.5 hp Tecumseh lawn mower. The
WHAT KIND OF OIL DO I NEED FOR THE LAWN MOWER
Sep 17, 2009 | Mtd 22" Yard Machine Push Mower
Lawnmower wont start
Possible Causes Corrective actions
Unit will not start Control handle is not engaged Engage control handle spacer.gif spacer.gif
Spark plug wire is disconnected Connect spark plug wire spacer.gif spacer.gif
Fuel tank empty or stale fuel Replace with clean, fresh gas spacer.gif spacer.gif
Air filter filled with dirt or debris Replace or clean air filter
May 23, 2009 | Mtd 22" Yard Machine Push Mower
Mtd 22" Yard Machine Push Mower Logo
114 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
